path: root/contributing.md
2014-04-01Update contributing.md with new integration processDan Handley
Contributions will now be merged into an ARM Trusted Firmware integration branch on GitHub instead of via an ARM internal branch.
2014-03-05Remove change log instructions from contribution.mdDan Handley
Remove the instructions to update the change log from contribution.md. The change log no longer contains a "Detailed changes since last release" section. Also, update the documentation links following recent documentation changes. Change-Id: Id9df43d666f7f9a60dcc6f663a8a85cdd2ff7cc4
2014-02-26Update contributing.md to new CLA locationDan Handley
This commit updates contributing.md to point to the ARM website for downloading copies of the Contribution License Agreement (CLA). It is no longer necessary to email ARM for these. Change-Id: Iaf58680631a626f26827577709ac5471e3b84566
2014-01-30Allow style checking of tree and local changesIan Spray
New phony Makefile targets have been added: * checkcodebase * checkpatch The checkcodebase target will run a Linux style compliance check over the entire codebase, and honours the V=1 Makefile verbose setting and so will show more information when this is enabled. If the local directory is a git checkout then the output of git ls-files is used to decide which files to test for compliance. If the local directory is not under git control then a 'best attempt' is made, but in this case it should be noted that it is possible for additional non-codebase files to be tested, so care should be taken when parsing the output. The checkpatch target will compare local changes against the git origin/master to allow issues with the last set of changes to be identified. To override the change comparision location, set the BASE_COMMIT variable to your desired git branch. Both targets rely on the Linux source tree script checkpatch.pl to do the syntax checking, and expects that the CHECKPATCH environment variable points to the location of this file. Notes on the usage of these targets have been added to the contributing.md and docs/user-guide.md text files. Change-Id: I6d73c97af578e24a34226d972afadab9d30f1d8d
2014-01-17Update year in copyright text to 2014Dan Handley
Change-Id: Ic7fb61aabae1d515b9e6baf3dd003807ff42da60
2014-01-17Refer to separate issue tracking repositoryDan Handley
Update documentation to refer to separate issue tracking repository, https://github.com/ARM-software/tf-issues/issues. Change-Id: Ib1cef65b0da420bec58290d8743eb069b1226c96
2013-12-05Enable third party contributionsDan Handley
- Add instructions for contributing to ARM Trusted Firmware. - Update copyright text in all files to acknowledge contributors. Change-Id: I9311aac81b00c6c167d2f8c889aea403b84450e5
