* changes:
chore(rme): add make rule for SPD=spmd
chore(bl1): remove redundant bl1_arch_next_el_setup
chore(docs): remove control register setup section
chore(pauth): remove redundant pauth_disable_el3() call
Reading back a RES0 bit does not necessarily mean it will be read as 0.
The Arm ARM explicitly warns against doing this. The PMU initialisation
code tries to set such bits to 1 (in MDCR_EL3) regardless of whether
they are in use or are RES0, checking their value could be wrong and
PMCR_EL0 might not end up being saved.
Save PMCR_EL0 unconditionally to prevent this. Remove the security state
change as the outgoing state is not relevant to what the root world
context should look like.
Signed-off-by: Boyan Karatotev <boyan.karatotev@arm.com>
Change-Id: Id43667d37b0e2da3ded0beaf23fa0d4f9013f470
bl1_arch_next_el_setup has no references anywhere in TF-A. Remove it as
it is redundant
Change-Id: Ice2997f33c318390883347acdd03dc6755f87ea5
In the next patch we add an extra step of setting the PSTATE
registers to a known state on el3 entry. In this patch we create
the function prepare_el3_entry to wrap the steps needed for before
el3 entry. For now this is only save_gp_pmcr_pauth_regs.
Change-Id: Ie26dc8d89bfaec308769165d2649e84d41be196c
Signed-off-by: Daniel Boulby <daniel.boulby@arm.com>
This patch enables BL2 to run in root world (EL3) which is
needed as per the security model of RME-enabled systems.
Using the existing BL2_AT_EL3 TF-A build option is not convenient
because that option assumes TF-A BL1 doesn't exist, which is not
the case for RME-enabled systems. For the purposes of RME, we use
a normal BL1 image but we also want to run BL2 in EL3 as normally as
possible, therefore rather than use the special bl2_entrypoint
function in bl2_el3_entrypoint.S, we use a new bl2_entrypoint
function (in bl2_rme_entrypoint.S) which doesn't need reset or
mailbox initialization code seen in the el3_entrypoint_common macro.
The patch also cleans up bl2_el3_entrypoint.S, moving the
bl2_run_next_image function to its own file to avoid duplicating
code.
Signed-off-by: Zelalem Aweke <zelalem.aweke@arm.com>
Change-Id: I99821b4cd550cadcb701f4c0c4dc36da81c7ef55
Usually, C has no problem up-converting types to larger bit sizes. MISRA
rule 10.7 requires that you not do this, or be very explicit about this.
This resolves the following required rule:
bl1/aarch64/bl1_context_mgmt.c:81:[MISRA C-2012 Rule 10.7 (required)]<None>
The width of the composite expression "0U | ((mode & 3U) << 2U) | 1U |
0x3c0U" (32 bits) is less that the right hand operand
"18446744073709547519ULL" (64 bits).
This also resolves MISRA defects such as:
bl2/aarch64/bl2arch_setup.c:18:[MISRA C-2012 Rule 12.2 (required)]
In the expression "3U << 20", shifting more than 7 bits, the number
of bits in the essential type of the left expression, "3U", is
not allowed.
Further, MISRA requires that all shifts don't overflow. The definition of
PAGE_SIZE was (1U << 12), and 1U is 8 bits. This caused about 50 issues.
This fixes the violation by changing the definition to 1UL << 12. Since
this uses 32bits, it should not create any issues for aarch32.
This patch also contains a fix for a build failure in the sun50i_a64
platform. Specifically, these misra fixes removed a single and
instruction,
92407e73 and x19, x19, #0xffffffff
from the cm_setup_context function caused a relocation in
psci_cpus_on_start to require a linker-generated stub. This increased the
size of the .text section and caused an alignment later on to go over a
page boundary and round up to the end of RAM before placing the .data
section. This sectionn is of non-zero size and therefore causes a link
error.
The fix included in this reorders the functions during link time
without changing their ording with respect to alignment.
