2019-12-10Build: Update PSoC6 documentationfeature-twincpuAndrei Narkevitch
- updated docs for psoc62, psoc64 and psoc64_1m platforms Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I9f0c290bdb916ca799bc2cf374006d21f424f3be
2019-12-10Build: Add ability to sign S and NS images separately (psoc64, psoc64_1m)Andrei Narkevitch
With this change, script can sign each image individually or both in the same time. As long as cysecuretools sign_image overwrites unsigned image file with the signed one, script creates a copy of the original image and signs the copy. For CM4, sign_image also creates an unsigned copy of the image named <image to sign>_cm4.hex. Script deletes it to avoid confusion. Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I99381c33d68c2281cae2ac55cc482da7db5f78ac
2019-11-27Platform: Update tfm_platform_ns_wait_for_s_cpu_ready() in PSoC 6David Hu
Update return type of tfm_platform_ns_wait_for_s_cpu_ready() to int32_t on PSoC 6 platforms. Change-Id: I7a569ea354e0ff6541ccf64a412af1865a1eee71 Signed-off-by: David Hu <david.hu@arm.com>
2019-11-27Dualcpu: Update SPE mailbox APIsDavid Hu
Update SPE mailbox APIs to align with latest implementation on master branch. Update the APIs in PSoC 62 and PSoC 64. Change-Id: Ib862488682ed2c37786c30364ca0fb1e93779947 Signed-off-by: David Hu <david.hu@arm.com>
2019-11-27Platform: Update post HW init function in Secure sideDavid Hu
Update the post hardware init functions in Secure side and the implementation on PSoC platforms, to align with those on master branch. Change-Id: I0f4c76e7156d9939651e301f610cec6edda29bf0 Signed-off-by: David Hu <david.hu@arm.com>
2019-11-27App: Update NS side to align with master branchDavid Hu
Update NS post HW initialization and UART baudrate setting to align with the latest implementation on master branch. Change-Id: I90fbc56373ebeebe1c5ff07c343724aa447c0412 Signed-off-by: David Hu <david.hu@arm.com>
2019-11-27Dualcpu: Update lock operations in NS PSA Client call interfaceDavid Hu
Update the lock initialization, acquisition and release inside NS PSA Client call interface, to align with the latest implementation on master branch. Change-Id: Icfd4da19d8c061e7566c31b9b882caf95f922840 Signed-off-by: David Hu <david.hu@arm.com>
2019-11-27Dualcpu: Align with latest NS mailbox APIs on master branchDavid Hu
Update the NS mailbox APIs to prepare for merging PSoC platform support to master branch. Change-Id: I70469a557d8cc8e3fc78640688a365aabb3ea50f Signed-off-by: David Hu <david.hu@arm.com>
2019-11-27plat: Use PC to control protection (psoc64)Chris Brand
With older versions of Secure Flashboot (SFB), the CM0 is placed into non-secure mode before TFM is run, and the registers are locked down so that Cy_Prot_ConfigBusMaster() will cause a hard fault. This change alters the SMPU setup to reflect that environment. Protection Context (PC) is used to distinguish Secure from Non-secure, while privileged/user is still used in the same manner. We rely on SFB restricting the ability of the two cores to change their PC. Change-Id: I87d34a319f5c0b05831796ea3a113b3a54b61e1c Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-11-27plat: PSoC 64 2MB SMPU settingsChris Brand
Update the SMPU settings for the memory map of the 2MB PSoC64. Change-Id: I30c73f26284698a05069485678b80a7200dc1ad7
2019-11-27Plat: Memory layout changes for psoc64 platformAndrei Narkevitch
Flash layout: * 0x1000_0000 Secure image primary (320 KB) * 0x1005_0000 Non-secure image primary (1152 KB) * 0x1017_0000 Secure image secondary (320 KB) * 0x101c_0000 - 0x101f_ffff Reserved * 0x101c_0000 Secure Storage Area (20 KB) * 0x101c_5000 Internal Trusted Storage Area (16 KB) * 0x101c_9000 NV counters area (512 B) * 0x101c_9200 Scratch area (27.5 KB) * 0x101d_0000 Reserved (192 KB) * 0x101f_ffff End of Flash RAM layout: * 0x0800_0000 - 0x0802_FFFF Secure (192KB) * 0x0800_0000 - 0x0800_FFFF Secure unprivileged data (S_UNPRIV_DATA_SIZE, 64KB) * 0x0801_0000 - 0x0802_EFFF Secure priviliged data (S_PRIV_DATA_SIZE, 124KB) * 0x0802_F000 - 0x0802_FFFF Secure priv code executable from RAM (S_RAM_CODE_SIZE, 4KB) * 0x0803_0000 - 0x080E_7FFF Non-secure (736KB) * 0x0803_0000 - 0x080E_6FFF Non-secure OS/App (732KB) * 0x080E_7000 - 0x080E_7FFF Shared memory (NS_DATA_SHARED_SIZE, 4KB) * 0x080E_8000 - 0x080F_FFFF System reserved memory (96KB) * 0x0810_0000 End of RAM Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I74a6d002dfa953f8d17e0d9f8a5f32b44c881682
