Fremont has more than one LCP in the system and all the LCPs need to be
loaded with the same image. Loading a single image to multiple
destination is currently not supported by MCUBoot.
In order to load the LCP image to N LCP designations, load copies of the
LCP ramfw to each LCP in the system by changing the ATU regions and
calling boot_go_for_image_id manually for each LCP after LCP 0.
Also, introduce build flag for LCP count as different Fremont variants
can have different LCP count.
Co-authored-by: Arnold Gabriel Benedict <arnoldgabriel.benedict@arm.com>
Signed-off-by: Vijayenthiran Subramaniam <vijayenthiran.subramaniam@arm.com>
Signed-off-by: Shriram K <shriram.k@arm.com>
Signed-off-by: Joel Goddard <joel.goddard@arm.com>
Change-Id: I2998d1b53f600f503a31ea2d100fef07acf7ea1d
* Update the flash layout and flash map info with LCP image details.
* Program RSE ATU to access the LCP ITCM via Cluster Utility region.
* As with SCP and MCP, the RSE ATU is setup so the code section of the
image is aligned with the start of the LCP ITCM in physical memory but
the header is contiguous in RSE logical memory.
Change-Id: I3d02521d6bbaddcb6b311b9dfb7ae00d47c78271
NI-Tower has programmable address maps (PSAM) and Access Protection
Units (APU) which can be configured during boot time which it uses to
map system addresses to interconnect targets for routing purposes as
well as to specify access permissions to configured regions.
Several nodes in the System Control NI-Tower instances are under SYSTOP
power domain rather than on the AON domain. So configure PSAMs and APUs
under SYSTOP power domain after RSE completes loading of SCP. The
support for RSE to wait for the SCP to complete the SYSTOP init will be
introduced in the subsequent patches.
Signed-off-by: Arnold Gabriel Benedict <arnoldgabriel.benedict@arm.com>
Change-Id: If078673a1a8d097d40357ef41f8534537ee93bdc
Add APU regions for the lcp_axis requester side interface. This
interface is on the requester side and does permissions checks for the
transactions targeting the SCP from LCP.
Change-Id: I65c588888a17cd45cb48ecdf013eaddc2d55898d
Add APU regions for the lcp_axim completer side interface. This
interface is on the completer side and does permissions checks for the
transactions targeting the Cluster Utility space.
Change-Id: Ife3395e5b8f2baff689d537a6572882235071bf2
Add APU regions for the app_axim completer side interface. This
transactions targeting the IO Block and Memory Controller + MPE
register space. This APU also does ID based filtering and currently,
all four valid requester IDs are enabled.
Change-Id: I342b462665016ad396b5514d31623143419fbebf
APP AXIS APU is responsible for PAS filtering for the transaction
originating at the app_axis interface. Add APU regions for app_axis
interface to check the permissions targeting the SCP, MCP and RSE
peripherals from AP. Since app_axis interface is present under the
SYSTOP power domain and not under the AON power domain, a new function
is introduced to configure the APUs under the SYSTOP domain and
app_axis APU will be programmed as part of it.
Note: The interfaces under SYSTOP domain can be accessed only after
SYSTOP is initialized. Accessing these node before SYSTOP init will
lead to error.
Change-Id: I8c41310de0cc04100434f30d1047fdaa5540b24c
Add PSAM region mappings for the lcp_axis requester interface of the
System Control NI-Tower instance. All physical address originating from
LCP will be mapped to the target interface LCP-SCP AXIM.
Change-Id: I50665de1997ae59db296a2bc862d3204cc8244e1
Add PSAM region mappings for the app_axis interface of the System
Control NI-Tower instance. The physical address coming out of AP will
be mapped to the target interface based on these PSAM region mappings.
Since this interface is under the SYSTOP power domain and not under
the AON power domain, a new function is introduced to configure the
PSAMs under the SYSTOP domain and app_axis will be programmed as part
of it.
lead to error.
