path: root/include/plat/common/platform.h
2021-02-05Add TRNG Firmware Interface serviceJimmy Brisson
This adds the TRNG Firmware Interface Service to the standard service dispatcher. This includes a method for dispatching entropy requests to platforms and includes an entropy pool implementation to avoid dropping any entropy requested from the platform. Change-Id: I71cadb3cb377a507652eca9e0d68714c973026e9 Signed-off-by: Jimmy Brisson <jimmy.brisson@arm.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2020-10-09Don't return error information from console_flushJimmy Brisson
And from crash_console_flush. We ignore the error information return by console_flush in _every_ place where we call it, and casting the return type to void does not work around the MISRA violation that this causes. Instead, we collect the error information from the driver (to avoid changing that API), and don't return it to the caller. Change-Id: I1e35afe01764d5c8f0efd04f8949d333ffb688c1 Signed-off-by: Jimmy Brisson <jimmy.brisson@arm.com>
2020-07-26SMCCC: Introduce function to check SMCCC function availabilityManish V Badarkhe
Currently, 'SMCCC_ARCH_FEATURES' SMC call handler unconditionally returns 'SMC_OK' for 'SMCCC_ARCH_SOC_ID' function. This seems to be not correct for the platform which doesn't implement soc-id functionality i.e. functions to retrieve both soc-version and soc-revision. Hence introduced a platform function which will check whether SMCCC feature is available for the platform. Also, updated porting guide for the newly added platform function. Change-Id: I389f0ef6b0837bb24c712aa995b7176117bc7961 Signed-off-by: Manish V Badarkhe <Manish.Badarkhe@arm.com>
2020-07-21TF-A: Add support for Measured Boot driverAlexei Fedorov
This patch adds support for Measured Boot driver functionality in common Arm platform code. Change-Id: If049dcf8d847c39023b77c0d805a8cf5b8bcaa3e Signed-off-by: Alexei Fedorov <Alexei.Fedorov@arm.com>
2020-05-15plat/arm/fvp: Support performing SDEI platform setup in runtimeBalint Dobszay
This patch introduces dynamic configuration for SDEI setup and is supported when the new build flag SDEI_IN_FCONF is enabled. Instead of using C arrays and processing the configuration at compile time, the config is moved to dts files. It will be retrieved at runtime during SDEI init, using the fconf layer. Change-Id: If5c35a7517ba00a9f258d7f3e7c8c20cee169a31 Signed-off-by: Balint Dobszay <balint.dobszay@arm.com> Co-authored-by: Madhukar Pappireddy <madhukar.pappireddy@arm.com>
2020-05-13SPMD: extract SPMC DTB header size from SPMDOlivier Deprez
Currently BL2 passes TOS_FW_CONFIG address and size through registers to BL31. This corresponds to SPMC manifest load address and size. The SPMC manifest is mapped in BL31 by dynamic mapping. This patch removes BL2 changes from generic code (which were enclosed by SPD=spmd) and retrieves SPMC manifest size directly from within SPMD. The SPMC manifest load address is still passed through a register by generic code. Signed-off-by: Olivier Deprez <olivier.deprez@arm.com> Change-Id: I35c5abd95c616ae25677302f0b1d0c45c51c042f
2020-05-13SPMD: code/comments cleanupOlivier Deprez
As a follow-up to bdd2596d4, and related to SPM Dispatcher EL3 component and SPM Core S-EL2/S-EL1 component: update with cosmetic and coding rules changes. In addition: -Add Armv8.4-SecEL2 arch detection helper. -Add an SPMC context (on current core) get helper. -Return more meaningful error return codes. -Remove complexity in few spmd_smc_handler switch-cases. -Remove unused defines and structures from spmd_private.h Signed-off-by: Olivier Deprez <olivier.deprez@arm.com> Change-Id: I99e642450b0dafb19d3218a2f0e2d3107e8ca3fe
2020-03-17Implement SMCCC_ARCH_SOC_ID SMC callManish V Badarkhe
Implemented SMCCC_ARCH_SOC_ID call in order to get below SOC information: 1. SOC revision 2. SOC version Implementation done using below SMCCC specification document: https://developer.arm.com/docs/den0028/c Signed-off-by: Manish V Badarkhe <Manish.Badarkhe@arm.com> Change-Id: Ie0595f1c345a6429a6fb4a7f05534a0ca9c9a48b
2020-03-06TBB: Add an IO abstraction layer to load encrypted firmwaresSumit Garg
