BL2_AT_EL3 is an overloaded macro which has two uses:
1. When BL2 is entry point into TF-A(no BL1)
2. When BL2 is running at EL3 exception level
These two scenarios are not exactly same even though first implicitly
means second to be true. To distinguish between these two use cases we
introduce new macros.
BL2_AT_EL3 is renamed to RESET_TO_BL2 to better convey both 1. and 2.
Additional macro BL2_RUNS_AT_EL3 is added to cover all scenarious where
BL2 runs at EL3 (including four world systems).
BREAKING CHANGE: BL2_AT_EL3 renamed to RESET_TO_BL2 across the
repository.
Change-Id: I477e1d0f843b44b799c216670e028fcb3509fb72
Signed-off-by: Arvind Ram Prakash <arvind.ramprakash@arm.com>
Signed-off-by: Maksims Svecovs <maksims.svecovs@arm.com>
This patch changes definitions of bl2_mem_params_descs to follow the
TF-A coding style documented at
https://trustedfirmware-a.readthedocs.io/en/latest/process/coding-style.html
Signed-off-by: Jorge Troncoso <jatron@google.com>
Change-Id: I7bd99a50a79499aca0d349e49a3e095e6c5d2f08
Currently Tf-A uses whatever openssl binary is on the system to sign
images. However if OPENSSL_DIR is specified in the build flags this can
lead to linking issues as the system binary can end up being linked
against shared libraries provided in OPENSSL_DIR/lib if both binaries
(the system's and the on in OPENSSL_DIR/bin) are the same version.
This patch ensures that the binary used is always the one given by
OPENSSL_DIR to avoid those link issues.
Signed-off-by: Salome Thirot <salome.thirot@arm.com>
Change-Id: Ib534e06ebc8482e4391e376d3791a87968de4a99
This change makes the necessary additions to makefile of
platforms using partition driver.
Signed-off-by: Rohit Ner <rohitner@google.com>
Change-Id: I0d524760bf52e1d9b4a103f556231f20146bd78e
Use long instead of long long on aarch64 for 64_t stdint types.
Introduce inttypes.h to properly support printf format specifiers for
fixed width types for such change.
Change-Id: I0bca594687a996fde0a9702d7a383055b99f10a1
Signed-off-by: Scott Branden <scott.branden@broadcom.com>
Create a dedicated static struct mmc_device_info mmc_info mmc_info
instead of having this in stack.
A boot issue has been seen on some platform when applying patch [1].
[1] 13f3c5166f1 ("mmc:prevent accessing to the released space in case of wrong usage")
Signed-off-by: Yann Gautier <yann.gautier@foss.st.com>
Change-Id: If5db8857cccec2e677b16a38eb3eeb41628a264c
And from crash_console_flush.
We ignore the error information return by console_flush in _every_
place where we call it, and casting the return type to void does not
work around the MISRA violation that this causes. Instead, we collect
the error information from the driver (to avoid changing that API), and
don't return it to the caller.
Change-Id: I1e35afe01764d5c8f0efd04f8949d333ffb688c1
Signed-off-by: Jimmy Brisson <jimmy.brisson@arm.com>
CoT used for BL1 and BL2 are moved to tbbr_cot_bl1.c
and tbbr_cot_bl2.c respectively.
Common CoT used across BL1 and BL2 are moved to
tbbr_cot_common.c.
Signed-off-by: Manish V Badarkhe <Manish.Badarkhe@arm.com>
Change-Id: I2252ac8a6960b3431bcaafdb3ea4fb2d01b79cf5
Since now the generic console_t structure holds the UART base address as
well, let's use that generic location and drop the UART driver specific
data structure at all.
Change-Id: I7a23327394d142af4b293ea7ccd90b843c54587c
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
PLATFORM_CORE_COUNT - Unsigned int
PLATFORM_CLUSTER_COUNT - Unsigned int
PLATFORM_MAX_CPUS_PER_CLUSTER - Unsigned int
PLATFORM_CORE_COUNT_PER_CLUSTER - Unsigned int
Signed-off-by: Deepika Bhavnani <deepika.bhavnani@arm.com>
Change-Id: I327a8a2ab0f0e49bd62f413296c3b326393422b6
Avoid to load FIP by hacking address. Load it by partition table instead.