Change-Id: I76b4b662c3d262296728a8b9aab7a33b02087f16
Signed-off-by: Jimmy Brisson <jimmy.brisson@arm.com>
This reduces the scope of these variables and resolves Misra violations
such as:
bl1/aarch64/bl1_context_mgmt.c:21:[MISRA C-2012 Rule 8.9 (advisory)]
"bl1_cpu_context" should be defined at block scope.
Change-Id: I9b0b26395bce07e10e61d10158c67f9c22ecce44
Attempts to address MISRA compliance issues in BL1, BL2, and BL31 code.
Mainly issues like not using boolean expressions in conditionals,
conflicting variable names, ignoring return values without (void), adding
explicit casts, etc.
Change-Id: If1fa18ab621b9c374db73fa6eaa6f6e5e55c146a
Signed-off-by: John Powell <john.powell@arm.com>
Fix code that violates the MISRA rule:
MISRA C-2012 Rule 11.9: Literal "0" shall not be used as
null pointer constant.
The fix explicitly checks whether a pointer is NULL.
Change-Id: Ibc318dc0f464982be9a34783f24ccd1d44800551
Signed-off-by: Zelalem <zelalem.aweke@arm.com>
Even though ERET always causes a jump to another address, aarch64 CPUs
speculatively execute following instructions as if the ERET
instruction was not a jump instruction.
The speculative execution does not cross privilege-levels (to the jump
target as one would expect), but it continues on the kernel privilege
level as if the ERET instruction did not change the control flow -
thus execution anything that is accidentally linked after the ERET
instruction. Later, the results of this speculative execution are
always architecturally discarded, however they can leak data using
microarchitectural side channels. This speculative execution is very
reliable (seems to be unconditional) and it manages to complete even
relatively performance-heavy operations (e.g. multiple dependent
fetches from uncached memory).
This was fixed in Linux, FreeBSD, OpenBSD and Optee OS:
https://github.com/torvalds/linux/commit/679db70801da9fda91d26caf13bf5b5ccc74e8e8
https://github.com/freebsd/freebsd/commit/29fb48ace4186a41c409fde52bcf4216e9e50b61
https://github.com/openbsd/src/commit/3a08873ece1cb28ace89fd65e8f3c1375cc98de2
https://github.com/OP-TEE/optee_os/commit/abfd092aa19f9c0251e3d5551e2d68a9ebcfec8a
It is demonstrated in a SafeSide example:
https://github.com/google/safeside/blob/master/demos/eret_hvc_smc_wrapper.cc
https://github.com/google/safeside/blob/master/kernel_modules/kmod_eret_hvc_smc/eret_hvc_smc_module.c
Signed-off-by: Anthony Steinhauser <asteinhauser@google.com>
Change-Id: Iead39b0b9fb4b8d8b5609daaa8be81497ba63a0f
When a Firmware is complied as Position Independent Executable it needs
to request GDT fixup by passing size of the memory region to
The Global descriptor table fixup will be done early on during cold boot
process of primary core.
Currently only BL31 supports PIE, but in future when BL2_AT_EL3 will be
compiled as PIE, it can simply pass fixup size to the common el3
entrypoint macro to fixup GDT.
The reason for this patch was to overcome the bug introduced by SHA
330ead806 which called fixup routine for each core causing
re-initializing of global pointers thus overwriting any changes
done by the previous core.
Change-Id: I55c792cc3ea9e7eef34c2e4653afd04572c4f055
Signed-off-by: Manish Pandey <manish.pandey2@arm.com>
This patch adds support for ARMv8.3-PAuth in BL1 SMC calls and
BL2U image for firmware updates by programming APIAKey_EL1 registers
and enabling Pointer Authentication in EL3 and EL1 respectively.
Change-Id: I875d952aba8242caf74fb5f4f2d2af6f0c768c08
* changes:
Unsigned long should not be used as per coding guidelines
SCTLR and ACTLR are 32-bit for AArch32 and 64-bit for AArch64
We should either change them to `unsigned int` or `unsigned long long`
when the size of the variable is the same in AArch64 and AArch32 or
to `u_register_t` if it is supposed to be 32 bit wide in AArch32
and 64 bit wide in AArch64.
