path: root/bionic-amd64-tf-a-build/requirements_python3.txt
2021-01-21TF-A: add lavacliFathi Boudra
It's required to get the lava jobs log. Sort the python3 requirements. Signed-off-by: Fathi Boudra <fathi.boudra@linaro.org> Change-Id: Id58f749b479938c373ca6e1a78dcbf14db17d25e
2020-11-06bionic-amd64-tf-a-build: add deps for lava-test-plansMilosz Wasilewski
Signed-off-by: Milosz Wasilewski <milosz.wasilewski@linaro.org> Change-Id: I46bd23d41dfff71eb22f6f340c09fb03fc5d1982
2020-10-30Introduce bionic-amd64-tf-a-build dockerfile and build infrastructureLeonardo Sandoval
There is a need to have separate docker images, each one targeted for specific project, i.e. TF-A, TF-M and Hafnium, otherwise some toolchain triplets may collide, i.e arm-none-eabi for M-Profiles and arm-none-eabi for A-profiles, or there could be different toolchain versions requirements as seen in [1,2]. This commit introduce the definition of the docker image (Dockerfile), its dependencies and build script for the TF-A project. At this moment, the only difference between TF-A and TF-M dockerfile is the arm-none-eabi, each targeting its profile. As a consequence of this new image, the corresponding project-name is now part of the image, leading to two new images: * trustedfirmware/ci-amd64-tf-a-ubuntu:bionic * trustedfirmware/ci-amd64-tf-m-ubuntu:bionic [1] https://trustedfirmware-a.readthedocs.io/en/latest/getting_started/prerequisites.html?highlight=arm-none-eabi-gcc#toolchain [2] https://ci.trustedfirmware.org/view/TF-M/job/tf-m-build-docs-nightly/lastStableBuild/artifact/trusted-firmware-m/build/install/doc/user_guide/html/docs/getting_started/tfm_sw_requirement.html Signed-off-by: Leonardo Sandoval <leonardo.sandoval@linaro.org> Change-Id: Ia36551b29818d57dc08fb839032a16474dc59b79
