path: root/drivers/renesas/rzg
2021-04-20renesas: rzg: Add support to identify EK874 RZ/G2E boardLad Prabhakar
Add support to identify Silicon Linux RZ/G2E evaluation kit (EK874). Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com> Change-Id: Id7bdbc9b0d25aa9af496d58d4bd5055579edc104
2021-04-20drivers: renesas: rzg: Add QoS support for RZ/G2ELad Prabhakar
Add QoS support for RZ/G2E SoC. Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com> Change-Id: I2c4373807ab8c550d86d6abc97f5b01f2fb78fb3
2021-04-20drivers: renesas: rzg: Add PFC support for RZ/G2ELad Prabhakar
Add pin control support for RZ/G2E SoC. Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com> Change-Id: I736724cc0dd32f2169018ed7f2f48319b039b61f
2021-04-20renesas: rzg: Add support to identify HopeRun HiHope RZ/G2N boardLad Prabhakar
Add support to identify HopeRun HiHope RZ/G2N board. Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com> Change-Id: Ib47aba84b63488247f6e9da1f5878140129766ce
2021-04-20drivers: renesas: rzg: Add QoS support for RZ/G2NLad Prabhakar
Add QoS support for RZ/G2N SoC. Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com> Change-Id: I663b50d9fb41b9b20a6b54795278659b2b184bc4
2021-04-20drivers: renesas: rzg: Add PFC support for RZ/G2NLad Prabhakar
Add pin control support for RZ/G2N SoC. Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com> Change-Id: Ib5eb4f3b1b75e158ec13c4eefdbe9688344206a3
2021-04-20renesas: rzg: Add support to identify HopeRun HiHope RZ/G2H boardLad Prabhakar
Add support to identify HopeRun HiHope RZ/G2H board. Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com> Change-Id: I6b28350ef50595fea9a1b1b7353fcabaeb935970
2021-04-20drivers: renesas: rzg: Add QoS support for RZ/G2HLad Prabhakar
Add QoS support for RZ/G2H SoC. Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com> Change-Id: If7d8940148fc31887568fd501c6cab609e715ba4
2021-04-20drivers: renesas: rzg: Add PFC support for RZ/G2HLad Prabhakar
Add pin control support for RZ/G2H SoC. Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com> Change-Id: I06dc259d7d26a5a5313e8731ea72f846bfca09ed
2021-04-20drivers: renesas: rzg: Switch using common ddr codeLad Prabhakar
Switch using common ddr driver code from renesas/common/ddr directory for RZ/G2M SoC. Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com> Change-Id: I807dcb0bc5186bd32bc1c577945d28634bb10e1f
2021-01-13drivers: renesas: rzg: Add HiHope RZ/G2M board supportBiju Das
Add support for HiHope RZ/G2M board. Signed-off-by: Biju Das <biju.das.jz@bp.renesas.com> Reviewed-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Change-Id: Ic8eed0729a42aeee94fc96d16b15b928232488a3
2021-01-13renesas: rzg: Add PFC support for RZ/G2MBiju Das
Add pin control support for RZ/G2M SoC. Signed-off-by: Biju Das <biju.das.jz@bp.renesas.com> Reviewed-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Change-Id: I08719015cab1ec59e2270523980a0a3e26e72c01
2021-01-13renesas: rzg: Add QoS support for RZ/G2MBiju Das
Add QoS support for RZ/G2M SoC. Signed-off-by: Biju Das <biju.das.jz@bp.renesas.com> Reviewed-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Change-Id: If541278fd629761cc83398bba71e63f09d9dbee6
2021-01-13renesas: rzg: Add support for DRAM initializationBiju Das
Add support for initializing DRAM on RZ/G2M SoC. Signed-off-by: Biju Das <biju.das.jz@bp.renesas.com> Reviewed-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com> Change-Id: I99f1a6971a061a44687af498d55306a93e4fc8f7
