Change-Id: Idcd2a35cd2b30d77a7ca031f7e0172814bdb8cab
Signed-off-by: Paul Beesley <paul.beesley@arm.com>
The Secure Partition Manager (SPM) prototype implementation is
being removed. This is preparatory work for putting in place a
dispatcher component that, in turn, enables partition managers
at S-EL2 / S-EL1.
This patch removes:
- The core service files (std_svc/spm)
- The Resource Descriptor headers (include/services)
- SPRT protocol support and service definitions
- SPCI protocol support and service definitions
Change-Id: Iaade6f6422eaf9a71187b1e2a4dffd7fb8766426
Signed-off-by: Artsem Artsemenka <artsem.artsemenka@arm.com>
There are two different implementations of Secure Partition
management in TF-A. One is based on the "Management Mode" (MM)
design, the other is based on the Secure Partition Client Interface
(SPCI) specification. Currently there is a dependency between their
build flags that shouldn't exist, making further development
harder than it should be. This patch removes that
dependency, making the two flags function independently.
Before: ENABLE_SPM=1 is required for using either implementation.
By default, the SPCI-based implementation is enabled and
this is overridden if SPM_MM=1.
After: ENABLE_SPM=1 enables the SPCI-based implementation.
SPM_MM=1 enables the MM-based implementation.
The two build flags are mutually exclusive.
Note that the name of the ENABLE_SPM flag remains a bit
ambiguous - this will be improved in a subsequent patch. For this
patch the intention was to leave the name as-is so that it is
easier to track the changes that were made.
Change-Id: I8e64ee545d811c7000f27e8dc8ebb977d670608a
The 9p interface provides abstraction layers allowing the software
that uses devices to be independent from the hardware.
This patch provides a file system abstraction to link drivers to their
devices and propose a common interface to expose driver operations to
higher layers. This file system can be used to access and configure a
device by doing read/write operations.
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
Signed-off-by: Olivier Deprez <olivier.deprez@arm.com>
Change-Id: Ia9662393baf489855dc0c8f389fe4a0afbc9c255
This patch adds the functionality needed for platforms to provide
Branch Target Identification (BTI) extension, introduced to AArch64
in Armv8.5-A by adding BTI instruction used to mark valid targets
for indirect branches. The patch sets new GP bit [50] to the stage 1
Translation Table Block and Page entries to denote guarded EL3 code
pages which will cause processor to trap instructions in protected
pages trying to perform an indirect branch to any instruction other
than BTI.
BTI feature is selected by BRANCH_PROTECTION option which supersedes
the previous ENABLE_PAUTH used for Armv8.3-A Pointer Authentication
and is disabled by default. Enabling BTI requires compiler support
and was tested with GCC versions 9.0.0, 9.0.1 and 10.0.0.
The assembly macros and helpers are modified to accommodate the BTI
instruction.
This is an experimental feature.
Note. The previous ENABLE_PAUTH build option to enable PAuth in EL3
is now made as an internal flag and BRANCH_PROTECTION flag should be
used instead to enable Pointer Authentication.
Note. USE_LIBROM=1 option is currently not supported.
Change-Id: Ifaf4438609b16647dc79468b70cd1f47a623362e
The size increase after enabling options related to ARMv8.3-PAuth is:
| | text | bss | data | rodata |
| CTX_INCLUDE_PAUTH_REGS = 1 | +192 | +1536 | +0 | +0 |
| | 0.3% | 3.1% | | |
| ENABLE_PAUTH = 1 | +1848 | +1536 | +16 | +0 |
| | 3.3% | 3.1% | 3.1% | |
Results calculated with the following build configuration:
make PLAT=fvp SPD=tspd DEBUG=1 \
SDEI_SUPPORT=1 \
EL3_EXCEPTION_HANDLING=1 \
TSP_NS_INTR_ASYNC_PREEMPT=1 \
CTX_INCLUDE_PAUTH_REGS=1 \
ENABLE_PAUTH=1
Change-Id: I43db7e509a4f39da6599ec2faa690d197573ec1b
Now that setjmp() and longjmp() are compliant with the standard they can
be moved with the other libc files.
