Add support for initializing DRAM on RZ/G2N SoC.
Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com>
Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com>
Change-Id: Id09a367b92b11a5da88f2dce6887677cc935d0c0
Select MMC_CH1 for eMMC on RZ/G2H SoC.
Change-Id: I1bdfa462fd98b144042c014701b342b87e1efc9d
Add support for initializing DRAM on RZ/G2H SoC.
Change-Id: Iae23f1093f65a9efd065d37b7d6e9340ff6350b9
Switch using common ddr driver code from renesas/common/ddr directory
for RZ/G2M SoC.
Change-Id: I807dcb0bc5186bd32bc1c577945d28634bb10e1f
Move ddr driver code to common directory, so that the same
code can be re-used by both R-Car Gen3 and RZ/G2 platforms.
Change-Id: I9aef73d3e9a027a127ce7483b72d339559866727
Enable eMMC driver support for RZ/G2M SoC.
Signed-off-by: Biju Das <biju.das.jz@bp.renesas.com>
Reviewed-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com>
Change-Id: I34803060c5b592ac24720b11d4a8cd3f9f40caee
Move DDR/QoS/PFC header files, so that the same code
Change-Id: I2cc0ceda8d05b6b8d95a69afdc233dc0d098e850
Move rpc driver code to common directory, so that the same
Change-Id: I04805d720d95b8edcc14e652f897fadc7f432197
Move avs driver code to common directory, so that the same
Change-Id: I85d9fa8b6abf158ce2521f1696478f7c5339fc42
Move authentication driver code to common directory, so that the
same code can be re-used by both R-Car Gen3 and RZ/G2 platforms.
Change-Id: I02592dfc714998bf89b9feaa78f685ae36be6f59
Move dma driver code to common directory, so that the same
Change-Id: Idce2e2f4e098cfc17219f963373d20ebf74e5b7c
Move watch driver code to common directory, so that the same
Change-Id: I235f2cde325a0feeadbfc4b7ee02e8b1186f7ea1
Move rom driver code to common directory, so that the same
Change-Id: I399dfb5eff186db76d26fa9c54bea88bee66789c
Move delay driver code to common directory, so that the same
Change-Id: I5e806bd0e0a0a4b436048513b7089db90ff9805f
Move console/scif driver code to common directory, so that the
Change-Id: I0b15e4f4ffaaa99e77bcee32b1dad648eeadcd9b
Move pwrc driver code to common directory, so that the same
Change-Id: I75d91a44d872fe2296b15c700efacd5721385363
Move io driver code to common directory, so that the same
Change-Id: Ic661e415c91a1fbfd5eee3bba86466037e51574b
Move eMMC driver code to common directory, so that the same
Change-Id: I7f3055709337327d1a1c9f563c14ad1626adb355
Move plat common sources to common directory, so that same
Change-Id: Id2b1822c97cc50e3febaffc2e5f42b4d53809a17
Create a common directory and move the header and assembly files
so that the common code can be used by both Renesas R-Car Gen3 and
RZ/G2 platforms.
Change-Id: Ia9a563a1c3c9f8c6f0d3cb82622deb2e155d7f6c