Signed-off-by: Deepika Bhavnani <deepika.bhavnani@arm.com>
Change-Id: I80e2a6edb33248ee88be395829abbd4c36c89abe
This patch provides the following features and makes modifications
listed below:
- Individual APIAKey key generation for each CPU.
- New key generation on every BL31 warm boot and TSP CPU On event.
- Per-CPU storage of APIAKey added in percpu_data[]
of cpu_data structure.
- `plat_init_apiakey()` function replaced with `plat_init_apkey()`
which returns 128-bit value and uses Generic timer physical counter
value to increase the randomness of the generated key.
The new function can be used for generation of all ARMv8.3-PAuth keys
- ARMv8.3-PAuth specific code placed in `lib\extensions\pauth`.
- New `pauth_init_enable_el1()` and `pauth_init_enable_el3()` functions
generate, program and enable APIAKey_EL1 for EL1 and EL3 respectively;
pauth_disable_el1()` and `pauth_disable_el3()` functions disable
PAuth for EL1 and EL3 respectively;
`pauth_load_bl31_apiakey()` loads saved per-CPU APIAKey_EL1 from
cpu-data structure.
- Combined `save_gp_pauth_registers()` function replaces calls to
`save_gp_registers()` and `pauth_context_save()`;
`restore_gp_pauth_registers()` replaces `pauth_context_restore()`
and `restore_gp_registers()` calls.
- `restore_gp_registers_eret()` function removed with corresponding
code placed in `el3_exit()`.
- Fixed the issue when `pauth_t pauth_ctx` structure allocated space
for 12 uint64_t PAuth registers instead of 10 by removal of macro
CTX_PACGAKEY_END from `include/lib/el3_runtime/aarch64/context.h`
and assigning its value to CTX_PAUTH_REGS_END.
- Use of MODE_SP_ELX and MODE_SP_EL0 macro definitions
in `msr spsel` instruction instead of hard-coded values.
- Changes in documentation related to ARMv8.3-PAuth and ARMv8.5-BTI.
Change-Id: Id18b81cc46f52a783a7e6a09b9f149b6ce803211
This patch fixes an issue when secure world timing information
can be leaked because Secure Cycle Counter is not disabled.
For ARMv8.5 the counter gets disabled by setting MDCR_El3.SCCD
bit on CPU cold/warm boot.
For the earlier architectures PMCR_EL0 register is saved/restored
on secure world entry/exit from/to Non-secure state, and cycle
counting gets disabled by setting PMCR_EL0.DP bit.
'include\aarch64\arch.h' header file was tided up and new
ARMv8.5-PMU related definitions were added.
Change-Id: I6f56db6bc77504634a352388990ad925a69ebbfa
Change-Id: Ic3b30de13e314efca30fc71370227d3e76f1148b
Signed-off-by: John Tsichritzis <john.tsichritzis@arm.com>
The size increase after enabling options related to ARMv8.3-PAuth is:
| | text | bss | data | rodata |
| CTX_INCLUDE_PAUTH_REGS = 1 | +108 | +192 | +0 | +0 |
| | 0.5% | 0.8% | | |
| ENABLE_PAUTH = 1 | +748 | +192 | +16 | +0 |
| | 3.7% | 0.8% | 7.0% | |
Results calculated with the following build configuration:
make PLAT=fvp SPD=tspd DEBUG=1 \
SDEI_SUPPORT=1 \
EL3_EXCEPTION_HANDLING=1 \
TSP_NS_INTR_ASYNC_PREEMPT=1 \
CTX_INCLUDE_PAUTH_REGS=1 \
ENABLE_PAUTH=1
Change-Id: I3a7d02feb6a6d212be32a01432b0c7c1a261f567
The macro EL_IMPLEMENTED() has been deprecated in favour of the new
function el_implemented().
Change-Id: Ic9b1b81480b5e019b50a050e8c1a199991bf0ca9
Check_vector_size checks if the size of the vector fits
in the size reserved for it. This check creates problems in
the Clang assembler. A new macro, end_vector_entry, is added
and check_vector_size is deprecated.
This new macro fills the current exception vector until the next
exception vector. If the size of the current vector is bigger
than 32 instructions then it gives an error.