Change-Id: Iea3b91c34eb353ace5e171e72f331602d57774d5
This implementation is no longer deprecated.
Change-Id: I68552d0fd5ba9f08fad4345e4657e8e3c5362a36
The SPM implementation based on MM is going to be kept for the
foreseeable future.
Change-Id: I11e96778a4f52a1aa803e7e048d9a7cb24a53954
Acked-by: Sumit Garg <sumit.garg@linaro.org>
The current SPM is a prototype that only supports one secure partition
in EL0. The objective of SPM is to have multiple partitions. The current
MM interface isn't adequate for this, so it is needed to modify heavily
the code to add proper support for it.
However, there are platforms which are already using this (like SGI) and
removing the code would break it. For this reason, the current SPM code
has been duplicated in order to temporarily preserve compatibility. All
new improvements/changes to SPM will be done in the non-deprecated copy,
that may change without notice.
The new build option SPM_DEPRECATED has been introduced to select the SPM
implementation. It defaults to 1, that selects the deprecated SPM.
Change-Id: Ic9f80b53b450e97b4d3f47e4ef4a138ee8d87443
Add a dependency for building EL3 exception handling framework(EHF)
module with the secure partition manager(SPM).
The EHF module is needed for raising the core's running priority
before the core enters the secure partition, and lowering it
subsequently on exit from the secure partition.
Change-Id: Icbe2d0a63f00b46dc593ff3d86b676c9333506c3
Signed-off-by: Sughosh Ganu <sughosh.ganu@arm.com>
AArch64: Enable MPAM for lower ELs
Memory Partitioning And Monitoring is an Armv8.4 feature that enables
various memory system components and resources to define partitions.
Software running at various ELs can then assign themselves to the
desired partition to control their performance aspects.
With this patch, when ENABLE_MPAM_FOR_LOWER_ELS is set to 1, EL3 allows
lower ELs to access their own MPAM registers without trapping to EL3.
This patch however doesn't make use of partitioning in EL3; platform
initialisation code should configure and use partitions in EL3 if
required.
Change-Id: I5a55b6771ccaa0c1cffc05543d2116b60cbbcdcd
Co-authored-by: James Morse <james.morse@arm.com>
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
If the system is in near idle conditions, this erratum could cause a
deadlock or data corruption. This patch applies the workaround that
prevents this.
This DSU erratum affects only the DSUs that contain the ACP interface
and it was fixed in r2p0. The workaround is applied only to the DSUs
that are actually affected.
Link to respective Arm documentation:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.epm138168/index.html
Change-Id: I033213b3077685130fc1e3f4f79c4d15d7483ec9
Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
A new file ea_delegate.S is introduced, and all EA-related functions are
moved into it. This makes runtime_exceptions.S less crowded and reads
better.
No functional changes.
Change-Id: I64b653b3931984cffd420563f8e8d1ba263f329f
SDEI event dispatches currently only sets up the Non-secure context
before returning to the caller. The actual dispatch only happens upon
exiting EL3 next time.
However, for various error handling scenarios, it's beneficial to have
the dispatch happen synchronously. I.e. when receiving SDEI interrupt,
or for a successful sdei_dispatch_event() call, the event handler is
executed; and upon the event completion, dispatcher execution resumes
after the point of dispatch. The jump primitives introduced in the
earlier patch facilitates this feature.
With this patch:
- SDEI interrupts and calls to sdei_dispatch_event prepares the NS
context for event dispatch, then sets a jump point, and immediately
exits EL3. This results in the client handler executing in
Non-secure.