Change-Id: I29dfd8a14f87d5d5ddf51850c419a5e532712536
Change-Id: I6338e7170a45739a2684d55030de694c16ae3223
Signed-off-by: Raef Coles <raef.coles@arm.com>
Change-Id: I5fd5df8edae0c81c6748df9d511e10a37b842b31
Change-Id: Ie9610565783026b0aa92943c164dd14b6a262d84
Check GPPC first, as it is less ephemeral. Also, attempt to run other
helpers if one does not trigger a jump.
Change-Id: Ia6a008cddc578fc787d01aa989188c972785b5c5
Change-Id: Ib6a1052d6801b379f1b9f0a10a0ed987331dab5c
Change-Id: I3d5e7c0f7655a48279468349895f686e2c1c3147
And don't overflow their fields
Change-Id: If4bcce66a9d26a9c41340d24edc12ce5dbfda204
To match integrity checker specification. Also, change the ICDL register
calculation to use 8 byte words.
Change-Id: I7ff8756d64b1372e820d5ddcb7df187ee1097273
As it is part of the OTP ICS
Change-Id: I99395625931ed78086d38ef23da96dd5673a1e14
RSE can control whether SCP can configure its ATU or whether it is
managed by RSE. RSE managing SCP ATU is not available yet, so allow SCP
to manage its own ATU.
Change-Id: I6d628dcaad9632edbb520ab7b4bee1fd27fa51d2
SCP and MCP are in a halted state and RSE is responsible for releasing
it from halt after the image loading to respective ITCM is completed.
This is done by configuring the MSCP_CPU_INIT_CTRL in the SCP RAS and
INIT Control registers address space.
Use MSCP drivers to unhalt SCP and MCP during post init stages of
respective firmware loading.
Change-Id: I94ba77ec4ecfc95f71626db55a691a7b08008168
Configure two instances of MSCP driver for SCP and MCP respectively.
As SCP and MCP are host devices specify ATU region for access SCP and
MCP registers.
Change-Id: I922981ffdd79d7e497032801e55612a077141dbc
Add MSCP driver which contains drivers for configuring registers in SCP
or MCP address space. At present add support to release CPU from halt.
Change-Id: Iaba10e11eb9e4a504e6852cbb0207be913872120
Configure MCUBoot to load MCP firmware image in RD-Fremont:
* Update flash layout and flash map with MCP image details
* Load MCP code directly to the start of the MCP ITCM. To do this the
ATU is used to map the MCUBoot image header to a different physical
area of memory while maintaining a contiguous logical addresses.
Change-Id: Id45ec2a4e0c554a69338882873c2e204b42a779b
Configure MCUBoot to load SCP firmware image in RD-Fremont:
* Update flash layout and flash map with SCP image details
* Load SCP code directly to the start of the SCP ITCM. To do this the
Change-Id: I0ac54c1c5773bd3c93fbe9718219402a2547d289
The shared memory for storing measureboot data is not large enough to
store the data for all images in RD-Fremont. To ensure there is
sufficient space, expand the shared data region.
Change-Id: I2ae50a45756cdf476b84cb69d146754fc53471ad
Units (APU) which can be configured during boot time. It uses these to
Configure PSAMs and APUs under Always-On (AON) power domain within the
System Control NI-Tower instance. RSE is required to configure the
system control NI-Tower before making any accesses to SCP/MCP or AP
address space.
In addition to this, enable the build of NI-Tower driver and the
corresponding platform configuration data for the system control
NI-Tower instance by setting the PLATFORM_HAS_NI_TOWER flag.
Change-Id: Ifdbd53fc37fc23b03f3c372a948bd0311e55ebc1
RSE MCP AXIM APU is the completer side filter that is present in front
of the MCP. Add APU regions for rse_mcp_axis interface to check the
permissions for the transactions coming from RSE and targeting the MCP.
Change-Id: I5a0fc6f5929945c5b0d2d41d11e0547553ad829e
RSE SCP AXIM APU is the completer side filter that is present in front
of the SCP. Add APU regions for rse_scp_axis interface to check the
permissions for the transactions coming from RSE and targeting the SCP.
Change-Id: I5c9e110c877c57a9bd2783f1708004407c1dc1af
RSM APBM APU is the completer side filter that is present in front of
the ECC record register block for Shared RAM between RSE, SCP and MCP
(RSM). Add APU regions for rsm_apbm interface to check the permissions
targeting the ECC record register block for Shared RAM between RSE, SCP
and MCP.