2019-11-27plat: Add support for configuring v2 PPUsChris Brand
The PSoC64 2MB has a different set of PPUs. Trying to configure the ones from the 62 and 64 1M will cause compilation errors. For now, we leave the PPUs as the boot code configures them. Change-Id: I9e444adae6a441043072f19bcef06cb63b176c14 Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-11-27plat: Update PPU code for PSoC64 2MChris Brand
The 2MB PSoC 64 has different PPUs (described as v2 in the PDL). For the programmable PPUs, we need the slave address and region size. Introduce #ifdefs so that we only get either the code for v1 PPUs or the code for v2 PPUs, but not both. Change-Id: I22935b00b0a5476880e9b066b0ef26b1e4e36de7 Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-11-22Plat: disable BL2 build for psoc64 and psoc64_1mAndrei Narkevitch
PSoC64 platforms do not use TF-M BL2 (mcuboot). Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I16b438778eb26c3d134636a0081d0a417d4dea6e
2019-11-22Plat: PSoC64 platform changesAndrei Narkevitch
- add psoc6_02 platform definitions - add GCC and CLang startup files - remove no longer needed DAP driver - change the mailbox interrupt: NvicMux9 is not available in psoc64 2MB part. Use NvicMux7 instead. Signed-off-by: Andrei Narkevitch <aih@cypress.com> Change-Id: Id1da7b1e77c9b6e040da616702f735efce158d03
2019-11-22Plat: SCB5 USART initializationAndrei Narkevitch
Added USART initialization as the original BSP misses it. Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I5bbf895c04eb0952f70ebe458c50e7811e15d8a3
2019-11-22Plat: Add CY8CKIT-062S2-4343W bsp codeAndrei Narkevitch
BSP was cloned from Cypress TARGET_CY8CKIT-062S2-4343W repo, tag: 1.0.0.7900 Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I87b0e17b492b37202616ddc9d379900f20f1d28c
2019-11-14Plat: Reorganize psoc6x platforms dir structureAndrei Narkevitch
Nest psoc62, psoc64 and psoc64_1m under "cypress" directory with intention to put common code in a common shared directory later (in a separate commit). Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: If1d9e285f76308a016b5bad349fddc1145390b5d
2019-11-14plat: Clone psoc64_1m build as psoc64Andrei Narkevitch
This is in preparation for adding support for PSoC64 2MB board. Note: copying entire directory "as is", thus creating many duplicating files, with an intention to create a better platform tree separation with common code support later. Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: Ib10f39fa253192e8c8de89315ee306d5d9b1c947
2019-11-14Plat: Rename psoc64 to psoc64_1mAndrei Narkevitch
Platform name psoc64 is reserved for the default PSoC64 part with 2MB Flash. Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I995a6e9be8fcac6ac08707a434164bda2fec9396
2019-11-14plat: Don't try to configure PPUs that we can't (PSoC 64)Chris Brand
On PSoC 64, some of the PPUs are already configured by the time TFM gets to run, so attempting to re-configure them will fail. Don't try to configure those PPUs. Change-Id: Idaf6a09c68f0f3d72fd44c70a1cc5149a22c057a Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-11-13plat: remove default config from USART driver (psoc64, psoc62)Andrei Narkevitch
Usage of board-specific configuration provided in generated_source/cycfg_peripherals.c makes the driver more generic. Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I2d134f61bf88758b00354752a3fecfb3105ff16d
2019-11-08plat: Turn off debug in default PSoC62 buildChris Brand
This was extremely useful when we were first getting TFM up and running on the platform, but we're now at the point where the non-debug build should be the default, and people wanting the debug build should enable it themselves. Change-Id: I1a0c3acd503704e644b2ec0be9ddd19adc88e074 Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-10-24plat: Print cy_en_prot_status_t as hex (PSoC)Chris Brand
cy_en_prot_status_t enumerals are specified as a bitmask, e.g. CY_PROT_BAD_PARAM = CY_PROT_ID | CY_PDL_STATUS_ERROR | 0x01U as such, they're much easier to interpret when printed in hex than in decimal. Signed-off-by: Chris Brand <chris.brand@cypress.com> Change-Id: Ibc4c910df62b85e66d73749847e8f7b3bffeed96
2019-10-24plat: Move system initialization out of USART driver (psoc64, psoc62)Andrei Narkevitch