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Change-Id: I0283fc2e6e459bff14de19d92db4158e05106ee4
NOTE: AARCH32/AARCH64 macros are now deprecated in favor of __aarch64__.
All common C compilers pre-define the same macros to signal which
architecture the code is being compiled for: __arm__ for AArch32 (or
earlier versions) and __aarch64__ for AArch64. There's no need for TF-A
to define its own custom macros for this. In order to unify code with
the export headers (which use __aarch64__ to avoid another dependency),
let's deprecate the AARCH32 and AARCH64 macros and switch the code base
over to the pre-defined standard macro. (Since it is somewhat
unintuitive that __arm__ only means AArch32, let's standardize on only
using __aarch64__.)
Change-Id: Ic77de4b052297d77f38fc95f95f65a8ee70cf200
Signed-off-by: Julius Werner <jwerner@chromium.org>
NOTE: __ASSEMBLY__ macro is now deprecated in favor of __ASSEMBLER__.
All common C compilers predefine a macro called __ASSEMBLER__ when
preprocessing a .S file. There is no reason for TF-A to define it's own
__ASSEMBLY__ macro for this purpose instead. To unify code with the
export headers (which use __ASSEMBLER__ to avoid one extra dependency),
let's deprecate __ASSEMBLY__ and switch the code base over to the
predefined standard.
Change-Id: Id7d0ec8cf330195da80499c68562b65cb5ab7417
This consists of ensuring that the left operand of each shift is
unsigned when the operation might overflow into the sign bit.
Change-Id: I67984b6c48c08af61e95a4dbd18047e2c3151f9a
Signed-off-by: Justin Chadwell <justin.chadwell@arm.com>
The new API becomes the default one.
Change-Id: Ic1d602da3dff4f4ebbcc158b885295c902a24fec
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
Change-Id: I54869151bfc434df66933bd418c70cca9c3d0861
Signed-off-by: Michalis Pappas <mpappas@fastmail.fm>
The implementation of the heap function plat_get_mbedtls_heap() becomes
mandatory for platforms supporting TRUSTED_BOARD_BOOT.
The shared Mbed TLS heap default weak function implementation is
converted to a helper function get_mbedtls_heap_helper() which can be
used by the platforms for their own function implementation.
Change-Id: Ic8f2994e25e3d9fcd371a21ac459fdcafe07433e
Also, update platform_def.h guidelines about includes in the porting
guide.
Change-Id: I1ae338c9dd3242b309f6d53687ba2cb755d488c3
Many parts of the code were duplicating symbols that are defined in
include/common/bl_common.h. It is better to only use the definitions in
this header.
As all the symbols refer to virtual addresses, they have to be
uintptr_t, not unsigned long. This has also been fixed in bl_common.h.
Change-Id: I204081af78326ced03fb05f69846f229d324c711
The definitions in bl1/bl1_private.h and bl2/bl2_private.h are useful for
platforms that may need to access them.
Change-Id: Ifd1880f855ddafcb3bfcaf1ed4a4e0f121eda174
This is used as a table index, and already compared with an unsigned int:
block_dev_count.
Signed-off-by: Yann Gautier <yann.gautier@st.com>
commit 386b14bf64124ebf0368eab33ef07603e0c3138a
Author: Haojian Zhuang <haojian.zhuang@linaro.org>
Date: Wed Nov 21 09:19:49 2018 +0800
mmc: poll eMMC status after EXT_CSD command
EXT_CSD command needs to access data from eMMC device. Add the
operation of polling eMMC device status. Make sure the command is
finished.
A hacked delay time can't fit each eMMC device. Since the above commit
enables the polling operation, remove the hacked delay time now.
Some eMMC chips require a longer delay. After testing
different chips, 20ms appears to work reliably.
