Imported from the LLVM compiler_rt library on master branch as of
30 Oct 2018 (SVN revision: r345645).
This is to get the __aeabi_llsr() builtin, which is required by a
subsequent patch that uses a logical right shift operator in AArch32.
Change-Id: I9884139a12855a8a87206fb572aaa7dd35582b09
Signed-off-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
Change-Id: I058cfb5894daf1d12e1ef971c0ba36b0aa089be5
The codebase was using non-standard headers. It is needed to replace
them by the correct ones so that we can use the new libc headers.
Change-Id: I530f71d9510cb036e69fe79823c8230afe890b9d
Acked-by: Sumit Garg <sumit.garg@linaro.org>
When using __builtin_ctzll() in AArch32 code, the compiler may translate
that into a call to the __ctzdi2() function. In this case, the linking
phase fails because TF doesn't provide an implementation for it.
This patch imports the implementation of the __ctzdi2() function from
LLVM's compiler-rt project and hooks it into TF's build system. The
ctzdi2.c file is an unmodified copy from the master branch as of
July 19 2017 (SVN revision: 308480).
Change-Id: I96766a025ba28e1afc6ef6a5c4ef91d85fc8f32b
Change-Id: I32fc523e3178b7e50191682241904d52499ff708
This patch enables compiler-rt for the AArch32 target. The code is
not used for AArch64 as the architecture supports the 64-bit division
and modulo operations natively.
Change-Id: I1703a92872b0bb56ac0b98c67193830683963b13
These are needed to provide division and modulo operations
This code is entirely unmodified. Imported from compiler-rt
master branch as of May 4 2017.
Change-Id: I001e1809f2afd4bf8d4cc3d2296798809f607144
