nand_wait_ready is called with a millisecond delay
but the timeout used a micro second. Fixing the conversion
in the timeout call.
The prototype of the function is also changed to use an unsigned int
parameter.
Change-Id: Ia3281be7980477dfbfdb842308d35ecd8b926fb8
Signed-off-by: Lionel Debieve <lionel.debieve@st.com>
Signed-off-by: Yann Gautier <yann.gautier@st.com>
into integration
From commit: 21571b1d140ae7bb44e94c0afba2ec61456b275b
Made small changes to fit into TF-A project
Change-Id: I991f653a7ace04f9c84bcda78ad8d7114ea18e93
Signed-off-by: Madhukar Pappireddy <madhukar.pappireddy@arm.com>
* changes:
plat: tegra: Use generic ehf defines
ehf: use common priority level enumuration
Implemented a parser which populates the properties of
the CoT descriptors as per the binding document [1].
'COT_DESC_IN_DTB' build option is disabled by default and can
be enabled in future for all Arm platforms by making necessary
changes in the memory map.
Currently, this parser is tested only for FVP platform.
[1]:
https://trustedfirmware-a.readthedocs.io/en/latest/components/cot-binding.html
Change-Id: I2f911206087a1a2942aa728de151d2ac269d27cc
Signed-off-by: Manish V Badarkhe <Manish.Badarkhe@arm.com>
It uses the existing implementation of snprintf() function
Change-Id: Ie59418564c2e415222e819cf322c34e9a4d1f336
Change-Id: I07fd7fe1037857f6b299c35367c104fb51fa5cfa
into integration
The API can be used to invoke a 'stop_func' callback for all
other cores from any initiating core. Optionally it can also
wait for other cores to power down. There may be various use
of such API by platform. Ex: Platform may use this to power
down all other cores from a crashed core.
Signed-off-by: Sandeep Tripathy <sandeep.tripathy@broadcom.com>
Change-Id: I4f9dc8a38d419f299c021535d5f1bcc6883106f9
The DSU contains system control registers in the SCU and L3 logic to
control the functionality of the cluster. If "DIRECT CONNECT" L3
memory system variant is used, there won't be any L3 cache,
snoop filter, and SCU logic present hence no system control register
will be present. Hence check SCU presence before accessing DSU register
for DSU_936184 errata.
Signed-off-by: Pramod Kumar <pramod.kumar@broadcom.com>
Change-Id: I1ffa8afb0447ae3bd1032c9dd678d68021fe5a63
integration
This patch creates and populates the /cpus node in a device tree
based on the existing topology. It uses the minimum required nodes
and properties to satisfy the binding as specified in
https://www.kernel.org/doc/Documentation/devicetree/bindings/arm/cpus.txt
Signed-off-by: Javier Almansa Sobrino <javier.almansasobrino@arm.com>
Change-Id: I03bf4e9a6427da0a3b8ed013f93d7bc43b5c4df0
This patch introduces support for PN9 variant for some
Denver based platforms.
Original change by: Hemant Nigam <hnigam@nvidia.com>
Signed-off-by: Kalyani Chidambaram Vaidyanathan <kalyanic@nvidia.com>
Change-Id: I331cd3a083721fd1cd1b03f4a11b32fd306a21f3
Using the Fconf, register base address of the various nv-counters
(currently, trusted, non-trusted nv-counters) are moved to the
device tree and retrieved during run-time. This feature is
enabled using the build option COT_DESC_IN_DTB.
Change-Id: I236f532e63cea63b179f60892cb406fc05cd5830
Created a header file defining the id of the various nv-counters
used in the system.
Also, updated the device tree to add 'id' property for the trusted
and non-trusted nv-counters.
Change-Id: Ia41a557f7e56ad4ed536aee11c7a59e078ae07c0
'EHF' is used by RAS, SDEI, SPM_MM common frameworks.
If platform needs to plug-in specific handlers then
'PLAT_EHF_DESC' can be used to populate platform specific
priority levels.
Change-Id: I37af7e0e48111f87b6982604bf5c15db3e05755d
Signed-off-by: Olivier Deprez <olivier.deprez@arm.com>
Signed-off-by: Max Shvetsov <maksims.svecovs@arm.com>
Change-Id: Icf90c2ccce75257908ba3d4703926041d64b1dd3
FF-A interface to handle SPMC to SPMD direct messages requests.
Change-Id: Ia707a308c55561a31dcfa86e554ea1c9e23f862a
In case of AT speculative workaround applied, page table walk
is disabled for lower ELs (EL1 and EL0) in EL3.
Hence added a wrapper function which temporarily enables page
table walk to execute AT instruction for lower ELs and then
disables page table walk.
Execute AT instructions directly for lower ELs (EL1 and EL0)
assuming page table walk is enabled always when AT speculative
workaround is not applied.
Change-Id: I4ad4c0bcbb761448af257e9f72ae979473c0dde8
As per latest mailing communication [1], we decided to
update AT speculative workaround implementation in order to
disable page table walk for lower ELs(EL1 or EL0) immediately
after context switching to EL3 from lower ELs.