Signed-off-by: Ryan Grachek <ryan@edited.us>
hikey, hikey960, poplar: use new console APIs
Switch to the new console APIs enabled by setting MULTI_CONSOLE_API=1.
Enables building with ERROR_DEPRECATED=1.
Signed-off-by: Jerome Forissier <jerome.forissier@linaro.org>
All identifiers, regardless of use, that start with two underscores are
reserved. This means they can't be used in header guards.
The style that this project is now to use the full name of the file in
capital letters followed by 'H'. For example, for a file called
"uart_example.h", the header guard is UART_EXAMPLE_H.
The exceptions are files that are imported from other projects:
- CryptoCell driver
- dt-bindings folders
- zlib headers
Change-Id: I50561bf6c88b491ec440d0c8385c74650f3c106e
hikey: add delay after eMMC initialized
The macro EL_IMPLEMENTED() has been deprecated in favour of the new
function el_implemented().
Change-Id: Ic9b1b81480b5e019b50a050e8c1a199991bf0ca9
It boots failure on CircuitCo HiKey board. The delay could fix the
hang issue.
Even though at this point plat_crash_console_flush is optional, it will
stop being optional in a following patch.
The console driver of warp7 doesn't support flush, so the implementation
is a placeholder.
TI had ``plat_crash_console_init`` and ``plat_crash_console_putc``, but
they weren't global so they weren't actually used. Also, they were
calling the wrong functions.
imx8_helpers.S only has placeholders for all of the functions.
Change-Id: I8d17bbf37c7dad74e134c61ceb92acb9af497718
Remove deprecated interfaces for all platforms
- Migrate to new GIC interfaces.
- Remove unused bl1_init_bl2_mem_layout().
- Migrate to bl31_early_platform_setup2().
- Use PLAT_VIRT_ADDR_SPACE_SIZE and PLAT_PHY_ADDR_SPACE_SIZE.
- Update Makefile paths.
- Remove references to removed build options.
Change-Id: Idd1e99b4864b2a72e9e12ff1fcd73d8285bc1c94
Tested-by: Haojian Zhuang <haojian.zhuang@linaro.org>
plat/hisilicon/hikey/include/plat_macros.S:19:55: error: unexpected token in '.asciz' directive
.asciz "gicd_ispendr regs (Offsets 0x200 - 0x278)\n" " Offset:\t\t\tvalue\n"
Makefile:720: recipe for target 'build/hikey/debug/bl1/cortex_a53.o' failed
make: *** [build/hikey/debug/bl1/cortex_a53.o] Error 1
Merge two lines into one line.
tf_printf and tf_snprintf are now called printf and snprintf, so the
code needs to be updated.
Change-Id: Iffeee97afcd6328c4c2d30830d4923b964682d71
The codebase was using non-standard headers. It is needed to replace
them by the correct ones so that we can use the new libc headers.
Change-Id: I530f71d9510cb036e69fe79823c8230afe890b9d
Acked-by: Sumit Garg <sumit.garg@linaro.org>
Replace stdio.h functions by TF functions
Migrate to mmc framework.
Functions provided by stdio.h such as printf and sprintf are available
in the codebase, but they add a lot of code to the final image if they
are used:
- AArch64: ~4KB
- AArch32: ~2KB in T32, ~3KB in A32
tf_printf and tf_snprintf are a lot more simple, but it is preferable
to use them when possible because they are also used in common code.
Change-Id: Id09fd2b486198fe3d79276e2c27931595b7ba60e
Acked-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Fix several MISRA defects in PSCI library
BL1 is used in recovery mode on HiKey. The TBB implementation
on HiKey is in BL2. It means that user need to build ATF BL2
with TBB and ATF BL1 with non-TBB. It's inconvenient.
So include TBB in BL1, too.
Signed-off-by: Teddy Reed <teddy@prosauce.org>
Signed-off-by: Victor Chong <victor.chong@linaro.org>
Also change header guards to fix defects of MISRA C-2012 Rule 21.1.