TBBR spec advocates for optional encryption of firmwares (see optional requirement: R060_TBBR_FUNCTION). So add an IO abstaction layer to support firmware decryption that can be stacked above any underlying IO/ packaging layer like FIP etc. It aims to provide a framework to load any encrypted IO payload. Also, add plat_get_enc_key_info() to be implemented in a platform specific manner as handling of encryption key may vary from one platform to another. Signed-off-by: Sumit Garg <sumit.garg@linaro.org> Change-Id: I9892e0ddf00ebecb8981301dbfa41ea23e078b03
2020-03-06drivers: crypto: Add authenticated decryption frameworkSumit Garg
Add framework for autheticated decryption of data. Currently this patch optionally imports mbedtls library as a backend if build option "DECRYPTION_SUPPORT = aes_gcm" is set to perform authenticated decryption using AES-GCM algorithm. Signed-off-by: Sumit Garg <sumit.garg@linaro.org> Change-Id: I2966f0e79033151012bf4ffc66f484cd949e7271
2020-02-10SPMD: add support for an example SPM core manifestAchin Gupta
This patch repurposes the TOS FW configuration file as the manifest for the SPM core component which will reside at the secure EL adjacent to EL3. The SPM dispatcher component will use the manifest to determine how the core component must be initialised. Routines and data structure to parse the manifest have also been added. Signed-off-by: Achin Gupta <achin.gupta@arm.com> Signed-off-by: Artsem Artsemenka <artsem.artsemenka@arm.com> Change-Id: Id94f8ece43b4e05609f0a1d364708a912f6203cb
2020-01-10Unify type of "cpu_idx" across PSCI module.Deepika Bhavnani
NOTE for platform integrators: API `plat_psci_stat_get_residency()` third argument `last_cpu_idx` is changed from "signed int" to the "unsigned int" type. Issue / Trouble points 1. cpu_idx is used as mix of `unsigned int` and `signed int` in code with typecasting at some places leading to coverity issues. 2. Underlying platform API's return cpu_idx as `unsigned int` and comparison is performed with platform specific defines `PLAFORM_xxx` which is not consistent Misra Rule 10.4: The value of a complex expression of integer type may only be cast to a type that is narrower and of the same signedness as the underlying type of the expression. Based on above points, cpu_idx is kept as `unsigned int` to match the API's and low-level functions and platform defines are updated where ever required Signed-off-by: Deepika Bhavnani <deepika.bhavnani@arm.com> Change-Id: Ib26fd16e420c35527204b126b9b91e8babcc3a5c
2019-12-20spm-mm: Refactor secure_partition.h and its contentsPaul Beesley
Before adding any new SPM-related components we should first do some cleanup around the existing SPM-MM implementation. The aim is to make sure that any SPM-MM components have names that clearly indicate that they are MM-related. Otherwise, when adding new SPM code, it could quickly become confusing as it would be unclear to which component the code belongs. The secure_partition.h header is a clear example of this, as the name is generic so it could easily apply to any SPM-related code, when it is in fact SPM-MM specific. This patch renames the file and the two structures defined within it, and then modifies any references in files that use the header. Change-Id: I44bd95fab774c358178b3e81262a16da500fda26 Signed-off-by: Paul Beesley <paul.beesley@arm.com>
2019-09-13Refactor ARMv8.3 Pointer Authentication support codeAlexei Fedorov
This patch provides the following features and makes modifications listed below: - Individual APIAKey key generation for each CPU. - New key generation on every BL31 warm boot and TSP CPU On event. - Per-CPU storage of APIAKey added in percpu_data[] of cpu_data structure. - `plat_init_apiakey()` function replaced with `plat_init_apkey()` which returns 128-bit value and uses Generic timer physical counter value to increase the randomness of the generated key. The new function can be used for generation of all ARMv8.3-PAuth keys - ARMv8.3-PAuth specific code placed in `lib\extensions\pauth`. - New `pauth_init_enable_el1()` and `pauth_init_enable_el3()` functions generate, program and enable APIAKey_EL1 for EL1 and EL3 respectively; pauth_disable_el1()` and `pauth_disable_el3()` functions disable PAuth for EL1 and EL3 respectively; `pauth_load_bl31_apiakey()` loads saved per-CPU APIAKey_EL1 from cpu-data structure. - Combined `save_gp_pauth_registers()` function replaces calls to `save_gp_registers()` and `pauth_context_save()`; `restore_gp_pauth_registers()` replaces `pauth_context_restore()` and `restore_gp_registers()` calls. - `restore_gp_registers_eret()` function removed with corresponding code placed in `el3_exit()`. - Fixed the issue when `pauth_t pauth_ctx` structure allocated space for 12 uint64_t PAuth registers instead of 10 by removal of macro CTX_PACGAKEY_END from `include/lib/el3_runtime/aarch64/context.h` and assigning its value to CTX_PAUTH_REGS_END. - Use of MODE_SP_ELX and MODE_SP_EL0 macro definitions in `msr spsel` instruction instead of hard-coded values. - Changes in documentation related to ARMv8.3-PAuth and ARMv8.5-BTI. Change-Id: Id18b81cc46f52a783a7e6a09b9f149b6ce803211 Signed-off-by: Alexei Fedorov <Alexei.Fedorov@arm.com>