Change-Id: I7267cf5a9a9f26585f56501dc9c836f53b476db0
RSM AXIM APU is the completer side filter that is present in front of
the RSM SRAM (Shared SRAM between RSE/SCP/MCP). Add APU regions for
rsm_axim interface to check the permissions targeting the RSM SRAM.
Currently, all permissions are allowed.
Change-Id: I4cfa9b83e8cda91818eb8933db8f2666dd86b966
Each NI-Tower APU has registers for configuring the address regions it
protects along with entity access permission.
MCP AXIS APU is the requester side filter that is present at the output
of the MCP ATU. Add APU regions for mcp_axis interface to check the
permissions targeting the Generic refclk in SCP and the shared RSM
SRAM.
Change-Id: Iaac605e153e1aeeda6d39641d0e6887c6eddc911
Add PSAM address map to map access from RSE and SCP targeting LCP
address space. All access from RSE and SCP that target to LCP is routed
via a NIC400 outside of System Control NI-Tower and sent to the
'rse_scp_axis' on the NI-Tower.
This is necessitated because address filtering on transactions based on
the LCP memory map is required in the NI-Tower, but the target
'lcp_axim' interface APU can only do address filtering for upto 8 LCPs.
Hence, for every transaction targeting the LCP, the upper address bits
are propagated via AXI USER bits rather than on the AXI address signals
and the address filtering is applied based on the lower address bits.
With this, NI-Tower has to handle only on a 'single' LCP in the system,
regardless of the number of LCPs in the system or regardless of the
chip address offset.
Change-Id: Ib203ea14e5f96e6810dd5dae29f00aec808a533c
As a preparation to add use Cluster Utility and LCP memory map
definitions, add 'host_clus_util_lcp__memory_map.h' file.
Change-Id: I7cec3c00ec9eb667de89a70a19976ff8092be74a
Add PSAM region mappings for the mcp_axis requester interface of the
System Control NI-Tower instance. The physical address coming out of
MCP ATU will be mapped to the target interface based on this PSAM
region mappings.
Change-Id: Ifddb03640d9e232c079a957125907e71ad751091
Add PSAM region mappings for the scp_axis requester interface of the
SCP ATU will be mapped to the target interface based on this PSAM
region mappings.
Change-Id: I92f1c870a8288141e27d75cceeb8d56f7c9f09f4
System Control NI-Tower is the interconnect between the AXI interfaces
of RSE, SCP/MCP and the CMN interconnect. This NI-Tower has
programmable address maps (PSAM) and Access Protection Units (APU)
which can be configured during boot time. It uses these to map system
addresses to interconnect targets for routing purposes as well as to
specify access permissions to configured regions. RSE is required to
configure the system control NI-Tower before making any accesses to
SCP/MCP or AP address space.
Add PSAM region mappings for the rse_main_axis requester interface of
the System Control NI-Tower instance under Always-On (AON) power
domain. The physical address coming out of RSE ATU will be mapped to
the target interface based on this PSAM region mappings.
Change-Id: I15447ea5e33e8b7fc46bb21841b835d7eb0f1663
of RSE, SCP/MCP and the CMN interconnect. Add interface IDs for every
xSNI and xMNI interfaces connected to this system control NI-Tower. The
interface ID is pre-configured by the platform hardware configurations.
These IDs are required to fetch offset address for register bases of
NI-Tower components and subfeatures. Also, the target IDs can be used
while configuring PSAMs within the NI-Tower.
Change-Id: I47a21a7e82b453a11c2785754b7ada81476d7eaa
As a preparation to add more host specific memory map definitions,
add 'host_css_memory_map.h' file and move existing definitions to it.
In context of RSE, host includes all addresses in chip which is not
directly accessible by RSE.
Change-Id: Id113e8d46d5a710aa655a290a9dec3e200c1747d
Add functions to PSAM and APU to initialize new configuration to an
unconfigured region. These functions find the region number of next
available region by iterating over all the region configuration
registers in the controller. If a region is not enabled, then add
the configuration to that region.
