integration
into integration
* changes:
allwinner: h6: power: Switch to using the AXP driver
drivers: allwinner: axp: Add AXP805 support
* changes:
allwinner: Convert AXP803 regulator setup code into a driver
allwinner: a64: power: Use fdt_for_each_subnode
allwinner: a64: power: Remove obsolete register check
allwinner: a64: power: Remove duplicate DT check
allwinner: Build PMIC bus drivers only in BL31
allwinner: a64: power: Make sunxi_turn_off_soc static
allwinner: Merge duplicate code in sunxi_power_down
allwinner: Clean up PMIC-related error handling
allwinner: Synchronize PMIC enumerations
allwinner: Enable clock before resetting I2C/RSB
Previously, the A64/H5 and H6 platforms' PMIC setup code was entirely
independent. However, some H6 boards also need early regulator setup.
Most of the register interface and all of the device tree traversal code
can be reused between the AXP803 and AXP805. The main difference is the
hardware bus interface, so that part is left to the platforms. The
remainder is moved into a driver.
I factored out the bits that were obviously specific to the AXP803;
additional changes for compatibility with other PMICs can be made as
needed.
The only functional change is that rsb_init() now checks the PMIC's chip
ID register against the expected value. This was already being done in
the H6 version of the code.
Signed-off-by: Samuel Holland <samuel@sholland.org>
Change-Id: Icdcf9edd6565f78cccc503922405129ac27e08a2
This adds the new regulator list, as well as changes to make the switch
(equivalent to DC1SW on the AXP803) work on both PMICs.
Change-Id: I9a1eac8ddfc54b27096c10a8eebdd51aaf9b8311
Add support for powering off the SGMII COMPHY (on lanes 0 and 1).
This is needed sometimes on Turris Mox when using KEXEC.
There is also another benefit of a little energy saving when the given
network interface is down.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Change-Id: I55ae0fe3627e7cc0f65c78a00771939d8bf5399f
When USB3 is on lane 2 and indirect register access is used, the polling
at the end of the mvebu_a3700_comphy_usb3_power_on function is
incorrect.
The LOOPBACK_REG0 register should not be used at all. Instead we have to
write the LANE_STATUS1 register address (with offset
USB3PHY_LANE2_REG_BASE_OFFSET) into the indirect address register and
then we should poll indirect data register.
This fixes problems on Turris Mox, which uses lane 2 for USB3.
Change-Id: I968b0cccee5ddbe10a2b5614e52e52d87682aacd
Add the support needed to enable using CryptoCell integration with
with RSA 3K support.
Signed-off-by: Gilad Ben-Yossef <gilad.benyossef@arm.com>
Change-Id: I95527cb0c41ae012109e8968dd20a4ae9fe67f17
* changes:
libc: Consolidate the size_t and NULL definitions
libc: Consolidate unified definitions
libc: Unify intmax_t and uintmax_t on AArch32/64
As supporting architectures aside from AArch32 and AArch64 is not a
concern, keeping identical definitions in two places for a large part
of the libc seems counterproductive
The int128 types were left un-unified as __int128 is not supported by
gcc on AArch32
Signed-off-by: Bence Szépkúti <bence.szepkuti@arm.com>
Change-Id: Idf08e6fab7e4680d9da62d3c57266ea2d80472cf
-Wlogical-op prevents common errors with using numerical constants where
a boolean one is expected as well as when the operands of a logical
operator are the same. While these are perfectly valid behavior, they
can be a sign that something is slightly off.
This patch adds this warning to gcc and it's closest equivalent to
clang, while also fixing any warnings that enabling them causes.
Change-Id: Iabadfc1e6ee0c44eef6685a23b0aed8abef8ce89
Signed-off-by: Justin Chadwell <justin.chadwell@arm.com>
Variable shadowing is, according to the C standard, permitted and valid
behaviour. However, allowing a local variable to take the same name as a
global one can cause confusion and can make refactoring and bug hunting
more difficult.
This patch moves -Wshadow from WARNING2 into the general warning group
so it is always used. It also fixes all warnings that this introduces
by simply renaming the local variable to a new name
Change-Id: I6b71bdce6580c6e58b5e0b41e4704ab0aa38576e
Change-Id: Ia120bcaacea3a462ab78db13f84ed23493033601
Signed-off-by: Max Shvetsov <maksims.svecovs@arm.com>
Arm's GIC-600 features a Power Register (GICR_PWRR),
which needs to be programmed to enable redistributor
operation. Section 3.6.1 in the GIC-600 TRM describes
the power-up and power-down sequence in pseudo code,
which deviates from the current TF-A implementation
in drivers/arm/gic/v3/gic600.c.
For powering on a redistributor, the pseudo code suggests
to loop over the whole sequence (check for transition,
write request bit) instead of just looping over the
ready bit read as TF-A does in gic600_pwr_on().