2019-04-12Mbed TLS: Remove weak heap implementationAmbroise Vincent
The implementation of the heap function plat_get_mbedtls_heap() becomes mandatory for platforms supporting TRUSTED_BOARD_BOOT. The shared Mbed TLS heap default weak function implementation is converted to a helper function get_mbedtls_heap_helper() which can be used by the platforms for their own function implementation. Change-Id: Ic8f2994e25e3d9fcd371a21ac459fdcafe07433e Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
2019-02-27Add support for pointer authenticationAntonio Nino Diaz
The previous commit added the infrastructure to load and save ARMv8.3-PAuth registers during Non-secure <-> Secure world switches, but didn't actually enable pointer authentication in the firmware. This patch adds the functionality needed for platforms to provide authentication keys for the firmware, and a new option (ENABLE_PAUTH) to enable pointer authentication in the firmware itself. This option is disabled by default, and it requires CTX_INCLUDE_PAUTH_REGS to be enabled. Change-Id: I35127ec271e1198d43209044de39fa712ef202a5 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2019-01-04Sanitise includes across codebaseAntonio Nino Diaz
Enforce full include path for includes. Deprecate old paths. The following folders inside include/lib have been left unchanged: - include/lib/cpus/${ARCH} - include/lib/el3_runtime/${ARCH} The reason for this change is that having a global namespace for includes isn't a good idea. It defeats one of the advantages of having folders and it introduces problems that are sometimes subtle (because you may not know the header you are actually including if there are two of them). For example, this patch had to be created because two headers were called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform to avoid collision."). More recently, this patch has had similar problems: 46f9b2c3a282 ("drivers: add tzc380 support"). This problem was introduced in commit 4ecca33988b9 ("Move include and source files to logical locations"). At that time, there weren't too many headers so it wasn't a real issue. However, time has shown that this creates problems. Platforms that want to preserve the way they include headers may add the removed paths to PLAT_INCLUDES, but this is discouraged. Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-12-11SPM: Load image and RD from SP packageAntonio Nino Diaz
Load SP and RD from package instead of relying on RD being already loaded in memory and the SP being loaded as a BL32 image. Change-Id: I18d4fbf4597656c6a7e878e1d7c01a8a324f3f8a Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-12-10SPM: Introduce functions to load DTB filesAntonio Nino Diaz
Introduce helpers to create resource description struct, as well as code to load the information from DTB files. Change-Id: I0f5bb94eb8b01c6cb53fe807a9db0c05a70d7a43 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-09-28Remove all other deprecated interfaces and filesAntonio Nino Diaz
Change-Id: Icd1cdd42afdc78895a9be6c46b414b0a155cfa63 Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-09-28Remove deprecated bl1_init_bl2_mem_layout()Antonio Nino Diaz
Change-Id: I8ec8b4439ca1d7606aae069c2c576a9a8b18c92c Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-09-28Remove deprecated early platform setup interfacesAntonio Nino Diaz
The affected interfaces are bl31_early_platform_setup(), sp_min_early_platform_setup() and bl2_early_platform_setup(). Change-Id: I50c01ec68bcbe97fe4e5d101bcd0f763358b8e1e Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-09-28Remove build option LOAD_IMAGE_V2Roberto Vargas