Change-Id: Ie8545cf1003a1e31656a1018dd6b4c28a4eaf671
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
When the source code says 'SMCC' it is talking about the SMC Calling
Convention. The correct acronym is SMCCC. This affects a few definitions
and file names.
Some files have been renamed (smcc.h, smcc_helpers.h and smcc_macros.S)
but the old files have been kept for compatibility, they include the
new ones with an ERROR_DEPRECATED guard.
Change-Id: I78f94052a502436fdd97ca32c0fe86bd58173f2f
After executing a TLBI a DSB is needed to ensure completion of the
TLBI.
rk3328: The MMU is allowed to load TLB entries for as long as it is
enabled. Because of this, the correct place to execute a TLBI is right
after disabling the MMU.
Change-Id: I8280f248d10b49a8c354a4ccbdc8f8345ac4c170
This fix modifies the order of system includes to meet the ARM TF coding
standard. There are some exceptions in order to retain header groupings,
minimise changes to imported headers, and where there are headers within
the #if and #ifndef statements.
Change-Id: I65085a142ba6a83792b26efb47df1329153f1624
Signed-off-by: Isla Mitchell <isla.mitchell@arm.com>
Minor build fixes
This change avoids warnings when setting -Wmissing-prototypes or when
using sparse tool.
Signed-off-by: Yann Gautier <yann.gautier@st.com>
Signed-off-by: Etienne Carriere <etienne.carriere@st.com>
This patch updates the el3_arch_init_common macro so that it fully
initialises essential control registers rather then relying on hardware
to set the reset values.
The context management functions are also updated to fully initialise
the appropriate control registers when initialising the non-secure and
secure context structures and when preparing to leave EL3 for a lower
EL.
This gives better alignement with the ARM ARM which states that software
must initialise RES0 and RES1 fields with 0 / 1.
This patch also corrects the following typos:
"NASCR definitions" -> "NSACR definitions"
Change-Id: Ia8940b8351dc27bc09e2138b011e249655041cfc
Signed-off-by: David Cunado <david.cunado@arm.com>
Execution state switch
Replace all instances of checks with the new macro.
Change-Id: I0eec39b9376475a1a9707a3115de9d36f88f8a2a
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
There are many instances in ARM Trusted Firmware where control is
transferred to functions from which return isn't expected. Such jumps
are made using 'bl' instruction to provide the callee with the location
from which it was jumped to. Additionally, debuggers infer the caller by
examining where 'lr' register points to. If a 'bl' of the nature
described above falls at the end of an assembly function, 'lr' will be
left pointing to a location outside of the function range. This misleads
the debugger back trace.
This patch defines a 'no_ret' macro to be used when jumping to functions
from which return isn't expected. The macro ensures to use 'bl'
instruction for the jump, and also, for debug builds, places a 'nop'
instruction immediately thereafter (unless instructed otherwise) so as
to leave 'lr' pointing within the function range.
Change-Id: Ib34c69fc09197cfd57bc06e147cc8252910e01b0
Co-authored-by: Douglas Raillard <douglas.raillard@arm.com>
This patch adds generic changes in BL1 to support AArch32 state.
New AArch32 specific assembly/C files are introduced and
some files are moved to AArch32/64 specific folders.
BL1 for AArch64 is refactored but functionally identical.
BL1 executes in Secure Monitor mode in AArch32 state.
NOTE: BL1 in AArch32 state ONLY handles BL1_RUN_IMAGE SMC.
Change-Id: I6e2296374c7efbf3cf2aa1a0ce8de0732d8c98a5
This patch removes the tight loop that calls `plat_report_exception`
in unhandled exceptions in AArch64 state.
The new behaviour is to call the `plat_report_exception` only
once followed by call to `plat_panic_handler`.
This allows platforms to take platform-specific action when
there is an unhandled exception, instead of always spinning
in a tight loop.
Note: This is a subtle break in behaviour for platforms that
expect `plat_report_exception` to be continuously executed
when there is an unhandled exception.