- When the SDEI client completes the dispatched event, the SDEI
dispatcher does a longjmp to the jump pointer created earlier. For
the caller of the sdei_dispatch_event() in particular, this would
appear as if call returned successfully.
The dynamic workaround for CVE_2018_3639 is slightly shifted around as
part of related minor refactoring. It doesn't affect the workaround
functionality.
Documentation updated.
NOTE: This breaks the semantics of the explicit dispatch API, and any
exiting usages should be carefully reviewed.
Change-Id: Ib9c876d27ea2af7fb22de49832e55a0da83da3f9
This patch introduces setjmp() and ongjmp() primitives to enable
standard setjmp/longjmp style execution. Both APIs parameters take a
pointer to struct jmpbuf type, which hosts CPU registers saved/restored
during jump.
As per the standard usage:
- setjmp() return 0 when a jump is setup; and a non-zero value when
returning from jump.
- The caller of setjmp() must not return, or otherwise update stack
pointer since.
Change-Id: I4af1d32e490cfa547979631b762b4cba188d0551
This patch renames symbols and files relating to CVE-2017-5715 to make
it easier to introduce new symbols and files for new CVE mitigations.
Change-Id: I24c23822862ca73648c772885f1690bed043dbc7
Signed-off-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
When querying `SMCCC_ARCH_WORKAROUND_1` through `SMCCC_ARCH_FEATURES`,
return either:
* -1 to indicate the PE on which `SMCCC_ARCH_FEATURES` is called
requires firmware mitigation for CVE-2017-5715 but the mitigation
is not compiled in.
* 0 to indicate that firmware mitigation is required, or
* 1 to indicate that no firmware mitigation is required.
This patch complies with v1.2 of the firmware interfaces
specification (ARM DEN 0070A).
Change-Id: Ibc32d6620efdac6c340758ec502d95554a55f02a
SMCCC v1.1 comes with a relaxed calling convention for AArch64
callers. The caller only needs to save x0-x3 before doing an SMC
call.
This patch adds support for SMCCC_VERSION and SMCCC_ARCH_FEATURES.
Refer to "Firmware Interfaces for mitigating CVE_2017_5715 System
Software on Arm Systems"[0] for more information.
[0] https://developer.arm.com/-/media/developer/pdf/ARM%20DEN%200070A%20Firmware%20interfaces%20for%20mitigating%20CVE-2017-5715_V1.0.pdf
Change-Id: If5b1c55c17d6c5c7cb9c2c3ed355d3a91cdad0a9
AMUv1 support
Add some AMU helper functions to allow configuring, reading and
writing of the Group 0 and Group 1 counters. Documentation for these
helpers will come in a separate patch.
Change-Id: I656e070d2dae830c22414f694aa655341d4e2c40
Invalidate the Branch Target Buffer (BTB) on entry to EL3 by
temporarily dropping into AArch32 Secure-EL1 and executing the
`BPIALL` instruction.
This is achieved by using 3 vector tables. There is the runtime
vector table which is used to handle exceptions and 2 additional
tables which are required to implement this workaround. The
additional tables are `vbar0` and `vbar1`.
The sequence of events for handling a single exception is
as follows:
1) Install vector table `vbar0` which saves the CPU context on entry
to EL3 and sets up the Secure-EL1 context to execute in AArch32 mode
with the MMU disabled and I$ enabled. This is the default vector table.
2) Before doing an ERET into Secure-EL1, switch vbar to point to
another vector table `vbar1`. This is required to restore EL3 state
when returning from the workaround, before proceeding with normal EL3
exception handling.
3) While in Secure-EL1, the `BPIALL` instruction is executed and an
SMC call back to EL3 is performed.
4) On entry to EL3 from Secure-EL1, the saved context from step 1) is
restored. The vbar is switched to point to `vbar0` in preparation to
handle further exceptions. Finally a branch to the runtime vector
table entry is taken to complete the handling of the original
exception.
This workaround is enabled by default on the affected CPUs.