The code of LOAD_IMAGE_V2=0 has been removed. Change-Id: Iea03e5bebb90c66889bdb23f85c07d0c9717fffe Co-authored-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com> Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-09-28PSCI: Remove platform compatibility layerRoberto Vargas
Change-Id: I40d040aa05bcbf11536a96ce59827711456b93a8 Co-authored-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com> Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-09-04Prepare Mbed TLS drivers for shared heapJohn Tsichritzis
The Mbed TLS drivers, in order to work, need a heap for internal usage. This heap, instead of being directly referenced by the drivers, now it is being accessed indirectly through a pointer. Also, the heap, instead of being part of the drivers, now it is being received through the plat_get_mbedtls_heap() function. This function requests a heap from the current BL image which utilises the Mbed TLS drivers. Those changes create the opportunity for the Mbed TLS heap to be shared among different images, thus saving memory. A default heap implementation is provided but it can be overridden by a platform specific, optimised implemenetation. Change-Id: I286a1f10097a9cdcbcd312201eea576c18d157fa Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
2018-08-22libc: Fix all includes in codebaseAntonio Nino Diaz
The codebase was using non-standard headers. It is needed to replace them by the correct ones so that we can use the new libc headers. Change-Id: I530f71d9510cb036e69fe79823c8230afe890b9d Acked-by: Sumit Garg <sumit.garg@linaro.org> Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-07-24PSCI: Fix MISRA defects in platform codeAntonio Nino Diaz
Fix violations of MISRA C-2012 Rules 10.1, 10.3, 13.3, 14.4, 17.7 and 17.8. Change-Id: I6c9725e428b5752f1d80684ec29cb6c52a5c0c2d Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-05-04AArch64: Introduce External Abort handlingJeenu Viswambharan
At present, any External Abort routed to EL3 is reported as an unhandled exception and cause a panic. This patch enables ARM Trusted Firmware to handle External Aborts routed to EL3. With this patch, when an External Abort is received at EL3, its handling is delegated to plat_ea_handler() function. Platforms can provide their own implementation of this function. This patch adds a weak definition of the said function that prints out a message and just panics. In order to support handling External Aborts at EL3, the build option HANDLE_EA_EL3_FIRST must be set to 1. Before this patch, HANDLE_EA_EL3_FIRST wasn't passed down to compilation; this patch fixes that too. Change-Id: I4d07b7e65eb191ff72d63b909ae9512478cd01a1 Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2018-02-28Fix MISRA rule 8.4 in common codeRoberto Vargas
Rule 8.4: A compatible declaration shall be visible when an object or function with external linkage is defined. Change-Id: I26e042cb251a6f9590afa1340fdac73e42f23979 Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2018-02-28Fix MISRA rule 8.3 in common codeRoberto Vargas
Rule 8.3: All declarations of an object or function shall use the same names and type qualifiers. Change-Id: Iff384187c74a598a4e73f350a1893b60e9d16cec Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2018-02-26BL1: Deprecate the `bl1_init_bl2_mem_layout()` APISoby Mathew
The `bl1_init_bl2_mem_layout()` API is now deprecated. The default weak implementation of `bl1_plat_handle_post_image_load()` calculates the BL2 memory layout and populates the same in x1(r1). This ensures compatibility for the deprecated API. Change-Id: Id44bdc1f572dc42ee6ceef4036b3a46803689315 Signed-off-by: Soby Mathew <soby.mathew@arm.com>
2018-02-26Introduce the new BL handover interfaceSoby Mathew
This patch introduces a new BL handover interface. It essentially allows passing 4 arguments between the different BL stages. Effort has been made so as to be compatible with the previous handover interface. The previous blx_early_platform_setup() platform API is now deprecated and the new blx_early_platform_setup2() variant is introduced. The weak compatiblity implementation for the new API is done in the `plat_bl_common.c` file. Some of the new arguments in the new API will be reserved for generic code use when dynamic configuration support is implemented. Otherwise the other registers are available for platform use. Change-Id: Ifddfe2ea8e32497fe1beb565cac155ad9d50d404 Signed-off-by: Soby Mathew <soby.mathew@arm.com>