Change-Id: Ie2453804b9b7caf9b010ee73e1a90eeb8384e4e8
This patch introduces some assembler macros to simplify the
declaration of the exception vectors. It abstracts the section
the exception code is put into as well as the alignments
constraints mandated by the ARMv8 architecture. For all TF images,
the exception code has been updated to make use of these macros.
This patch also updates some invalid comments in the exception
vector code.
Change-Id: I35737b8f1c8c24b6da89b0a954c8152a4096fa95
Asynchronous abort exceptions generated by the platform during cold boot are
not taken in EL3 unless SCR_EL3.EA is set.
Therefore EA bit is set along with RES1 bits in early BL1 and BL31 architecture
initialisation. Further write accesses to SCR_EL3 preserve these bits during
cold boot.
A build flag controls SCR_EL3.EA value to keep asynchronous abort exceptions
being trapped by EL3 after cold boot or not.
For further reference SError Interrupts are also known as asynchronous external
aborts.
On Cortex-A53 revisions below r0p2, asynchronous abort exceptions are taken in
EL3 whatever the SCR_EL3.EA value is.
Fixes arm-software/tf-issues#368
Signed-off-by: Gerald Lejeune <gerald.lejeune@st.com>
Firmware update(a.k.a FWU) feature is part of the TBB architecture.
BL1 is responsible for carrying out the FWU process if platform
specific code detects that it is needed.
This patch adds support for FWU feature support in BL1 which is
included by enabling `TRUSTED_BOARD_BOOT` compile time flag.
This patch adds bl1_fwu.c which contains all the core operations
of FWU, which are; SMC handler, image copy, authentication, execution
and resumption. It also adds bl1.h introducing #defines for all
BL1 SMCs.
Following platform porting functions are introduced:
int bl1_plat_mem_check(uintptr_t mem_base, unsigned int mem_size,
unsigned int flags);
This function can be used to add platform specific memory checks
for the provided base/size for the given security state.
The weak definition will invoke `assert()` and return -ENOMEM.
__dead2 void bl1_plat_fwu_done(void *cookie, void *reserved);
This function can be used to initiate platform specific procedure
to mark completion of the FWU process.
The weak definition waits forever calling `wfi()`.
plat_bl1_common.c contains weak definitions for above functions.
FWU process starts when platform detects it and return the image_id
other than BL2_IMAGE_ID by using `bl1_plat_get_next_image_id()` in
`bl1_main()`.
NOTE: User MUST provide platform specific real definition for
bl1_plat_mem_check() in order to use it for Firmware update.
Change-Id: Ice189a0885d9722d9e1dd03f76cac1aceb0e25ed
As of now BL1 loads and execute BL2 based on hard coded information
provided in BL1. But due to addition of support for upcoming Firmware
Update feature, BL1 now require more flexible approach to load and
run different images using information provided by the platform.
This patch adds new mechanism to load and execute images based on
platform provided image id's. BL1 now queries the platform to fetch
the image id of the next image to be loaded and executed. In order
to achieve this, a new struct image_desc_t was added which holds the
information about images, such as: ep_info and image_info.
This patch introduces following platform porting functions:
unsigned int bl1_plat_get_next_image_id(void);
This is used to identify the next image to be loaded
and executed by BL1.
struct image_desc *bl1_plat_get_image_desc(unsigned int image_id);
This is used to retrieve the image_desc for given image_id.
void bl1_plat_set_ep_info(unsigned int image_id,
struct entry_point_info *ep_info);
This function allows platforms to update ep_info for given
image_id.
The plat_bl1_common.c file provides default weak implementations of
all above functions, the `bl1_plat_get_image_desc()` always return
BL2 image descriptor, the `bl1_plat_get_next_image_id()` always return
BL2 image ID and `bl1_plat_set_ep_info()` is empty and just returns.
These functions gets compiled into all BL1 platforms by default.
Platform setup in BL1, using `bl1_platform_setup()`, is now done
_after_ the initialization of authentication module. This change
provides the opportunity to use authentication while doing the
platform setup in BL1.
In order to store secure/non-secure context, BL31 uses percpu_data[]
to store context pointer for each core. In case of BL1 only the
primary CPU will be active hence percpu_data[] is not required to
store the context pointer.