System-wide initialization needs to be placed in more generic platform_init and bl2_platform_init functions. Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I6735591c643dab56e5308dddd782c8353a277ab0
2019-10-22plat: Ensure return value is always set (PSoC)Chris Brand
In protect_unconfigured_smpus(), if all SMPUs are already configured, ret would be returned without having been set. Change-Id: I17f6ee19546cf3ab5b6ff47ddc984a0e94434613 Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-10-17plat: Change RAM layout (psoc64)dualcpu_l2_v01Andrei Narkevitch
Modify the RAM layout and corresponding SMPU settings for PSoC64. PSoC64 specific limits available RAM to 192KB (from 0x08000000 to 0x08030000) and requries allocating CM4 core RAM in the lower 64KB. Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: If74b9b3141e765dd06f7f60b932340fbf9da13fd
2019-10-17plat: add policy and script for image signing (psoc64)Andrei Narkevitch
Add signing tools for CypressBootloader. Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I74b7be1a916e1454bfb2e16e128df895f4cf7db7
2019-10-17plat: mock mcuboot shared data (psoc64)Andrei Narkevitch
- Instead of TFM-customized mcuboot, at this moment psoc64 uses Cypress version of it - CypressBootloader (CYBL). CYBL doesn't populate BOOT_TFM_SHARED_DATA. - as a temp workaround, mock mcuboot shared data to pass initialization checks and attestation tests. Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I535a11e1d439e0e05af9874054bf2fa6bb810e53
2019-10-17plat: Debug Access Port (DAP) driver (psoc64)Andrei Narkevitch
As specified by the default security policy, CM4 core debug port is disabled during the boot, but allowed to be enabled later after CM4 is up. Add an API to control DAP and enable CM4 debugging. Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: Ica84ab545f04191c03e49dcc31eba61346737415
2019-10-17plat: Move some SMPU checks (psoc64)Chris Brand
Try to keep the code layout consistent: - SMPU struct definition - check for alignment constraint - check region protected is correct with any other checks based on a combination of SMPU structs after all the used structs have been defined. Change-Id: I05a5383ba51aa047c10d72a29bd2c0d300664ab7 Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-10-17plat: Ensure CM0+ runs as secure (psoc64)Chris Brand
It seems that the CM0+ on the PSoC64 board is currently set to non-secure mode by default. Explictly set it to secure mode before configuring the hardware isolation. Change-Id: Ib6753d46f9e33fbb0e30e8996cbeeef6ae5046ad Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-10-17plat: Change flash layout for PSoC64 (psoc64)Chris Brand
Modify the flash layout for PSoC64. This change modifies the psoc64 cmakefile such that a build with BL2=False will build for the PSoC64 target. The build with BL2=True is broken. RAM layout and corresponding SMPU settings still need to be changed. Change-Id: Ie80a6ca09edc9ffb0ca974f15868026ed8500f49 Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-10-17plat: Add header file for PSoC64 board (psoc64)Chris Brand
Copied verbatim from PDL version 1.3.1. Change-Id: I034b2c12890d5b48b043c160aca8a100f28e66e9 Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-10-17plat: Fix non-BL2 build (psoc64)Chris Brand
Fixes these errors when building with -DBL2=False: .../secure_fw/core/tfm_boot_data.c:54:41: error: use of undeclared identifier 'BOOT_TFM_SHARED_DATA_BASE' boot_data = (struct tfm_boot_data *)BOOT_TFM_SHARED_DATA_BASE; ^ .../secure_fw/core/tfm_boot_data.c:123:41: error: use of undeclared identifier 'BOOT_TFM_SHARED_DATA_BASE' boot_data = (struct tfm_boot_data *)BOOT_TFM_SHARED_DATA_BASE; ^ .../secure_fw/core/tfm_boot_data.c:124:15: error: use of undeclared identifier 'BOOT_TFM_SHARED_DATA_BASE' tlv_end = BOOT_TFM_SHARED_DATA_BASE + boot_data->header.tlv_tot_len; ^ .../secure_fw/core/tfm_boot_data.c:125:15: error: use of undeclared identifier 'BOOT_TFM_SHARED_DATA_BASE' offset = BOOT_TFM_SHARED_DATA_BASE + SHARED_DATA_HEADER_SIZE; ^ 4 errors generated. secure_fw/CMakeFiles/tfm_s_obj_lib.dir/build.make:446: recipe for target 'secure_fw/CMakeFiles/tfm_s_obj_lib.dir/core/tfm_boot_data.o' failed Note that there are still other issues preventing the build from completing, but those will be addressed in separate patches. Change-Id: If2e9b977e684c7b4b9bb0dd7daa1068fab656299 Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-10-17plat: Change which SMPU structs are used on psoc6Chris Brand