NOTE
There are 4 different stubs in Secure-EL1. Each stub corresponds to
an exception type such as Sync/IRQ/FIQ/SError. Each stub will move a
different value in `R0` before doing an SMC call back into EL3.
Without this piece of information it would not be possible to know
what the original exception type was as we cannot use `ESR_EL3` to
distinguish between IRQs and FIQs.
Change-Id: I90b32d14a3735290b48685d43c70c99daaa4b434
Invalidate the Branch Target Buffer (BTB) on entry to EL3 by disabling
and enabling the MMU. To achieve this without performing any branch
instruction, a per-cpu vbar is installed which executes the workaround
and then branches off to the corresponding vector entry in the main
vector table. A side effect of this change is that the main vbar is
configured before any reset handling. This is to allow the per-cpu
reset function to override the vbar setting.
Change-Id: I97788d38463a5840a410e3cea85ed297a1678265
This patch adds a new build option, ENABLE_SVE_FOR_NS, which when set
to one EL3 will check to see if the Scalable Vector Extension (SVE) is
implemented when entering and exiting the Non-secure world.
If SVE is implemented, EL3 will do the following:
- Entry to Non-secure world: SIMD, FP and SVE functionality is enabled.
- Exit from Non-secure world: SIMD, FP and SVE functionality is
disabled. As SIMD and FP registers are part of the SVE Z-registers
then any use of SIMD / FP functionality would corrupt the SVE
registers.
The build option default is 1. The SVE functionality is only supported
on AArch64 and so the build option is set to zero when the target
archiecture is AArch32.
This build option is not compatible with the CTX_INCLUDE_FPREGS - an
assert will be raised on platforms where SVE is implemented and both
ENABLE_SVE_FOR_NS and CTX_INCLUDE_FPREGS are set to 1.
Also note this change prevents secure world use of FP&SIMD registers on
SVE-enabled platforms. Existing Secure-EL1 Payloads will not work on
such platforms unless ENABLE_SVE_FOR_NS is set to 0.
Additionally, on the first entry into the Non-secure world the SVE
functionality is enabled and the SVE Z-register length is set to the
maximum size allowed by the architecture. This includes the use case
where EL2 is implemented but not used.
Change-Id: Ie2d733ddaba0b9bef1d7c9765503155188fe7dae
Signed-off-by: David Cunado <david.cunado@arm.com>
The `ENABLE_AMU` build option can be used to enable the
architecturally defined AMU counters. At present, there is no support
for the auxiliary counter group.
Change-Id: I7ea0c0a00327f463199d1b0a481f01dadb09d312
Factor out SPE operations in a separate file. Use the publish
subscribe framework to drain the SPE buffers before entering secure
world. Additionally, enable SPE before entering normal world.
A side effect of this change is that the profiling buffers are now
only drained when a transition from normal world to secure world
happens. Previously they were drained also on return from secure
world, which is unnecessary as SPE is not supported in S-EL1.
Change-Id: I17582c689b4b525770dbb6db098b3a0b5777b70a
The implementation currently supports only interrupt-based SDEI events,
and supports all interfaces as defined by SDEI specification version
1.0 [1].
Introduce the build option SDEI_SUPPORT to include SDEI dispatcher in
BL31.
Update user guide and porting guide. SDEI documentation to follow.
[1] http://infocenter.arm.com/help/topic/com.arm.doc.den0054a/ARM_DEN0054A_Software_Delegated_Exception_Interface.pdf
Change-Id: I758b733084e4ea3b27ac77d0259705565842241a
Co-authored-by: Yousuf A <yousuf.sait@arm.com>
EHF is a framework that allows dispatching of EL3 interrupts to their
respective handlers in EL3.
This framework facilitates the firmware-first error handling policy in
which asynchronous exceptions may be routed to EL3. Such exceptions may
be handed over to respective exception handlers. Individual handlers
might further delegate exception handling to lower ELs.