This patch introduce bl1_cpu_context[] and bl1_cpu_context_ptr[] to
store the context and context pointers respectively. It also also
re-defines cm_get_context() and cm_set_context() for BL1 in
bl1/bl1_context_mgmt.c.
BL1 now follows the BL31 pattern of using SP_EL0 for the C runtime
environment, to support resuming execution from a previously saved
context.
NOTE: THE `bl1_plat_set_bl2_ep_info()` PLATFORM PORTING FUNCTION IS
NO LONGER CALLED BY BL1 COMMON CODE. PLATFORMS THAT OVERRIDE
THIS FUNCTION MAY NEED TO IMPLEMENT `bl1_plat_set_ep_info()`
INSTEAD TO MAINTAIN EXISTING BEHAVIOUR.
Change-Id: Ieee4c124b951c2e9bc1c1013fa2073221195d881
The upcoming Firmware Update feature needs transitioning across
Secure/Normal worlds to complete the FWU process and hence requires
context management code to perform this task.
Currently context management code is part of BL31 stage only.
This patch moves the code from (include)/bl31 to (include)/common.
Some function declarations/definitions and macros have also moved
to different files to help code sharing.
Change-Id: I3858b08aecdb76d390765ab2b099f457873f7b0c
This patch introduces a new build option named COLD_BOOT_SINGLE_CPU,
which allows platforms that only release a single CPU out of reset to
slightly optimise their cold boot code, both in terms of code size
and performance.
COLD_BOOT_SINGLE_CPU defaults to 0, which assumes that the platform
may release several CPUs out of reset. In this case, the cold reset
code needs to coordinate all CPUs via the usual primary/secondary
CPU distinction.
If a platform guarantees that only a single CPU will ever be released
out of reset, there is no need to arbitrate execution ; the notion of
primary and secondary CPUs itself no longer exists. Such platforms
may set COLD_BOOT_SINGLE_CPU to 1 in order to compile out the
primary/secondary CPU identification in the cold reset code.
All ARM standard platforms can release several CPUs out of reset
so they use COLD_BOOT_SINGLE_CPU=0. However, on CSS platforms like
Juno, bringing up more than one CPU at reset should only be attempted
when booting an EL3 payload, as it is not fully supported in the
normal boot flow.
For platforms using COLD_BOOT_SINGLE_CPU=1, the following 2 platform
APIs become optional:
- plat_secondary_cold_boot_setup();
- plat_is_my_cpu_primary().
The Porting Guide has been updated to reflect that.
User Guide updated as well.
Change-Id: Ic5b474e61b7aec1377d1e0b6925d17dfc376c46b
This patch modifies the prototype of the bl1_plat_prepare_exit()
platform API to pass the address of the entry point info structure
received from BL2. The structure contains information that can be
useful, depending on the kind of clean up or bookkeeping operations
to perform.
The weak implementation of this function ignores this argument to
preserve platform backwards compatibility.
NOTE: THIS PATCH MAY BREAK PLATFORM PORTS THAT ARE RELYING ON THE
FORMER PROTOTYPE OF THE BL1_PLAT_PREPARE_EXIT() API.
Change-Id: I3fc18f637de06c85719c4ee84c85d6a4572a0fdb
This patch introduces a new build flag, SPIN_ON_BL1_EXIT, which
puts an infinite loop in BL1. It is intended to help debugging
the post-BL2 phase of the Trusted Firmware by stopping execution
in BL1 just before handing over to BL31. At this point, the
developer may take control of the target using a debugger.
This feature is disabled by default and can be enabled by
rebuilding BL1 with SPIN_ON_BL1_EXIT=1.
User Guide updated accordingly.
Change-Id: I6b6779d5949c9e5571dd371255520ef1ac39685c
- Remove out-dated information about the use of printf() in the
function comment.
- Make the argument const, as the function doesn't need to modify it.
- Rename the function into bl1_print_bl31_ep_info() to make its
purpose clearer.
