Currently BL2 passes TOS_FW_CONFIG address and size through registers to
BL31. This corresponds to SPMC manifest load address and size. The SPMC
manifest is mapped in BL31 by dynamic mapping. This patch removes BL2
changes from generic code (which were enclosed by SPD=spmd) and retrieves
SPMC manifest size directly from within SPMD. The SPMC manifest load
address is still passed through a register by generic code.
Signed-off-by: Olivier Deprez <olivier.deprez@arm.com>
Change-Id: I35c5abd95c616ae25677302f0b1d0c45c51c042f
At the moment, OP-TEE has no support to receive a DTB in Secure Memory
so it cannot receive TOS_FW_CONFIG_ID as it is supposed to happen on
any BL32 image. Instead, when OP-TEE is enable as BL32 payload,
NT_FW_CONFIG_ID is passed.
This MUST be reverted as soon as OP-TEE has support for receiving
DTBs from Secure Memory.
Change-Id: I9a873f42e94f2f99a60b638333e7afba1505aec9
Signed-off-by: Javier Almansa Sobrino <javier.almansasobrino@arm.com>
* changes:
SPMD: enable SPM dispatcher support
SPMD: hook SPMD into standard services framework
SPMD: add SPM dispatcher based upon SPCI Beta 0 spec
SPMD: add support to run BL32 in TDRAM and BL31 in secure DRAM on Arm FVP
SPMD: add support for an example SPM core manifest
SPMD: add SPCI Beta 0 specification header file
This patch repurposes the TOS FW configuration file as the manifest for
the SPM core component which will reside at the secure EL adjacent to
EL3. The SPM dispatcher component will use the manifest to determine how
the core component must be initialised. Routines and data structure to
parse the manifest have also been added.
Signed-off-by: Achin Gupta <achin.gupta@arm.com>
Signed-off-by: Artsem Artsemenka <artsem.artsemenka@arm.com>
Change-Id: Id94f8ece43b4e05609f0a1d364708a912f6203cb
Fix code that violates the MISRA rule:
MISRA C-2012 Rule 11.9: Literal "0" shall not be used as
null pointer constant.
The fix explicitly checks whether a pointer is NULL.
Change-Id: Ibc318dc0f464982be9a34783f24ccd1d44800551
Signed-off-by: Zelalem <zelalem.aweke@arm.com>
BL31 used to take a single bl31_params_t parameter structure with entry
point information in arg0. In commit 726002263 (Add new version of image
loading.) this API was changed to a more flexible linked list approach,
and the old parameter structure was copied into all platforms that still
used the old format. This duplicated code unnecessarily among all these
platforms.
This patch adds a helper function that platforms can optionally link to
outsource the task of interpreting arg0. Many platforms are just
interested in the BL32 and BL33 entry point information anyway. Since
some platforms still need to support the old version 1 parameters, the
helper will support both formats when ERROR_DEPRECATED == 0. This allows
those platforms to drop a bunch of boilerplate code and asynchronously
update their BL2 implementation to the newer format.
Change-Id: I9e6475adb1a7d4bccea666118bd1c54962e9fc38
Signed-off-by: Julius Werner <jwerner@chromium.org>
On ARM platforms, the BL2 memory can be overlaid by BL31/BL32. The memory
descriptors describing the list of executable images are created in BL2
R/W memory, which could be possibly corrupted later on by BL31/BL32 due
to overlay. This patch creates a reserved location in SRAM for these
descriptors and are copied over by BL2 before handing over to next BL
image.
Also this patch increases the PLAT_ARM_MAX_BL2_SIZE for juno when TBBR
is enabled.
Fixes ARM-Software/tf-issues#626
Change-Id: I755735706fa702024b4032f51ed4895b3687377f
Signed-off-by: Sathees Balya <sathees.balya@arm.com>
No functional changes.
Change-Id: I9638e02acb9b22eb794ebf45aad84348a710287e
This patch modifies the common utility function
`populate_next_bl_params_config()` to only modify the entrypoint arguments
to an executable image only if they are not initialized earlier.
This issue was detected while testing Optee on ARM platforms which needed
the current arguments to be preserved in the absence of corresponding
config files.