In preparation for adding support for PSoC64, change which SMPU structs are used. Change-Id: Ic9f23b0f0f321bf9802541746602e72503416b95 Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-10-16plat: Re-apply IPC config changes (psoc64)Chris Brand
Re-apply changes from commit 43cee2b3aa01fbe3032cbc7af3d782c7f0e5500a ("plat: enable default IPC configuration (PSoC64)") to the updated PDL code. Change-Id: Ib30f62f35c45a4530df3f4828a4ad447441f0d61 Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-10-16plat: Re-add shared memory region support (psoc64)Chris Brand
Re-apply the PDL changes from commit 142055ff18faa91fff25f18e54b2a3642880ae66 ("plat: add shared memory region support (PSoC6)") to the new PDL code. Change-Id: Id58131280b26b3ce03129fa12c894cf6e446ad7d Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-10-16plat: Re-replace .cy_ramfunc with .ramfuncChris Brand
Re-apply patch 5f7810c1f9b2e28e3ff5c16ae5b966f4479cab18 ("plat: replace .cy_ramfunc with .ram_func") to the new version of the PDL files. Signed-off-by: Chris Brand <chris.brand@cypress.com> Change-Id: Ib48f8320e783eb4277a62add426fc09dbfd640cb
2019-10-16plat: Re-apply PROT_SIZE_XXX definition changeChris Brand
Re-apply commit 4b1cd72acf3a180664497beedcef91907e11f487 ("Platform: Fix the condition check during preprocessing in SMPU on PSoC 6") to the new version of cy_prot.h. Signed-off-by: Chris Brand <chris.brand@cypress.com> Change-Id: If87c358cbbf1ac2f1f35dad0de3c34e7f1d83419
2019-10-16plat: Re-apply changes to new PDL code (psoc64)Chris Brand
Re-apply changes as needed from commit 0c937fa4968a83a3bcd4017c77df92a75f498ae1 ("plat: PSoC6 platform modifications") Change-Id: I1e05231ec39b8ed682c56a4b171402790275ed9d Signed-off-by: Chris Brand <chris.brand@cypress.com>
2019-10-15plat: Update PSoC 64 PDL code to version 1.3.1Chris Brand
Note that this a verbatim copy of the PDL code. As such, this patch effectively removes parts of the following patches: b901482dbf8b129a3adbe31c4e62432557fd1ba6 ("plat: Tweak Cypress code for Arm Compiler version 6") 4b1cd72acf3a180664497beedcef91907e11f487 ("Platform: Fix the condition check during preprocessing in SMPU on PSoC 6") 5f7810c1f9b2e28e3ff5c16ae5b966f4479cab18 ("plat: replace .cy_ramfunc with .ram_func") 142055ff18faa91fff25f18e54b2a3642880ae66 ("plat: add shared memory region support (PSoC6)") Later patches will re-apply those changes as needed. Signed-off-by: Chris Brand <chris.brand@cypress.com> Change-Id: Ic66de3161fce87f13f638a0f546fb35d77768aa9
2019-10-12plat: Enable Flash driver RWW support (PSoC62)Andrei Narkevitch
"Read while write" (RWW) improves flash driver performance and enables flash driver notifications between two cores. The latter is required to trigger an interrupt on CM4 side, which handler is located in RAM, thus preventing the core accessing flash memory during flash erase/program operations. - add Cy_SysIpcPipeIsrCm0 interrupt handler to CM0P interrupt vectors table - add Cy_SysIpcPipeIsrCm4 and Cy_Flash_ResumeIrqHandler to CM4 interrupt vectors table - consider supporting vectors table relocation to RAM in order to support run-time interrupt handlers registration - TBD Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I797be7334aef2b95c27b7aaa466380d7fb28f114
2019-10-11plat: Enable Flash driver RWW support (PSoC64)Andrei Narkevitch
"Read while write" (RWW) improves flash driver performance and enables flash driver notifications between two cores. The latter is required to trigger an interrupt on CM4 side, which handler is located in RAM, thus preventing the core accessing flash memory during flash erase/program operations. - add Cy_SysIpcPipeIsrCm0 interrupt handler to CM0P interrupt vectors table - add Cy_SysIpcPipeIsrCm4 and Cy_Flash_ResumeIrqHandler to CM4 interrupt vectors table - consider supporting vectors table relocation to RAM in order to support run-time interrupt handlers registration - TBD Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I36ac7a427ca8fb92fed1a765f10bc7a9e3ce29b4
2019-10-11plat: update CM4 ARM CLang startup file (psoc62, psoc64)Andrei Narkevitch