Change-Id: Iabc545db005efb762db16c9c023d6353f0b03d34
Refactor 'component_node_type' and 'component_node_id' fields under
'ni_tower_psam_cfgs' and 'ni_tower_apu_cfgs' into a new dev_cfg
structure. This refactoring is necessary to allow device configurations
to be reusable during multiple configurations to a specific PSAM or an
APU.
Template to configure a region within a PSAM,
struct ni_tower_psam_dev_cfg PSAM_DEV_CFG = {
.component_node_type = NI_TOWER_ASNI,
.component_node_id = < asni_node_id >,
struct ni_tower_dev NI_TOWER_DEV = {
.periphbase = < ni_tower_base_address >,
.config_node_granularity = NI_TOWER_64KB_CONFIG_NODES
/* Array of regions within the PSAM */
static struct ni_tower_psam_reg_cfg_info psam_axis_0[] = {
< region_start_address >,
< region_end_address >,
< target_id >
/* Array of all PSAMs to be configured */
struct ni_tower_psam_cfgs psam_table[] = {
.dev_cfg = &PSAM_DEV_CFG,
.nh_region_count = 1,
.regions = psam_axis_0,
ni_tower_program_psam_table(&NI_TOWER_DEV, psam_table, 1);
Change-Id: Ie7f3e503d816aff863048a8d6afc1db39f582416
When configuring PSAM or APU regions, the memory region entry could
overlap with another region, which is already enabled in the PSAM or
APU. Check if the base address and end address of the new entry
overlaps with existing/enabled entry in the node. In case of APU, two
foreground regions or two background region should'nt overlap. Whereas,
a foreground region can overlap two background region. The APU
priorities the foreground access permission in such case.
Change-Id: I6eb69486b75c10cdf80f54740889cc64239f7210
When reconfiguring an APU region, previously set permissions or APU ids
were not cleared out, leading to wrong configuration of permissions or
APU ids. Resolve this issue by clearing out the permissions and APU ids
before programming the new values.
Also, if a region is locked, re-programming a region should not be
allowed to avoid any exceptions raised by the NI-Tower. Add a check to
disallow re-configuration when a region is locked.
Change-Id: I9c1f9aa18e20b79f8acaa4d59fd264647ecc6e2e
Change-Id: I310c27a97dca165c0151b680fca0f7db19bcc338
Signed-off-by: JidongMei <Jidong.Mei@armchina.com>
From CMSIS6, IARARM compiler only supports the `__NO_RETURN` macro
before the function definition.
Builds were failing if you compiled with IARARM toolchain.
Signed-off-by: Gergely Korcsák <gergely.korcsak@arm.com>
Change-Id: I0b89fcbb7b1ec94e886bb74c94ebb696ce90c988
Workaround the LPCXpresso55s69 compilation error in fsl_common_arm.c
after TFM upgrade to CMSISv6.
Change-Id: I22470474f37bfb8dd68961254515df94e022f69d
Signed-off-by: Andrej Butok <andrey.butok@nxp.com>
Adds a cut-down startup file for BL1_2 and BL2 based on the BL1_1
version. It removes interrupt handlers, PSP and stack sealing, which are
not required in bootloaders.
Signed-off-by: Jamie Fox <jamie.fox@arm.com>
Change-Id: I7b2e6998210c1c4d43bae3c0e41e663e37dbb06a
Changes nrfx_glue.h to use SPM_ASSERT instead of libc assert so
message is written to log on assertion failure.
Change-Id: Ided1e3ebec3b11b41d9c3ee3940e1000b81e2445
Signed-off-by: Vidar Lillebø <vidar.lillebo@nordicsemi.no>
Signed-off-by: Antonio de Angelis <antonio.deangelis@arm.com>
Change-Id: I3302197995e467a6d3fa3e161fde72d68057f3df
Add an API in the EC module to compute a shared secret following
the description available in SEC1 paragraph 3.3.1, leveraging the
scalar / point multiplication primitives
Change-Id: Ib45cf8a23ae37c792870fd6f71f18b20d0c2e9b4
Change-Id: I7e08b616ddc76233b49588a4487bb9773bb22da8