Change-Id: I1e3fb4be8176fc173959e72442396dd33a99a316
Signed-off-by: Amit Daniel Kachhap <amit.kachhap@arm.com>
Signed-off-by: David Cunado <david.cunado@arm.com>
Rule 8.5: An external object or function shall be declared
once in one and only one file.
Fixed for:
make DEBUG=1 PLAT=fvp LOG_LEVEL=50 all
Change-Id: I2420c58134c280db90706cad2d5e7a190f9f9311
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
Change-Id: I1d85b76af002b8b672fcaeca94939b7420bc8243
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
The patch adds the necessary changes to load HW_CONFIG in BL2 for
ARM Platforms :
1. The load address of HW_CONFIG is specified via the `hw_config_addr`
property in TB_FW_CONFIG is loaded by BL1. The `hw_config_max_size`
property defines the maximum size to be expected for the HW_CONFIG.
The `arm_dyn_cfg_helpers.c` and corresponding header implements
utility functions to parse these DT properties defined.
The `arm_dyn_cfg.c` implements wrappers to these helpers to enable
them to be invoked from ARM platform layer.
2. `HW_CONFIG` is added to the `bl2_mem_params_descs[]` array which is
the list of images to be loaded by BL2.
3. The `libfdt` sources are now included when BL2 is built
4. A new helper `populate_next_bl_params_config()` is introduced in
desc_image_load.c to populate the subsequent executable BL images
with the `hw_config` and the corresponding `fw_config` if available.
The `plat_get_next_bl_params()` API for ARM platforms is modified to
invoke this new helper.
5. The implementation of `bl2_early_platform_setup2()` is modified to
consider `arg0` as well in addition to `arg1` passed from BL1.
6. Bump up the BL2 size for Juno to accommodate the inclusion of libfdt.
Change-Id: I80f1554adec41753e0d179a5237364f04fe13a3f
Previously, get_next_bl_params_from_mem_params_desc() populated arg0
in the EL3 runtime entrypoint with a bl_params_t pointer. This is the
responsibility of the generic LOAD_IMAGE_V2 framework instead of the
descriptor-based image loading utility functions. Therefore this patch
moves that code to bl2_load_images().
Also, this patch moves the code that flushes the bl_params structure to
flush_bl_params_desc(), together with the other descriptor-based image
loading flushing code.
Change-Id: I4541e3f50e3878dde7cf89e9e8f31fe0b173fb9d
Signed-off-by: Dan Handley <dan.handley@arm.com>
This patch adds capability to load BL images based on image
descriptors instead of hard coded way of loading BL images.
This framework is designed such that it can be readily adapted
by any BL stage that needs to load images.
In order to provide the above capability the following new
platform functions are introduced:
bl_load_info_t *plat_get_bl_image_load_info(void);
This function returns pointer to the list of images that the
platform has populated to load.
bl_params_t *plat_get_next_bl_params(void);
This function returns a pointer to the shared memory that the
platform has kept aside to pass trusted firmware related
information that next BL image needs.
void plat_flush_next_bl_params(void);
This function flushes to main memory all the params that
are passed to next image.
int bl2_plat_handle_post_image_load(unsigned int image_id)
This function can be used by the platforms to update/use
image information for given `image_id`.
`desc_image_load.c` contains utility functions which can be used
by the platforms to generate, load and executable, image list
based on the registered image descriptors.
This patch also adds new version of `load_image/load_auth_image`
functions in-order to achieve the above capability.
Following are the changes for the new version as compared to old:
- Refactor the signature and only keep image_id and image_info_t
arguments. Removed image_base argument as it is already passed
through image_info_t. Given that the BL image base addresses and
limit/size are already provided by the platforms, the meminfo_t
and entry_point_info arguments are not needed to provide/reserve
the extent of free memory for the given BL image.
- Added check for the image size against the defined max size.
This is needed because the image size could come from an
unauthenticated source (e.g. the FIP header).
To make this check, new member is added to the image_info_t
struct for identifying the image maximum size.
New flag `LOAD_IMAGE_V2` is added in the Makefile.
Default value is 0.
NOTE: `TRUSTED_BOARD_BOOT` is currently not supported when
`LOAD_IMAGE_V2` is enabled.
Change-Id: Ia7b643f4817a170d5a2fbf479b9bc12e63112e79