This patch fixes GIC-600 power up sequence according
to the TRM.
Change-Id: I445c480e96ba356b69a2d8e5308ffe6c0a97f45b
Previous implementation of timers assumed that clk_div has pretty
representation in MHz (10MHz, 100MHz, etc). Unusual frequencies
(99.99MHz) were causing assertion error and made udelay unusable.
Change-Id: Ic915fff224369d113fd9f8edbcfff169fca8beac
* changes:
gic/gic600: add support for multichip configuration
plat/arm/gicv3: add support for probing multiple GIC Redistributor frames
Add support to configure GIC-600's multichip routing table registers.
Introduce a new gic600 multichip structure in order to support platforms
to pass their GIC-600 multichip information such as routing table owner,
SPI blocks ownership.
This driver is currently experimental and the driver api may change in
the future.
Change-Id: Id409d0bc07843e271ead3fc2f6e3cb38b317878d
Signed-off-by: Vijayenthiran Subramaniam <vijayenthiran.subramaniam@arm.com>
Instead of retry polling, timer of 1ms is used to poll
Signed-off-by: Deepika Bhavnani <deepika.bhavnani@arm.com>
Change-Id: I7e028dc68138d2888e3cf0cbed744f5e6bc6ff42
Currently for Armv7 plaforms the quotient calculated in pl011
uart init code is moved to register r1.
This patch moves the quotient to register r2 as done for other
platforms in the udiv instruction. Value of register r2 is then
used to calculate the values for IBRD and FBRD register
Change-Id: Ie6622f9f0e6d634378b471df5d02823b492c8a24
Signed-off-by: Avinash Mehta <avinash.mehta@arm.com>
Change-Id: I84f8a99be2dcdf7c51fbecdb324df8e2f32cc855
Signed-off-by: Nicolas Le Bayon <nicolas.le.bayon@st.com>
Signed-off-by: Yann Gautier <yann.gautier@st.com>
In the SD Specification, Power Up Diagram of Card figure, the Timeout
value for initialization process (ACMD41 command retries) is 1 second.
Align to match MMC cards (in mmc_send_op_cond()) and Linux kernel code,
and set the delay between ACMD41 command retries to 10ms.
Change-Id: I2e07cb9944e7d7b72f2d4b13e0505e6751458091
* changes:
stm32mp1: add authentication support for stm32image
bsec: move bsec_mode_is_closed_device() service to platform
crypto: stm32_hash: Add HASH driver
* changes:
amlogic: g12a: Add support for the S905X2 (G12A) platform
amlogic: makefile: Use PLAT variable when possible
amlogic: sha_dma: Move register mappings to platform header
* changes:
Migrate ARM platforms to use the new GICv3 API
Adding new optional PSCI hook pwr_domain_on_finish_late
GICv3: Enable multi socket GIC redistributor frame discovery
* changes:
hikey: fix to load FIP by partition table.
hikey960: fix to load FIP by partition table
drivers: partition: support different block size
This patch provides declaration and definition of new GICv3 driver
API: gicv3_rdistif_probe().This function delegates the responsibility
of discovering the corresponding Redistributor base frame to each CPU
itself. It is a modified version of gicv3_rdistif_base_addrs_probe()
and is executed by each CPU in the platform unlike the previous
approach in which only the Primary CPU did the discovery of all the
Redistributor frames for every CPU.
The flush operations as part of gicv3_driver_init() function are
made necessary even for platforms with WARMBOOT_ENABLE_DCACHE_EARLY
because the GICv3 driver data structure contents are accessed by CPU
with D-Cache turned off during power down operations.
Change-Id: I1833e81d3974b32a3e4a3df4766a33d070982268
Signed-off-by: Madhukar Pappireddy <madhukar.pappireddy@arm.com>
This commit adds authentication binary support for STM32MP1.
It prints the bootrom authentication result if signed
image is used and authenticates the next loaded STM32 images.
It also enables the dynamic translation table support
(PLAT_XLAT_TABLES_DYNAMIC) to use bootrom services.
Signed-off-by: Lionel Debieve <lionel.debieve@st.com>
Change-Id: Iba706519e0dc6b6fae1f3dd498383351f0f75f51
This BSEC service is a platform specific service. Implementation
moved to the platform part.
Change-Id: I1f70ed48a446860498ed111acce01187568538c9
The driver manages the HASH processor IP on STM32MP1
Change-Id: I3b67c80c16d819f86b951dae29a6c465e51ad585
The block size of some storage device is 4096-byte long, such as UFS. But
PARTITION_BLOCK_SIZE is defined as 512-byte long. So replace it by
PLAT_PARTITION_BLOCK_SIZE. Make it configurable in platform.
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
Change-Id: Iada05f7c646d0a0f2c0d3b8545540b3cb7153de3
The registers location for the SHA DMA driver is not unique for the
different platforms. Move the mapping out of the driver and into the
platform-specific header.