Change-Id: I2a9d215a37f0ec11aefce0c5c9e050473b7a6b25
This patch adds an optional API to the platform port:
void bl1_plat_prepare_exit(void);
This function is called prior to exiting BL1 in response to the
RUN_IMAGE_SMC request raised by BL2. It should be used to perform
platform specific clean up or bookkeeping operations before
transferring control to the next image.
A weak empty definition of this function has been provided to
Change-Id: Iec09697de5c449ae84601403795cdb6aca166ba1
The AArch64 synchronous exception vector code in BL1 is almost
reaching its architectural limit of 32 instructions. This means
there is very little space for this code to grow.
This patch reduces the size of the exception vector code by
moving most of its code in a function to which we branch from
SynchronousExceptionA64.
Change-Id: Ib35351767a685fb2c2398029d32e54026194f7ed
This patch introduces a new platform build option, called
PROGRAMMABLE_RESET_ADDRESS, which tells whether the platform has
a programmable or fixed reset vector address.
If the reset vector address is fixed then the code relies on the
platform_get_entrypoint() mailbox mechanism to figure out where
it is supposed to jump. On the other hand, if it is programmable
then it is assumed that the platform code will program directly
the right address into the RVBAR register (instead of using the
mailbox redirection) so the mailbox is ignored in this case.
Change-Id: If59c3b11fb1f692976e1d8b96c7e2da0ebfba308
The attempt to run the CPU reset code as soon as possible after reset
results in highly complex conditional code relating to the
RESET_TO_BL31 option.
This patch relaxes this requirement a little. In the BL1, BL3-1 and
PSCI entrypoints code, the sequence of operations is now as follows:
1) Detect whether it is a cold or warm boot;
2) For cold boot, detect whether it is the primary or a secondary
CPU. This is needed to handle multiple CPUs entering cold reset
simultaneously;
3) Run the CPU init code.
This patch also abstracts the EL3 registers initialisation done by
the BL1, BL3-1 and PSCI entrypoints into common code.
This improves code re-use and consolidates the code flows for
different types of systems.
NOTE: THE FUNCTION plat_secondary_cold_boot() IS NOW EXPECTED TO
NEVER RETURN. THIS PATCH FORCES PLATFORM PORTS THAT RELIED ON THE
FORMER RETRY LOOP AT THE CALL SITE TO MODIFY THEIR IMPLEMENTATION.
OTHERWISE, SECONDARY CPUS WILL PANIC.
Change-Id: If5ecd74d75bee700b1bd718d23d7556b8f863546
In order for the symbol table in the ELF file to contain the size of
functions written in assembly, it is necessary to report it to the
assembler using the .size directive.
To fulfil the above requirements, this patch introduces an 'endfunc'
macro which contains the .endfunc and .size directives. It also adds
a .func directive to the 'func' assembler macro.
The .func/.endfunc have been used so the assembler can fail if
endfunc is omitted.
Fixes ARM-Software/tf-issues#295
Change-Id: If8cb331b03d7f38fe7e3694d4de26f1075b278fc
Signed-off-by: Kévin Petit <kevin.petit@arm.com>
This patch extends the build option `USE_COHERENT_MEMORY` to
conditionally remove coherent memory from the memory maps of
all boot loader stages. The patch also adds necessary
documentation for coherent memory removal in firmware-design,
porting and user guides.
Fixes ARM-Software/tf-issues#106
Change-Id: I260e8768c6a5c2efc402f5804a80657d8ce38773
This patch gathers miscellaneous minor fixes to the documentation, and comments
in the source code.
Change-Id: I631e3dda5abafa2d90f464edaee069a1e58b751b
Co-Authored-By: Soby Mathew <soby.mathew@arm.com>
Co-Authored-By: Dan Handley <dan.handley@arm.com>
This patch introduces a framework which will allow CPUs to perform
implementation defined actions after a CPU reset, during a CPU or cluster power
down, and when a crash occurs. CPU specific reset handlers have been implemented
in this patch. Other handlers will be implemented in subsequent patches.
Also moved cpu_helpers.S to the new directory lib/cpus/aarch64/.
Change-Id: I1ca1bade4d101d11a898fb30fea2669f9b37b956
