path: root/plat/mediatek/mt8173/power_tracer.c
2019-01-04Sanitise includes across codebaseAntonio Nino Diaz
Enforce full include path for includes. Deprecate old paths. The following folders inside include/lib have been left unchanged: - include/lib/cpus/${ARCH} - include/lib/el3_runtime/${ARCH} The reason for this change is that having a global namespace for includes isn't a good idea. It defeats one of the advantages of having folders and it introduces problems that are sometimes subtle (because you may not know the header you are actually including if there are two of them). For example, this patch had to be created because two headers were called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform to avoid collision."). More recently, this patch has had similar problems: 46f9b2c3a282 ("drivers: add tzc380 support"). This problem was introduced in commit 4ecca33988b9 ("Move include and source files to logical locations"). At that time, there weren't too many headers so it wasn't a real issue. However, time has shown that this creates problems. Platforms that want to preserve the way they include headers may add the removed paths to PLAT_INCLUDES, but this is discouraged. Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-07-18Fix types of arch.h definitionsAntonio Nino Diaz
Define the values as unsigned int or unsigned long long based on the actual size of the register. This prevents subtle issues caused by having a type that is too small. For example: #define OPTION_ENABLE 0x3 #define OPTION_SHIFT 32 uint64_t mask = OPTION_ENABLE << OPTION_SHIFT; Because OPTION_ENABLE fits in an int, the value is considered an int. This means that, after shifting it 32 places to the left, the final result is 0. The correct way to define the values is: #define OPTION_ENABLE ULL(0x3) #define OPTION_SHIFT U(32) In this case, the compiler is forced to use a 64 bit value from the start, so shifting it 32 places to the left results in the expected value. Change-Id: Ieaf2ffc2d8caa48c622db011f2aef549e713e019 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-05-03Use SPDX license identifiersdp-arm
To make software license auditing simpler, use SPDX[0] license identifiers instead of duplicating the license text in every file. NOTE: Files that have been imported by FreeBSD have not been modified. [0]: https://spdx.org/ Change-Id: I80a00e1f641b8cc075ca5a95b10607ed9ed8761a Signed-off-by: dp-arm <dimitris.papastamos@arm.com>
2015-08-11Initial platform port for MediaTek mt8173CC Ma
- Boot up 4 cores. - Add a generic UART driver. - Add generic CPU helper functions - Supoort suspend - Add system_off & system_reset implementation - Add crash console reporting implementation - Add get_sys_suspend_power_state() for PSCI 1.0 SYSTEM_SUSPEND - Add Mediatek SIP runtime service - Add delay timer platform implementation Change-Id: I44138249f115ee10b9cbd26fdbc2dd3af04d825f Signed-off-by: CC Ma <cc.ma@mediatek.com> Signed-off-by: Jimmy Huang <jimmy.huang@mediatek.com>