The framework associates the delegated execution to lower ELs with a
priority value. For interrupts, this corresponds to the priorities
programmed in GIC; for other types of exceptions, viz. SErrors or
Synchronous External Aborts, individual dispatchers shall explicitly
associate delegation to a secure priority. In order to prevent lower
priority interrupts from preempting higher priority execution, the
framework provides helpers to control preemption by virtue of
programming Priority Mask register in the interrupt controller.
This commit allows for handling interrupts targeted at EL3. Exception
handlers own interrupts by assigning them a range of secure priorities,
and registering handlers for each priority range it owns.
Support for exception handling in BL31 image is enabled by setting the
build option EL3_EXCEPTION_HANDLING=1.
Documentation to follow.
NOTE: The framework assumes the priority scheme supported by platform
interrupt controller is compliant with that of ARM GIC architecture (v2
or later).
Change-Id: I7224337e4cea47c6ca7d7a4ca22a3716939f7e42
A Secure Partition is a software execution environment instantiated in
S-EL0 that can be used to implement simple management and security
services. Since S-EL0 is an unprivileged exception level, a Secure
Partition relies on privileged firmware e.g. ARM Trusted Firmware to be
granted access to system and processor resources. Essentially, it is a
software sandbox that runs under the control of privileged software in
the Secure World and accesses the following system resources:
- Memory and device regions in the system address map.
- PE system registers.
- A range of asynchronous exceptions e.g. interrupts.
- A range of synchronous exceptions e.g. SMC function identifiers.
A Secure Partition enables privileged firmware to implement only the
absolutely essential secure services in EL3 and instantiate the rest in
a partition. Since the partition executes in S-EL0, its implementation
cannot be overly complex.
The component in ARM Trusted Firmware responsible for managing a Secure
Partition is called the Secure Partition Manager (SPM). The SPM is
responsible for the following:
- Validating and allocating resources requested by a Secure Partition.
- Implementing a well defined interface that is used for initialising a
Secure Partition.
- Implementing a well defined interface that is used by the normal world
and other secure services for accessing the services exported by a
Secure Partition.
- Implementing a well defined interface that is used by a Secure
Partition to fulfil service requests.
- Instantiating the software execution environment required by a Secure
Partition to fulfil a service request.
Change-Id: I6f7862d6bba8732db5b73f54e789d717a35e802f
Co-authored-by: Douglas Raillard <douglas.raillard@arm.com>
Co-authored-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
Co-authored-by: Achin Gupta <achin.gupta@arm.com>
Co-authored-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
These source file definitions should be defined in generic
Makefiles so that all platforms can benefit. Ensure that the
symbols are properly marked as weak so they can be overridden
by platforms.
NOTE: This change is a potential compatibility break for
non-upstream platforms.
Change-Id: I7b892efa9f2d6d216931360dc6c436e1d10cffed
This patch introduces the PSCI Library interface. The major changes
introduced are as follows:
* Earlier BL31 was responsible for Architectural initialization during cold
boot via bl31_arch_setup() whereas PSCI was responsible for the same during
warm boot. This functionality is now consolidated by the PSCI library
and it does Architectural initialization via psci_arch_setup() during both
cold and warm boots.
* Earlier the warm boot entry point was always `psci_entrypoint()`. This was
not flexible enough as a library interface. Now PSCI expects the runtime
firmware to provide the entry point via `psci_setup()`. A new function
`bl31_warm_entrypoint` is introduced in BL31 and the previous
`psci_entrypoint()` is deprecated.
* The `smc_helpers.h` is reorganized to separate the SMC Calling Convention
defines from the Trusted Firmware SMC helpers. The former is now in a new
header file `smcc.h` and the SMC helpers are moved to Architecture specific
header.