2018-02-26Add image_id to bl1_plat_handle_post/pre_image_load()Soby Mathew
This patch adds an argument to bl1_plat_post/pre_image_load() APIs to make it more future proof. The default implementation of these are moved to `plat_bl1_common.c` file. These APIs are now invoked appropriately in the FWU code path prior to or post image loading by BL1 and are not restricted to LOAD_IMAGE_V2. The patch also reorganizes some common platform files. The previous `plat_bl2_el3_common.c` and `platform_helpers_default.c` files are merged into a new `plat_bl_common.c` file. NOTE: The addition of an argument to the above mentioned platform APIs is not expected to have a great impact because these APIs were only recently added and are unlikely to be used. Change-Id: I0519caaee0f774dd33638ff63a2e597ea178c453 Signed-off-by: Soby Mathew <soby.mathew@arm.com>
2018-02-02bl1: add bl1_plat_handle_{pre,post}_image_load()Masahiro Yamada
Just like bl2_, add pre/post image load handlers for BL1. No argument is needed since BL2 is the only image loaded by BL1. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-02-02bl2: add bl2_plat_handle_pre_image_load()Masahiro Yamada
There are cases where we need to manipulate image information before the load. For example, for decompressing data, we cannot load the compressed images to their final destination. Instead, we need to load them to the temporary buffer for the decompressor. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-01-18bl2-el3: Add BL2_EL3 imageRoberto Vargas
This patch enables BL2 to execute at the highest exception level without any dependancy on TF BL1. This enables platforms which already have a non-TF Boot ROM to directly load and execute BL2 and subsequent BL stages without need for BL1. This is not currently possible because BL2 executes at S-EL1 and cannot jump straight to EL3. Change-Id: Ief1efca4598560b1b8c8e61fbe26d1f44e929d69 Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2017-11-13BL31: Add SDEI dispatcherJeenu Viswambharan
The implementation currently supports only interrupt-based SDEI events, and supports all interfaces as defined by SDEI specification version 1.0 [1]. Introduce the build option SDEI_SUPPORT to include SDEI dispatcher in BL31. Update user guide and porting guide. SDEI documentation to follow. [1] http://infocenter.arm.com/help/topic/com.arm.doc.den0054a/ARM_DEN0054A_Software_Delegated_Exception_Interface.pdf Change-Id: I758b733084e4ea3b27ac77d0259705565842241a Co-authored-by: Yousuf A <yousuf.sait@arm.com> Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2017-11-13GIC: Introduce API to get interrupt IDJeenu Viswambharan
Acknowledging interrupt shall return a raw value from the interrupt controller in which the actual interrupt ID may be encoded. Add a platform API to extract the actual interrupt ID from the raw value obtained from interrupt controller. Document the new function. Also clarify the semantics of interrupt acknowledge. Change-Id: I818dad7be47661658b16f9807877d259eb127405 Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2017-11-08SPM: Introduce Secure Partition ManagerAntonio Nino Diaz
A Secure Partition is a software execution environment instantiated in S-EL0 that can be used to implement simple management and security services. Since S-EL0 is an unprivileged exception level, a Secure Partition relies on privileged firmware e.g. ARM Trusted Firmware to be granted access to system and processor resources. Essentially, it is a software sandbox that runs under the control of privileged software in the Secure World and accesses the following system resources: - Memory and device regions in the system address map. - PE system registers. - A range of asynchronous exceptions e.g. interrupts. - A range of synchronous exceptions e.g. SMC function identifiers. A Secure Partition enables privileged firmware to implement only the absolutely essential secure services in EL3 and instantiate the rest in a partition. Since the partition executes in S-EL0, its implementation cannot be overly complex. The component in ARM Trusted Firmware responsible for managing a Secure Partition is called the Secure Partition Manager (SPM). The SPM is responsible for the following: - Validating and allocating resources requested by a Secure Partition. - Implementing a well defined interface that is used for