Change-Id: Ied0d4b0e557ef6119ab669d106d2ac5d99620c57
Acked-by: Anson Huang <Anson.Huang@nxp.com>
This patch adds experimental support for TRUSTED_BOARD_BOOT to the
Hikey. This is adapted from the RPi3 and QEMU implementations.
Since the Hikey starts from BL2 the TRUSTED_BOARD_BOOT ROT begins there
too. When TRUSTED_BOARD_BOOT is defined, the BL1 build is skipped.
See the following example:
make \
PLAT=hikey \
BL33=u-boot.bin \
SCP_BL2=mcuimage.bin \
TRUSTED_BOARD_BOOT=1 \
MBEDTLS_DIR=../../mbedtls \
GENERATE_COT=1 \
all fip
Signed-off-by: Teddy Reed <teddy.reed@gmail.com>
RFC4122 defines that fields are stored in network order (big endian),
but TF-A stores them in machine order (little endian by default in TF-A).
We cannot change the future UUIDs that are already generated, but we can store
all the bytes using arrays and modify fiptool to generate the UUIDs with
the correct byte order.
Change-Id: I97be2d3168d91f4dee7ccfafc533ea55ff33e46f
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
Since commit 031dbb122472 ("AArch32: Add essential Arch helpers"),
it is difficult to use consistent format strings for printf() family
between aarch32 and aarch64.
For example, uint64_t is defined as 'unsigned long long' for aarch32
and as 'unsigned long' for aarch64. Likewise, uintptr_t is defined
as 'unsigned int' for aarch32, and as 'unsigned long' for aarch64.
A problem typically arises when you use printf() in common code.
One solution could be, to cast the arguments to a type long enough
for both architectures. For example, if 'val' is uint64_t type,
like this:
printf("val = %llx\n", (unsigned long long)val);
Or, somebody may suggest to use a macro provided by <inttypes.h>,
like this:
printf("val = %" PRIx64 "\n", val);
But, both would make the code ugly.
The solution adopted in Linux kernel is to use the same typedefs for
all architectures. The fixed integer types in the kernel-space have
been unified into int-ll64, like follows:
typedef signed char int8_t;
typedef unsigned char uint8_t;
typedef signed short int16_t;
typedef unsigned short uint16_t;
typedef signed int int32_t;
typedef unsigned int uint32_t;
typedef signed long long int64_t;
typedef unsigned long long uint64_t;
[ Linux commit: 0c79a8e29b5fcbcbfd611daf9d500cfad8370fcf ]
This gets along with the codebase shared between 32 bit and 64 bit,
with the data model called ILP32, LP64, respectively.
The width for primitive types is defined as follows:
ILP32 LP64
int 32 32
long 32 64
long long 64 64
pointer 32 64
'long long' is 64 bit for both, so it is used for defining uint64_t.
'long' has the same width as pointer, so for uintptr_t.
We still need an ifdef conditional for (s)size_t.
All 64 bit architectures use "unsigned long" size_t, and most 32 bit
architectures use "unsigned int" size_t. H8/300, S/390 are known as
exceptions; they use "unsigned long" size_t despite their architecture
is 32 bit.
One idea for simplification might be to define size_t as 'unsigned long'
across architectures, then forbid the use of "%z" string format.
However, this would cause a distortion between size_t and sizeof()
operator. We have unknowledge about the native type of sizeof(), so
we need a guess of it anyway. I want the following formula to always
return 1:
__builtin_types_compatible_p(size_t, typeof(sizeof(int)))
Fortunately, ARM is probably a majority case. As far as I know, all
32 bit ARM compilers use "unsigned int" size_t.
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Clean cache to flush parameters into SRAM before MCU using them.
Store those DDR parameters into SRAM. They may be used by MCU
firmware.
Fix that DDR can't work at 533MHz. Now step to set DDR frequency
from 150MHz to 800MHz. DDR could work among these frequency, 150MHz,
266MHz, 400MHz, 533MHz and 800MHz.
Fix switch statements to comply with MISRA rules
Clean usage of void pointers to access symbols