* The CPU context is used by PSCI for context initialization and
restoration after power down (PSCI Context). It is also used by BL31 for SMC
handling and context management during Normal-Secure world switch (SMC
Context). The `psci_smc_handler()` interface is redefined to not use SMC
helper macros thus enabling to decouple the PSCI context from EL3 runtime
firmware SMC context. This enables PSCI to be integrated with other runtime
firmware using a different SMC context.
NOTE: With this patch the architectural setup done in `bl31_arch_setup()`
is done as part of `psci_setup()` and hence `bl31_platform_setup()` will be
invoked prior to architectural setup. It is highly unlikely that the platform
setup will depend on architectural setup and cause any failure. Please be
be aware of this change in sequence.
Change-Id: I7f497a08d33be234bbb822c28146250cb20dab73
This patch moves the PSCI services and BL31 frameworks like context
management and per-cpu data into new library components `PSCI` and
`el3_runtime` respectively. This enables PSCI to be built independently from
BL31. A new `psci_lib.mk` makefile is introduced which adds the relevant
PSCI library sources and gets included by `bl31.mk`. Other changes which
are done as part of this patch are:
* The runtime services framework is now moved to the `common/` folder to
enable reuse.
* The `asm_macros.S` and `assert_macros.S` helpers are moved to architecture
specific folder.
* The `plat_psci_common.c` is moved from the `plat/common/aarch64/` folder
to `plat/common` folder. The original file location now has a stub which
just includes the file from new location to maintain platform compatibility.
Most of the changes wouldn't affect platform builds as they just involve
changes to the generic bl1.mk and bl31.mk makefiles.
NOTE: THE `plat_psci_common.c` FILE HAS MOVED LOCATION AND THE STUB FILE AT
THE ORIGINAL LOCATION IS NOW DEPRECATED. PLATFORMS SHOULD MODIFY THEIR
MAKEFILES TO INCLUDE THE FILE FROM THE NEW LOCATION.
Change-Id: I6bd87d5b59424995c6a65ef8076d4fda91ad5e86
This patch adds following optional PSCI STAT functions:
- PSCI_STAT_RESIDENCY: This call returns the amount of time spent
in power_state in microseconds, by the node represented by the
`target_cpu` and the highest level of `power_state`.
- PSCI_STAT_COUNT: This call returns the number of times a
`power_state` has been used by the node represented by the
`target_cpu` and the highest power level of `power_state`.
These APIs provides residency statistics for power states that has
been used by the platform. They are implemented according to v1.0
of the PSCI specification.
By default this optional feature is disabled in the PSCI
implementation. To enable it, set the boolean flag
`ENABLE_PSCI_STAT` to 1. This also sets `ENABLE_PMF` to 1.
Change-Id: Ie62e9d37d6d416ccb1813acd7f616d1ddd3e8aff
This patch adds Performance Measurement Framework(PMF) in the
ARM Trusted Firmware. PMF is implemented as a library and the
SMC interface is provided through ARM SiP service.
The PMF provides capturing, storing, dumping and retrieving the
time-stamps, by enabling the development of services by different
providers, that can be easily integrated into ARM Trusted Firmware.
The PMF capture and retrieval APIs can also do appropriate cache
maintenance operations to the timestamp memory when the caller
indicates so.
`pmf_main.c` consists of core functions that implement service
registration, initialization, storing, dumping and retrieving
the time-stamp.
`pmf_smc.c` consists SMC handling for registered PMF services.
`pmf.h` consists of the macros that can be used by the PMF service
providers to register service and declare time-stamp functions.
`pmf_helpers.h` consists of internal macros that are used by `pmf.h`
By default this feature is disabled in the ARM trusted firmware.
To enable it set the boolean flag `ENABLE_PMF` to 1.
NOTE: The caller is responsible for specifying the appropriate cache
maintenance flags and for acquiring/releasing appropriate locks
before/after capturing/retrieving the time-stamps.