Signed-off-by: Carlo Caione <ccaione@baylibre.com>
Change-Id: Ice64637844a3cb384b01e466cb8c1cea5f764129
To allow sharing the driver between the RPi3 and RPi4, move the random
number generator driver into the generic driver directory.
Change-Id: Iae94d7cb22c6bce3af9bff709d76d4caf87b14d1
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
To allow sharing the driver between the RPi3 and RPi4, move the mailbox
Change-Id: I463e49acf82b02bf004f3d56482b7791f3020bc0
This patch fixes GICv3 driver bug which causes assertion
when full range of SPI INTIDs 32-1019 is supported in
GICv3 implementation.
Change-Id: Ib6da4b6eea868cff271cb32c7c7570bf5547ab47
integration
Support for PKCS#1 v1.5 was deprecated in SHA 1001202 and fully removed
in SHA fe199e3, however, cert_tool is still able to generate
certificates in that form. This patch fully removes the ability for
cert_tool to generate these certificates.
Additionally, this patch also fixes a bug where the issuing certificate
was a RSA and the issued certificate was EcDSA. In this case, the issued
certificate would be signed using PKCS#1 v1.5 instead of RSAPSS per
PKCS#1 v2.1, preventing TF-A from verifying the image signatures. Now
that PKCS#1 v1.5 support is removed, all certificates that are signed
with RSA now use the more modern padding scheme.
Change-Id: Id87d7d915be594a1876a73080528d968e65c4e9a
Previously, TF-A could not support large RSA key sizes as the
configuration options passed to MBEDTLS prevented storing and performing
calculations with the larger, higher-precision numbers required. With
these changes to the arguments passed to MBEDTLS, TF-A now supports
using 3072 (3K) and 4096 (4K) keys in certificates.
Change-Id: Ib73a6773145d2faa25c28d04f9a42e86f2fd555f
integration
* changes:
rcar_gen3: drivers: ddr_b: Update DDR setting for H3, M3, M3N
rcar_gen3: drivers: qos: update QoS setting
rcar_gen3: drivers: ddr_b: Fix checkpatch errors in headers
rcar_gen3: drivers: ddr_b: Fix line-over-80s
rcar_gen3: drivers: ddr_b: Further checkpatch cleanups
rcar_gen3: drivers: ddr_b: Clean up camel case
rcar_get3: drivers: ddr_b: Basic checkpatch fixes
rcar_get3: drivers: ddr: Partly unify register macros between DDR A and B
rcar_get3: drivers: ddr: Clean up common code
* changes:
amlogic: Fix includes order
amlogic: Fix header guards
amlogic: Fix prefixes in the SoC specific files
amlogic: Fix prefixes in the PM code
amlogic: Fix prefixes in the SCPI related code
amlogic: Fix prefixes in the MHU code
amlogic: Fix prefixes in the SIP/SVC code
amlogic: Fix prefixes in the thermal driver
amlogic: Fix prefixes in the private header file
amlogic: Fix prefixes in the efuse driver
amlogic: Fix prefixes in the platform macros file
amlogic: Fix prefixes in the helpers file
amlogic: Rework Makefiles
amlogic: Move the SIP SVC code to common directory
amlogic: Move topology file to common directory
amlogic: Move thermal code to common directory
amlogic: Move MHU code to common directory
amlogic: Move efuse code to common directory
amlogic: Move platform macros assembly file to common directory
amlogic: Introduce unified private header file
amlogic: Move SCPI code to common directory
amlogic: Move the SHA256 DMA driver to common directory
amlogic: Move assembly helpers to common directory
amlogic: Introduce directory parameters in the makefiles
meson: Rename platform directory to amlogic
The STM32 console driver was pre-pending '\r' before '\n'.
It is now managed by the framework with the flag:
CONSOLE_FLAG_TRANSLATE_CRLF.
Remove the code in driver, and add the flag for STM32MP1.
Change-Id: I5d0d5d5c4abee0b7dc11c2f8707b1b5cf10149ab
The SHA256 DMA driver can be used by multiple SoCs. Move it to the
common directory.
Change-Id: I96319eeeeeebd503ef0dcb07c0e4ff6a67afeaa5
Meson is the internal code name for the SoC family. The correct name for
the platform should be Amlogic. Change the name of the platform
directory.
Change-Id: Icc140e1ea137f12117acbf64c7dcb1a8b66b345d
DBLOCKSIZE should be filled such as the data size is 2^DBLOCKSIZE.
Hence it is calculated with __builtin_ctz.
Change-Id: Id6b5ff9b594afc4fc523a388011beed307e6abd1
If the max-frequency property is provided in the device tree mmc node,
it should be managed. The max allowed frequency will be the min between
this property value and what the card can support.
Change-Id: I885b676c3300d2670a0fe4c6ecab87758b5893ad