initialising a Secure Partition. - Implementing a well defined interface that is used by the normal world and other secure services for accessing the services exported by a Secure Partition. - Implementing a well defined interface that is used by a Secure Partition to fulfil service requests. - Instantiating the software execution environment required by a Secure Partition to fulfil a service request. Change-Id: I6f7862d6bba8732db5b73f54e789d717a35e802f Co-authored-by: Douglas Raillard <douglas.raillard@arm.com> Co-authored-by: Sandrine Bailleux <sandrine.bailleux@arm.com> Co-authored-by: Achin Gupta <achin.gupta@arm.com> Co-authored-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com> Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2017-10-24Add platform hooks for boot redundancy supportRoberto Vargas
These hooks are intended to allow one platform to try load images from alternative places. There is a hook to initialize the sequence of boot locations and a hook to pass to the next sequence. Change-Id: Ia0f84c415208dc4fa4f9d060d58476db23efa5b2 Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
2017-10-16GIC: Add API to set priority maskJeenu Viswambharan
API documentation updated. Change-Id: I40feec1fe67a960d035061b54dd55610bc34ce1d Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2017-10-16GIC: Add API to set/clear interrupt pendingJeenu Viswambharan
API documentation updated. Change-Id: I14e33cfc7dfa93257c82d76fae186b17a1b6d266 Co-authored-by: Yousuf A <yousuf.sait@arm.com> Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2017-10-16GIC: Add API to set interrupt routingJeenu Viswambharan
SPIs can be routed to either a specific PE, or to any one of all available PEs. API documentation updated. Change-Id: I28675f634568aaf4ea1aa8aa7ebf25b419a963ed Co-authored-by: Yousuf A <yousuf.sait@arm.com> Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2017-10-16GIC: Add API to raise secure SGIJeenu Viswambharan
API documentation updated. Change-Id: I129725059299af6cc612bafa8d74817f779d7c4f Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2017-10-16GIC: Add APIs to set interrupt type and query supportJeenu Viswambharan
The back end GIC driver converts and assigns the interrupt type to suitable group. For GICv2, a build option GICV2_G0_FOR_EL3 is introduced, which determines to which type Group 0 interrupts maps to. - When the build option is set 0 (the default), Group 0 interrupts are meant for Secure EL1. This is presently the case. - Otherwise, Group 0 interrupts are meant for EL3. This means the SPD will have to synchronously hand over the interrupt to Secure EL1. The query API allows the platform to query whether the platform supports interrupts of a given type. API documentation updated. Change-Id: I60fdb4053ffe0bd006b3b20914914ebd311fc858 Co-authored-by: Yousuf A <yousuf.sait@arm.com> Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2017-10-16GIC: Add API to set interrupt priorityJeenu Viswambharan
API documentation updated. Change-Id: Ib700eb1b8ca65503aeed0ac4ce0e7b934df67ff9 Co-authored-by: Yousuf A <yousuf.sait@arm.com> Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2017-10-16GIC: Add APIs to enable and disable interruptJeenu Viswambharan
API documentation updated. Change-Id: Ice7511f8df5356851001d2f7dc2a46cfe318f9ba Co-authored-by: Yousuf A <yousuf.sait@arm.com> Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2017-10-16GIC: Add API to get interrupt active statusJeenu Viswambharan
API documentation updated. Change-Id: I6d61785af0d5330930c709de971a904dc7c3516c Co-authored-by: Yousuf A <yousuf.sait@arm.com> Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2017-10-16GIC: Add APIs to query interrupt typesJeenu Viswambharan
These APIs allow the GIC implementation to categorize interrupt numbers into SPIs, PPIs, and SGIs. The default implementations for GICv2 and GICv3 follows interrupt numbering as specified by the ARM GIC architecture. API documentation updated. Change-Id: Ia6aa379dc955994333232e6138f259535d4fa087 Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
2017-10-16GIC: Add API to get running priorityJeenu Viswambharan
Document the API in separate platform interrupt controller API document. Change-Id: If18f208e10a8a243f5c59d226fcf48e985941949 Co-authored-by: Yousuf A <yousuf.sait@arm.com> Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