Previous implementation of AT speculative workaround is available
here: 45aecff00
AT speculative workaround is updated as below:
1. Avoid saving and restoring of SCTLR and TCR registers for EL1
in context save and restore routine respectively.
2. On EL3 entry, save SCTLR and TCR registers for EL1.
3. On EL3 entry, update EL1 system registers to disable stage 1
page table walk for lower ELs (EL1 and EL0) and enable EL1
MMU.
4. On EL3 exit, restore SCTLR and TCR registers for EL1 which
are saved in step 2.
[1]:
https://lists.trustedfirmware.org/pipermail/tf-a/2020-July/000586.html
Change-Id: Iee8de16f81dc970a8f492726f2ddd57e7bd9ffb5
SCTLR and TCR registers of EL1 plays role in enabling/disabling of
page table walk for lower ELs (EL0 and EL1).
Hence re-arranged EL1 context offsets to have SCTLR and TCR registers
values one after another in the stack so that these registers values
can be saved and restored using stp and ldp instruction respectively.
Change-Id: Iaa28fd9eba82a60932b6b6d85ec8857a9acd5f8b
* changes:
SPM: Add owner field to cactus secure partitions
SPM: Alter sp_gen.mk entry depending on owner of partition
plat/arm: enable support for Plat owned SPs
For Arm platforms SPs are loaded by parsing tb_fw_config.dts and
adding them to SP structure sequentially, which in-turn is appended to
loadable image list.
With recently introduced dualroot CoT for SPs where they are owned
either by SiP or by Platform. SiP owned SPs index starts at SP_PKG1_ID
and Plat owned SPs index starts at SP_PKG5_ID. As the start index of SP
depends on the owner, there should be a mechanism to parse owner of a SP
and put it at the correct index in SP structure.
This patch adds support for parsing a new optional field "owner" and
based on it put SP details(UUID & Load-address) at the correct index in
SP structure.
Change-Id: Ibd255b60d5c45023cc7fdb10971bef6626cb560b
Signed-off-by: Manish Pandey <manish.pandey2@arm.com>
* changes:
dualroot: add chain of trust for Platform owned SPs
cert_create: add Platform owned secure partitions support
We relyed on the default signed-ness of constants, which is usually
signed. This can create MISRA violations, such as:
bl1/bl1_main.c:257:[MISRA C-2012 10.8 (required)] Cast of composite
expression off essential type signed to essential type unsigned
These constants were only used as unsigned, so this patch makes them
explicitly unsigned.
Change-Id: I5f1310c881e936077035fbb1d5ffb449b45de3ad
Signed-off-by: Jimmy Brisson <jimmy.brisson@arm.com>
There was a collision between the name of the typedef in the CASSERT and
something else, so we make the name of the typedef unique to the
invocation of DEFFINE_SVC_UUID2 by appending the name that's passed into
the macro. This eliminates the following MISRA violation:
bl1/bl1_main.c:233:[MISRA C-2012 Rule 5.6 (required)] Identifier
"invalid_svc_uuid" is already used to represent a typedef.
This also resolves MISRA rule 5.9.
These renamings are as follows:
* tzram -> secram. This matches the function call name as it has
sec_mem in it's name
* fw_config_base -> config_base. This file does not mess with
hw_conig, so there's little chance of confusion
Change-Id: I8734ba0956140c8e29b89d0596d10d61a6ef351e
For dualroot CoT there are two sets of SP certificates, one owned by
Silicon Provider(SiP) and other owned by Platform. Each certificate can
have a maximum of 4 SPs.
This patch reduces the number of SiP owned SPs from 8 to 4 and adds
the remaining 4 to Plat owned SP.
Plat owned SP certificate is signed using Platform RoT key and
protected against anti-rollback using the Non-trusted Non-volatile
counter.
Change-Id: Idc3ddd87d6d85a5506a7435f45a6ec17c4c50425
Add support to generate a certificate named "plat-sp-cert" for Secure
Partitions(SP) owned by Platform.
Earlier a single certificate file "sip-sp-cert" was generated which
contained hash of all 8 SPs, with this change SPs are divided into
two categories viz "SiP owned" and "Plat owned" containing 4 SPs each.
Platform RoT key pair is used for signing.
Change-Id: I5bd493cfce4cf3fc14b87c8ed1045f633d0c92b6
ERRATA ID: RES-3033912 - Internal Address Space Init state causes
a hang upon accesses to [0xf070_0000, 0xf07f_ffff]
Workaround: Boot Firmware (ATF) should configure CCU_RGF_WIN(4) to
split [0x6e_0000, 0xff_ffff] to values [0x6e_0000, 0x6f_ffff] and
[0x80_0000, 0xff_ffff] that cause accesses to the segment of
[0xf070_0000, 0xf07f_ffff] to act as RAZWI. Reuse common
work-around code for both AP806 and AP807.