Change-Id: Ib45219ac07c2a81b9726ef6bd9c190cc55e81854
Change-Id: I6f49bd779f2a4d577c6443dd160290656cdbc59b
This patch removes the dash character from the image name, to
follow the image terminology in the Trusted Firmware Wiki page:
https://github.com/ARM-software/arm-trusted-firmware/wiki
Changes apply to output messages, comments and documentation.
non-ARM platform files have been left unmodified.
Change-Id: Ic2a99be4ed929d52afbeb27ac765ceffce46ed76
The upcoming Firmware Update feature needs transitioning across
Secure/Normal worlds to complete the FWU process and hence requires
context management code to perform this task.
Currently context management code is part of BL31 stage only.
This patch moves the code from (include)/bl31 to (include)/common.
Some function declarations/definitions and macros have also moved
to different files to help code sharing.
Change-Id: I3858b08aecdb76d390765ab2b099f457873f7b0c
The IMF_READ_INTERRUPT_ID build option enables a feature where the interrupt
ID of the highest priority pending interrupt is passed as a parameter to the
interrupt handler registered for that type of interrupt. This additional read
of highest pending interrupt id from GIC is problematic as it is possible that
the original interrupt may get deasserted and another interrupt of different
type maybe become the highest pending interrupt. Hence it is safer to prevent
such behaviour by removing the IMF_READ_INTERRUPT_ID build option.
The `id` parameter of the interrupt handler `interrupt_type_handler_t` is
now made a reserved parameter with this patch. It will always contain
INTR_ID_UNAVAILABLE.
Fixes ARM-software/tf-issues#307
Change-Id: I2173aae1dd37edad7ba6bdfb1a99868635fa34de
This commit does the switch to the new PSCI framework implementation replacing
the existing files in PSCI folder with the ones in PSCI1.0 folder. The
corresponding makefiles are modified as required for the new implementation.
The platform.h header file is also is switched to the new one
as required by the new frameworks. The build flag ENABLE_PLAT_COMPAT defaults
to 1 to enable compatibility layer which let the existing platform ports to
continue to build and run with minimal changes.
The default weak implementation of platform_get_core_pos() is now removed from
platform_helpers.S and is provided by the compatibility layer.
Note: The Secure Payloads and their dispatchers still use the old platform
and framework APIs and hence it is expected that the ENABLE_PLAT_COMPAT build
flag will remain enabled in subsequent patch. The compatibility for SPDs using
the older APIs on platforms migrated to the new APIs will be added in the
following patch.
Change-Id: I18c51b3a085b564aa05fdd98d11c9f3335712719
This patch moves the bakery locks out of coherent memory to normal memory.
This implies that the lock information needs to be placed on a separate cache
line for each cpu. Hence the bakery_lock_info_t structure is allocated in the
per-cpu data so as to minimize memory wastage. A similar platform per-cpu
data is introduced for the platform locks.
As a result of the above changes, the bakery lock api is completely changed.
Earlier, a reference to the lock structure was passed to the lock implementation.
Now a unique-id (essentially an index into the per-cpu data array) and an offset
into the per-cpu data for bakery_info_t needs to be passed to the lock
implementation.
Change-Id: I1e76216277448713c6c98b4c2de4fb54198b39e0
This patch introduces a framework which will allow CPUs to perform
implementation defined actions after a CPU reset, during a CPU or cluster power
down, and when a crash occurs. CPU specific reset handlers have been implemented
in this patch. Other handlers will be implemented in subsequent patches.
Also moved cpu_helpers.S to the new directory lib/cpus/aarch64/.
Change-Id: I1ca1bade4d101d11a898fb30fea2669f9b37b956
This patch adds support for SYSTEM_OFF and SYSTEM_RESET PSCI
operations. A platform should export handlers to complete the
requested operation. The FVP port exports fvp_system_off() and
fvp_system_reset() as an example.
