TF-A wants to eventually enable -Wold-style-definition globally. Convert
the rare few instances where this is still the case.
Signed-off-by: Boyan Karatotev <boyan.karatotev@arm.com>
Change-Id: I9c450fc875cf097e6de2ed577ea3b085821c9f5e
spd trusty requires memory dynamic mapping feature to be
enabled, so we have to use xlat table library v2 instead
of v1.
Signed-off-by: Ji Luo <ji.luo@nxp.com>
Signed-off-by: Jacky Bai <ping.bai@nxp.com>
Change-Id: I2813af9c7878b1fc2a59e27619c5b643af6a1e91
Use long instead of long long on aarch64 for 64_t stdint types.
Introduce inttypes.h to properly support printf format specifiers for
fixed width types for such change.
Change-Id: I0bca594687a996fde0a9702d7a383055b99f10a1
Signed-off-by: Scott Branden <scott.branden@broadcom.com>
This removes hardcoded iomux/clk/addr configuration for debug uart,
provides possibility (as a workaround, till that information isn't
provided via DT) to set this configuration during compile time via
IMX_DEBUG_UART build flag.
Usage:
$ make PLAT=imx8qm IMX_DEBUG_UART=1 bl31
Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com>
Change-Id: Ib5f5dd81ba0c8ad2b2dc5647ec75629072f511c5
Since now the generic console_t structure holds the UART base address as
well, let's use that generic location and drop the UART driver specific
data structure at all.
Change-Id: I058f793e4024fa7291e432f5be374a77faf16f36
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
This flag warns if anything is declared more than once in the same
scope, even in cases where multiple declaration is valid and changes
nothing.
Consequently, this patch also fixes the issues reported by this
flag. Consider the following two lines of code from two different source
files(bl_common.h and bl31_plat_setup.c):
IMPORT_SYM(uintptr_t, __RO_START__, BL_CODE_BASE);
IMPORT_SYM(unsigned long, __RO_START__, BL2_RO_BASE);
The IMPORT_SYM macro which actually imports a linker symbol as a C expression.
The macro defines the __RO_START__ as an extern variable twice, one for each
instance. __RO_START__ symbol is defined by the linker script to mark the start
of the Read-Only area of the memory map.
Essentially, the platform code redefines the linker symbol with a different
(relevant) name rather than using the standard symbol. A simple solution to
fix this issue in the platform code for redundant declarations warning is
to remove the second IMPORT_SYM and replace it with following assignment
static const unsigned long BL2_RO_BASE = BL_CODE_BASE;
Change-Id: If4835d1ee462d52b75e5afd2a59b64828707c5aa
Signed-off-by: Madhukar Pappireddy <madhukar.pappireddy@arm.com>
Current implementation of i.MX8QM power management related
features does NOT optimize power number, all system resources
like CCI, DDR, and A cluster etc. are kept in STBY mode (powered
ON) when system suspend or CPU hotplug.
To lower the power number, OFF mode should be adopted for those
system resources whenever they can be OFF, A cluster will be OFF
if the CPUs in the cluster are all off line, DDR/MU/DB can be OFF
if system suspend, IRQ steer can be OFF if the wakeup source is
belonged to system controller partition, so wakeup source runtime
check is used to determine if IRQ steer can be OFF before system
suspend.
If resources are powered off for suspend, they should be restored
properly after system resume.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
- Migrate to new GIC interfaces.
- Migrate to bl31_early_platform_setup2().
- Remove references to removed build options.
Change-Id: Ia7c63f75325ea4b41e32a9de3f01b0007d0ae210
NXP's i.MX8QM is an ARMv8 SoC with 2 clusters, 2 Cortex-A72
cores in one cluster and 4 Cortex-A53 in the other cluster,
and also has system controller (Cortex-M4) inside, documentation
can be found in below link:
https://www.nxp.com/products/processors-and-microcontrollers/
applications-processors/i.mx-applications-processors/i.mx-8-processors:IMX8-SERIES
This patch adds support for booting up SMP linux kernel (v4.9).
