path: root/scripts/run_fwu_fvp.sh
2018-10-22Acknowledge that FWU tests do not work on AEM FVP revCSandrine Bailleux
Mention this as a known issue in the change log. Also update the run_fwu_fvp.sh script to invoke the revB version of the FVP rather than the revC. Change-Id: I58957f4ac3ee37e054fe33bfb246c6f6fc689fdd Signed-off-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
2018-10-10Trusted Firmware-A Tests, version 2.0v2.0Sandrine Bailleux
This is the first public version of the tests for the Trusted Firmware-A project. Please see the documentation provided in the source tree for more details. Change-Id: I6f3452046a1351ac94a71b3525c30a4ca8db7867 Signed-off-by: Sandrine Bailleux <sandrine.bailleux@arm.com> Co-authored-by: amobal01 <amol.balasokamble@arm.com> Co-authored-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com> Co-authored-by: Asha R <asha.r@arm.com> Co-authored-by: Chandni Cherukuri <chandni.cherukuri@arm.com> Co-authored-by: David Cunado <david.cunado@arm.com> Co-authored-by: Dimitris Papastamos <dimitris.papastamos@arm.com> Co-authored-by: Douglas Raillard <douglas.raillard@arm.com> Co-authored-by: dp-arm <dimitris.papastamos@arm.com> Co-authored-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com> Co-authored-by: Jonathan Wright <jonathan.wright@arm.com> Co-authored-by: Kévin Petit <kevin.petit@arm.com> Co-authored-by: Roberto Vargas <roberto.vargas@arm.com> Co-authored-by: Sathees Balya <sathees.balya@arm.com> Co-authored-by: Shawon Roy <Shawon.Roy@arm.com> Co-authored-by: Soby Mathew <soby.mathew@arm.com> Co-authored-by: Thomas Abraham <thomas.abraham@arm.com> Co-authored-by: Vikram Kanigiri <vikram.kanigiri@arm.com> Co-authored-by: Yatharth Kochar <yatharth.kochar@arm.com>
