This patch introduces the populate function which leverages
a new driver to extract base address and clk frequency properties
of the uart serial node from HW_CONFIG device tree.
This patch also introduces fdt helper API fdtw_translate_address()
which helps in performing address translation.
Change-Id: I053628065ebddbde0c9cb3aa93d838619f502ee3
Signed-off-by: Madhukar Pappireddy <madhukar.pappireddy@arm.com>
The stdout-path property in the /chosen node of a DTB points to a device
node, which is used for boot console output.
On most (if not all) ARM based platforms this is the debug UART.
The ST platform code contains a function to parse this property and
chase down eventual aliases to learn the node offset of this UART node.
Introduce a slightly more generalised version of this ST platform function
in the generic fdt_wrappers code. This will be useful for other platforms
as well.
Change-Id: Ie6da47ace7833861b5e35fe8cba49835db3659a5
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
The STM32 platform port parse DT nodes to find base address to
peripherals. It does this by using its own implementation, even though
this functionality is generic and actually widely useful outside of the
STM32 code.
Re-implement fdt_get_reg_props_by_name() on top of the newly introduced
fdt_get_reg_props_by_index() function, and move it to fdt_wrapper.c.
This is removes the assumption that #address-cells and #size-cells are
always one.
Change-Id: I6d584930262c732b6e0356d98aea50b2654f789d
At the moment the fconf_populate_gicv3_config() implementation is
somewhat incomplete: First it actually fails to store the retrieved
information (the local addr[] array is going nowhere), but also it makes
quite some assumptions about the device tree passed to it: it needs to
use two address-cells and two size-cells, and also requires all five
register regions to be specified, where actually only the first two
are mandatory according to the binding (and needed by our code).
Fix this by introducing a proper generic function to retrieve "reg"
property information from a DT node:
We retrieve the #address-cells and #size-cells properties from the
parent node, then use those to extract the right values from the "reg"
property. The function takes an index to select one region of a reg
property.
This is loosely based on the STM32 implementation using "reg-names",
which we will subsume in a follow-up patch.
Change-Id: Ia59bfdf80aea4e36876c7b6ed4d153e303f482e8
The STM32 platform code uses its own set of FDT helper functions,
although some of them are fairly generic.
Remove the implementation of fdt_read_uint32_default() and implement it
on top of the newly introduced fdt_read_uint32() function, then convert
all users over.
This also fixes two callers, which were slightly abusing the "default"
semantic.
Change-Id: I570533362b4846e58dd797a92347de3e0e5abb75
Our fdtw_read_cells() implementation goes to great lengths to
sanity-check every parameter and result, but leaves a big hole open:
The size of the storage the value pointer points at needs to match the
number of cells given. This can't be easily checked at compile time,
since we lose the size information by using a void pointer.
Regardless the current usage of this function is somewhat wrong anyways,
since we use it on single-element, fixed-length properties only, for
which the DT binding specifies the size.
Typically we use those functions dealing with a number of cells in DT
context to deal with *dynamically* sized properties, which depend on
other properties (#size-cells, #clock-cells, ...), to specify the number
of cells needed.
Another problem with the current implementation is the use of
ambiguously sized types (uintptr_t, size_t) together with a certain
expectation about their size. In general there is no relation between
the length of a DT property and the bitness of the code that parses the
DTB: AArch64 code could encounter 32-bit addresses (where the physical
address space is limited to 4GB [1]), while AArch32 code could read
64-bit sized properties (/memory nodes on LPAE systems, [2]).
To make this more clear, fix the potential issues and also align more
with other DT users (Linux and U-Boot), introduce functions to explicitly
read uint32 and uint64 properties. As the other DT consumers, we do this
based on the generic "read array" function.
Convert all users to use either of those two new functions, and make
sure we never use a pointer to anything other than uint32_t or uint64_t
variables directly.
This reveals (and fixes) a bug in plat_spmd_manifest.c, where we write
4 bytes into a uint16_t variable (passed via a void pointer).
Also we change the implementation of the function to better align with
other libfdt users, by using the right types (fdt32_t) and common
variable names (*prop, prop_names).
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/arch/arm64/boot/dts/allwinner/sun50i-a64.dtsi#n874
[2] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/arch/arm/boot/dts/ecx-2000.dts
Change-Id: I718de960515117ac7a3331a1b177d2ec224a3890
Currently our fdtw_read_array() implementation requires the length of
the property to exactly match the requested size, which makes it less
flexible for parsing generic device trees.
Also the name is slightly misleading, since we treat the cells of the
array as 32 bit unsigned integers, performing the endianess conversion.
To fix those issues and align the code more with other DT users (Linux
kernel or U-Boot), rename the function to "fdt_read_uint32_array", and
relax the length check to only check if the property covers at least the
number of cells we request.
This also changes the variable names to be more in-line with other DT
users, and switches to the proper data types.
This makes this function more useful in later patches.
Change-Id: Id86f4f588ffcb5106d4476763ecdfe35a735fa6c
This patch adds 'fdtw_read_bytes' and 'fdtw_write_inplace_bytes'
functions for read/write array of bytes from/to a given property.
It also adds 'fdt_setprop_inplace_namelen_partial' to jmptbl.i
files for builds with USE_ROMLIB=1 option.
Change-Id: Ied7b5c8b38a0e21d508aa7bcf5893e656028b14d
fdtw_read_cells() can only read one or two cells, sometimes it may be
needed to read more cells from one property.
Change-Id: Ie70dc76d1540cd6a04787cde7cccb4d1bafc7282
Introduced fdtw_read_string() to read string properties.
Change-Id: I854eef0390632cf2eaddd2dce60cdb98c117de43
Change-Id: I1d85b76af002b8b672fcaeca94939b7420bc8243
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
Change-Id: I9b1cdaf2430a1998a69aa366ea1461224a3d43dc
Co-Authoured-by: Jeenu Viswambharan <Jeenu.Viswambharan@arm.com>