Change-Id: Ia91a4802d02917d1682faa0c81571093d1687d97
Signed-off-by: Stefan Chulski <stefanc@marvell.com>
* changes:
docs: marvell: update PHY porting layer description
docs: marvell: update path in marvell documentation
docs: marvell: update build instructions with CN913x
plat: marvell: octeontx: add support for t9130
plat: marvell: t9130: add SVC support
plat: marvell: t9130: update AVS settings
plat: marvell: t9130: pass actual CP count for load_image
plat: marvell: armada: a7k: add support to SVC validation mode
plat: marvell: armada: add support for twin-die combined memory device
This patch fixes the bug when AMUv1 group1 counters was
always assumed being implemented without checking for its
presence which was causing exception otherwise.
The AMU extension code was also modified as listed below:
- Added detection of AMUv1 for ARMv8.6
- 'PLAT_AMU_GROUP1_NR_COUNTERS' build option is removed and
number of group1 counters 'AMU_GROUP1_NR_COUNTERS' is now
calculated based on 'AMU_GROUP1_COUNTERS_MASK' value
- Added bit fields definitions and access functions for
AMCFGR_EL0/AMCFGR and AMCGCR_EL0/AMCGCR registers
- Unification of amu.c Aarch64 and Aarch32 source files
- Bug fixes and TF-A coding style compliant changes.
Change-Id: I14e407be62c3026ebc674ec7045e240ccb71e1fb
BL31 binary size is aligned to 4KB because of the
code in include\plat\arm\common\arm_reclaim_init.ld.S:
__INIT_CODE_UNALIGNED__ = .;
. = ALIGN(PAGE_SIZE);
__INIT_CODE_END__ = .;
with all the zero data after the last instruction of
BL31 code to the end of the page.
This causes increase in size of BL31 binary stored in FIP
and its loading time by BL2.
This patch reduces the size of BL31 image by moving
page alignment from __INIT_CODE_END__ to __STACKS_END__
which also increases the stack size for secondary CPUs.
Change-Id: Ie2ec503fc774c22c12ec506d74fd3ef2b0b183a9
This patch adds support for additional Denver MIDRs to
cover all the current SKUs.
Change-Id: I85d0ffe9b3cb351f430ca7d7065a2609968a7a28
Signed-off-by: Alex Van Brunt <avanbrunt@nvidia.com>
Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
Currently only single signing domain is supported for SP packages but
there is plan to support dual signing domains if CoT is dualroot.
SP_CONTENT_CERT_ID is the certificate file which is currently generated
and signed with trusted world key which in-turn is derived from Silicon
provider RoT key.
To allow dual signing domain for SP packages, other certificate file
will be derived from Platform owned RoT key.
This patch renames "SP_CONTENT_CERT_ID" to "SIP_SP_CONTENT_CERT_ID" and
does other related changes.
Change-Id: I0bc445a3ab257e2dac03faa64f46e36a9fed5e93
Provide manifest and build options to boot OP-TEE as a
guest S-EL1 Secure Partition on top of Hafnium in S-EL2.
Increase ARM_SP_MAX_SIZE to cope with OP-TEE debug build image.
Change-Id: Idd2686fa689a78fe2d05ed92b1d23c65e2edd4cb
Add CN913x case to bl2_plat_get_cp_count.
Fix loading of cp1/2 image. This is a preparation
patch for adding CN913x SoC family support.
Change-Id: Id84a30203d20572fc0dfd3f91ea395c199a85fe9
Signed-off-by: Ben Peled <bpeled@marvell.com>
This patch fixes violation of Rules 10.1, 10.4,
11.9 and 13.2 reported by MISRA-2012 scan.
Change-Id: Ibe9190cb0f26ae85d9a31db8e92fbd32f1740e25
integration
This patch fixes defects 10.3, 10.4, 10.7, 20.7
reported by MISRA-2012 scan and adds braces for
conditional statements according to the TF-A
coding style.
Change-Id: If84ed31cdd55bc8e7cdd2a5f48c0dacc25792112
Currently, 'SMCCC_ARCH_FEATURES' SMC call handler unconditionally
returns 'SMC_OK' for 'SMCCC_ARCH_SOC_ID' function. This seems to
be not correct for the platform which doesn't implement soc-id
functionality i.e. functions to retrieve both soc-version and
soc-revision.
Hence introduced a platform function which will check whether SMCCC
feature is available for the platform.
Also, updated porting guide for the newly added platform function.
Change-Id: I389f0ef6b0837bb24c712aa995b7176117bc7961
This reverts commit 11af40b6308ac75c83e874129bb79bc3a58060bf, reversing
changes made to 2afcf1d4b845272791b75c8285108c4dcd91e2b9.
This errata workaround did not work as intended so we are reverting this
change. In the future, when the corrected workaround is published in an
SDEN, we will push a new workaround.
This is the patch being reverted:
https://review.trustedfirmware.org/c/TF-A/trusted-firmware-a/+/4750
Signed-off-by: John Powell <john.powell@arm.com>
Change-Id: I20aa064c1bac9671939e657bec269d32b9e75a97
