The comments with the prototypes of the register functions of the
console drivers are incorrect. The arguments are wrong. This patch fixes
them.
Change-Id: I38c4b481ee69e840780111c42f03c0752eb6315c
It is still a placeholder, but now it is registered correctly by the
macro finish_console_register.
Change-Id: Ic78c966d9be606cbc1a53cec43ead23b32963afe
This patch updates the Cadence CDNS console driver to support the new
console API. The driver will continue to support the old API as well by
checking the MULTI_CONSOLE_API compile-time flag.
Change-Id: I2ef8fb0d6ab72696997db1e0243a533499569d6b
Signed-off-by: Julius Werner <jwerner@chromium.org>
It is needed to add placeholders for this function because, as this is
not a `plat_xxx()` function, there aren't weak definitions of it in any
file.
If `console_flush()` is used and there isn't an implementation of
`console_core_flush()` in any file, the compilation will fail.
Change-Id: I50eb56d085c4c9fbc85d40c343e86af6412f3020
This patch moves the various assembly console drivers
into `aarch64` architecture specific folder. Stub files,
which include files from new location, are retained at the
original location for platform compatibility reasons.
Change-Id: I0069b6c1c0489ca47f5204d4e26e3bc3def533a8