- update ARM CLang PSoC6 CM4 startup file with valid interrupt handlers (copied from mbed-os CY8CKIT_062_WIFI_BT startup_psoc6_01_cm4.S Git SHA: 101ae73b87e7082502915c5a4c6f3971fac270bb) Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I82509aa0b52aa66f43eaa74892a3bd48c87a5fb7
2019-10-11plat: enable default IPC configuration (PSoC64)Andrei Narkevitch
- IPC is used for semaphores subsystem, mailbox and CY Flash driver. Current implementation disables IPC initialization and configuration by setting CY_IPC_DEFAULT_CFG_DISABLE build flag. While not using IPC channels at the moment (RWW feature is disabled), Flash driver still relies on semaphores. Currently semaphores are initialized in the mailbox code. This patch enables default centralized IPC initialization in Cy_Platform_Init(). - By PDL design, Cy_Platform_Init is called from startup code. This creates a problem that all initialized variables are wiped off when C code starts. Proposed implementation adds optional call to a custom hw initialization function that for PSoC6 platform eventialy ends in Cy_Platform_Init(). Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I3b593ea9bec09d33bf6b49bbc885e266c8113930
2019-10-11plat: enable default IPC configuration (PSoC62)Andrei Narkevitch
- IPC is used for semaphores subsystem, mailbox and CY Flash driver. Current implementation disables IPC initialization and configuration by setting CY_IPC_DEFAULT_CFG_DISABLE build flag. While not using IPC channels at the moment (RWW feature is disabled), Flash driver still relies on semaphores. Currently semaphores are initialized in the mailbox code. This patch enables default centralized IPC initialization in Cy_Platform_Init(). - By PDL design, Cy_Platform_Init is called from startup code. This creates a problem that all initialized variables are wiped off when C code starts. Proposed implementation adds optional call to a custom hw initialization function that for PSoC6 platform eventialy ends in Cy_Platform_Init(). Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I13d83b67260c138df087ed63fa03535976ac73e7
2019-10-11plat: add NSPE platform-specific hw initializationAndrei Narkevitch
Adding tfm_ns_platform_init() function. Contrarily to SystemInit() intended for a high priority hw initialization (for example clock and power subsystems), and called on a very early boot stage from startup code, this function is called from C code, hence variables and other drivers data are protected from being cleared up by the C library init. This function can be used for initializing platform-specific hw resources (e.g. IPC, UART) thus freeing up application main() function from the platform details. Implemented as a "weak" functions, it can be overwritten by a platform specific implementation. Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I2ffc4d40465fa40039523418fe08face065029c0
2019-10-11plat: add BL2 platform-specific hw initializationAndrei Narkevitch
Adding bl2_platform_init() function. Contrarily to SystemInit() intended for a high priority hw initialization (for example clock and power subsystems), and called on a very early boot stage from startup code, this function is called from C code, hence variables and other drivers data are protected from being cleared up by the C library init. This function can be used for initializing platform-specific hw resources (e.g. IPC, UART) thus freeing up application main() function from the platform details. Implemented as a "weak" functions, it can be overwritten by a platform specific implementation. Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: Ia1e0e32c526bb1213ef9a32d04423221b51a3b7a
2019-10-11plat: add SPE platform-specific hw initializationAndrei Narkevitch
Adding tfm_spm_hal_post_platform_init() function. Contrarily to SystemInit() intended for a high priority hw initialization (for example clock and power subsystems), and called on a very early boot stage from startup code, this function is called from C code, hence variables and other drivers data are protected from being cleared up by the C library init. This function can be used for initializing platform-specific hw resources (e.g. IPC, UART) thus freeing up application main() function from the platform details. Implemented as a "weak" functions, it can be overwritten by a platform specific implementation. Signed-off-by: Andrei Narkevitch <ainh@cypress.com> Change-Id: I46d453954177f15c3d925717880ed1aa81e0a7d6