If the SPD provides a power management hook for system off and
system reset, then the SPD is notified about the corresponding
operation so it can do some bookkeeping. The TSPD exports
tspd_system_off() and tspd_system_reset() for that purpose.
Versatile Express shutdown and reset methods have been removed
from the FDT as new PSCI sys_poweroff and sys_reset services
have been added. For those kernels that do not support yet these
PSCI services (i.e. GICv3 kernel), the original dtsi files have
been renamed to *-no_psci.dtsi.
Fixes ARM-software/tf-issues#218
Change-Id: Ic8a3bf801db979099ab7029162af041c4e8330c8
This patch uses stacks allocated in normal memory to enable the MMU early in the
warm boot path thus removing the dependency on stacks allocated in coherent
memory. Necessary cache and stack maintenance is performed when a cpu is being
powered down and up. This avoids any coherency issues that can arise from
reading speculatively fetched stale stack memory from another CPUs cache. These
changes affect the warm boot path in both BL3-1 and BL3-2.
The EL3 system registers responsible for preserving the MMU state are not saved
and restored any longer. Static values are used to program these system
registers when a cpu is powered on or resumed from suspend.
Change-Id: I8357e2eb5eb6c5f448492c5094b82b8927603784
The crash reporting support and early initialisation of the
cpu_data allow the runtime_exception vectors to be used from
the start in BL3-1, removing the need for the additional
early_exception vectors and 2KB of code from BL3-1.
Change-Id: I5f8997dabbaafd8935a7455910b7db174a25d871
This patch prepares the per-cpu pointer cache for wider use by:
* renaming the structure to cpu_data and placing in new header
* providing accessors for this CPU, or other CPUs
* splitting the initialization of the TPIDR pointer from the
initialization of the cpu_data content
* moving the crash stack initialization to a crash stack function
* setting the TPIDR pointer very early during boot
Change-Id: Icef9004ff88f8eb241d48c14be3158087d7e49a3
This patch makes the console crash dump of processor register
state optional based on the CRASH_REPORTING make variable.
This defaults to only being enabled for DEBUG builds. This can
be overridden by setting a different value in the platform
makefile or on the make command line.
Change-Id: Icfa1b2d7ff0145cf0a85e8ad732f9cee7e7e993f
This patch adds a common handler for FIQ and IRQ exceptions in the
BL3-1 runtime exception vector table. This function determines the
interrupt type and calls its handler. A crash is reported if an
inconsistency in the interrupt management framework is detected. In
the event of a spurious interrupt, execution resumes from the
instruction where the interrupt was generated.
This patch also removes 'cm_macros.S' as its contents have been moved
to 'runtime_exceptions.S'
Change-Id: I3c85ecf8eaf43a3fac429b119ed0bd706d2e2093
This patch introduces a framework for registering interrupts routed to
EL3. The interrupt routing model is governed by the SCR_EL3.IRQ and
FIQ bits and the security state an interrupt is generated in. The
framework recognizes three type of interrupts depending upon which
exception level and security state they should be handled in
i.e. Secure EL1 interrupts, Non-secure interrupts and EL3
interrupts. It provides an API and macros that allow a runtime service
to register an handler for a type of interrupt and specify the routing
model. The framework validates the routing model and uses the context
management framework to ensure that it is applied to the SCR_EL3 prior
to entry into the target security state. It saves the handler in
internal data structures. An API is provided to retrieve the handler
when an interrupt of a particular type is asserted. Registration is
expected to be done once by the primary CPU. The same handler and
routing model is used for all CPUs.
Support for EL3 interrupts will be added to the framework in the
future. A makefile flag has been added to allow the FVP port choose
between ARM GIC v2 and v3 support in EL3. The latter version is
currently unsupported.
A framework for handling interrupts in BL3-1 will be introduced in
subsequent patches. The default routing model in the absence of any
handlers expects no interrupts to be routed to EL3.
Change-Id: Idf7c023b34fcd4800a5980f2bef85e4b5c29e649
