New helper functions are created to handle data & prefetch aborts
in AARCH32. They call platform functions, just like what
report_exception is doing.
As extended MSR/MRS instructions (to access lr_abt in monitor mode)
are only available if CPU (Armv7) has virtualization extension,
the functions branch to original report_exception handlers if this is
not the case.
Those new helpers are created mainly to distinguish data and prefetch
aborts, as they both share the same mode.
This adds 40 bytes of code.
Change-Id: I5dd31930344ad4e3a658f8a9d366a87a300aeb67
Signed-off-by: Yann Gautier <yann.gautier@st.com>
Only BL32 (SP_min) is supported at the moment, BL1 and BL2_AT_EL3 are just
stubbed with _pie_fixup_size=0.
The changes are an adaptation for AARCH32 on what has been done for
PIE support on AARCH64.
The RELA_SECTION is redefined for AARCH32, as the created section is
.rel.dyn and the symbols are .rel*.
Change-Id: I92bafe70e6b77735f6f890f32f2b637b98cf01b9
The size increase after enabling options related to ARMv8.3-PAuth is:
| | text | bss | data | rodata |
| CTX_INCLUDE_PAUTH_REGS = 1 | +108 | +192 | +0 | +0 |
| | 0.5% | 0.8% | | |
| ENABLE_PAUTH = 1 | +748 | +192 | +16 | +0 |
| | 3.7% | 0.8% | 7.0% | |
Results calculated with the following build configuration:
make PLAT=fvp SPD=tspd DEBUG=1 \
SDEI_SUPPORT=1 \
EL3_EXCEPTION_HANDLING=1 \
TSP_NS_INTR_ASYNC_PREEMPT=1 \
CTX_INCLUDE_PAUTH_REGS=1 \
ENABLE_PAUTH=1
Change-Id: I3a7d02feb6a6d212be32a01432b0c7c1a261f567
When the source code says 'SMCC' it is talking about the SMC Calling
Convention. The correct acronym is SMCCC. This affects a few definitions
and file names.
Some files have been renamed (smcc.h, smcc_helpers.h and smcc_macros.S)
but the old files have been kept for compatibility, they include the
new ones with an ERROR_DEPRECATED guard.
Change-Id: I78f94052a502436fdd97ca32c0fe86bd58173f2f
This patch updates the el3_arch_init_common macro so that it fully
initialises essential control registers rather then relying on hardware
to set the reset values.
The context management functions are also updated to fully initialise
the appropriate control registers when initialising the non-secure and
secure context structures and when preparing to leave EL3 for a lower
EL.
This gives better alignement with the ARM ARM which states that software
must initialise RES0 and RES1 fields with 0 / 1.
This patch also corrects the following typos:
"NASCR definitions" -> "NSACR definitions"
Change-Id: Ia8940b8351dc27bc09e2138b011e249655041cfc
Signed-off-by: David Cunado <david.cunado@arm.com>
This patch adds `TRUSTED_BOARD_BOOT` support for AArch32 mode.
To build this patch the "mbedtls/include/mbedtls/bignum.h"
needs to be modified to remove `#define MBEDTLS_HAVE_UDBL`
when `MBEDTLS_HAVE_INT32` is defined. This is a workaround
for "https://github.com/ARMmbed/mbedtls/issues/708"
NOTE: TBBR support on Juno AArch32 is not currently supported.
Change-Id: I86d80e30b9139adc4d9663f112801ece42deafcf
Co-Authored-By: Yatharth Kochar <yatharth.kochar@arm.com>
The current SMC context data structure `smc_ctx_t` and related helpers are
optimized for case when SMC call does not result in world switch. This was
the case for SP_MIN and BL1 cold boot flow. But the firmware update usecase
requires world switch as a result of SMC and the current SMC context helpers
were not helping very much in this regard. Therefore this patch does the
following changes to improve this:
1. Add monitor stack pointer, `spmon` to `smc_ctx_t`
The C Runtime stack pointer in monitor mode, `sp_mon` is added to the
SMC context, and the `smc_ctx_t` pointer is cached in `sp_mon` prior
to exit from Monitor mode. This makes is easier to retrieve the
context when the next SMC call happens. As a result of this change,
the SMC context helpers no longer depend on the stack to save and
restore the register.
This aligns it with the context save and restore mechanism in AArch64.
2. Add SCR in `smc_ctx_t`
Adding the SCR register to `smc_ctx_t` makes it easier to manage this
register state when switching between non secure and secure world as a
result of an SMC call.
Change-Id: I5e12a7056107c1701b457b8f7363fdbf892230bf
Signed-off-by: Soby Mathew <soby.mathew@arm.com>
This patch adds generic changes in BL1 to support AArch32 state.
New AArch32 specific assembly/C files are introduced and
some files are moved to AArch32/64 specific folders.
BL1 for AArch64 is refactored but functionally identical.
BL1 executes in Secure Monitor mode in AArch32 state.
NOTE: BL1 in AArch32 state ONLY handles BL1_RUN_IMAGE SMC.
Change-Id: I6e2296374c7efbf3cf2aa1a0ce8de0732d8c98a5
