- Enable PAuth in Realm RL1 by default.
- Check if PAuth keys are accessible in Realm RL1.
- Check if Realm PAuth keys are preserved across RMM entry/exit.
- Check if NS PAuth keys are preserved across RMM entry/exit.
- Generate PAuth fault by cloberring LR.
Signed-off-by: Shruti Gupta <shruti.gupta@arm.com>
Change-Id: I85d8e03ec604c96117555e7aa866453cb2745cfe
Invalidate the RW regions in the data cache for NS_BL1U and NS_BL2U
images before enabling MMU to safeguard against potential stale data
from previous firmware stage.
Signed-off-by: Zelalem Aweke <zelalem.aweke@arm.com>
Change-Id: Ia5fc8206685cc3c1875004f4511670d7ec07b310
This patch adds 'BRANCH_PROTECTION' build option in
TFTF makefiles which corresponds to that in TF-A.
The option values are documented in 'build-options.rst'
Change-Id: Iad5083aee339cec574acf5e7ab1fd8142877a122
NOTE: AARCH32/AARCH64 macros are now deprecated in favor of __aarch64__.
All common C compilers pre-define the same macros to signal which
architecture the code is being compiled for: __arm__ for AArch32 (or
earlier versions) and __aarch64__ for AArch64. There's no need for TF-A
to define its own custom macros for this. In order to unify code with
the export headers (which use __aarch64__ to avoid another dependency),
let's deprecate the AARCH32 and AARCH64 macros and switch the code base
over to the pre-defined standard macro. (Since it is somewhat
unintuitive that __arm__ only means AArch32, let's standardize on only
using __aarch64__.)
NOTE: This change is based on below TFA commit
https://github.com/ARM-software/arm-trusted-firmware/commit/402b3cf8766fe2cb4ae462f7ee7761d08a1ba56c
Signed-off-by: Deepika Bhavnani <deepika.bhavnani@arm.com>
Change-Id: If2c3dbaeb01d4a9d8cfd95d906e5eaf4ae94417f
This patch adds ARMv8.3-PAuth support for FWU tests.
Change-Id: I36a0a2a3870db51cda0a09bd8fd8004e2d01d2bc
Parallel builds would fail while generating the dependency file of the
first source file that included tests_list.h due to it missing.
In-order builds only worked, because a rule that specified tests_list.c
as a prerequisite happened to get executed first.
This patch introduces tests_list.h as an order-only dependency of all
rules that generate dependency files. This is necessary because we can't
know which files actually depend on it until the dependency files have
been generated.
This forces the autogenerated files to be generated before any other
files are compiled, but does not cause unrelated files to recompile if
they are modified.
Signed-off-by: Bence Szépkúti <bence.szepkuti@arm.com>
Change-Id: I21f0b98052a884a853935ea35a2898ff90245a49
This prevents the execution of the read-only data.
This is done in a similar way in TF-A when the build flag
SEPARATE_CODE_AND_RODATA is enabled.
The build flag is probably not needed in TF-A Tests.
Change-Id: I2bdc0237c00377beb2febeb47207770c85036192
Signed-off-by: Ambroise Vincent <ambroise.vincent@arm.com>
Add -mstrict-align flag, and -march minor version. These are needed to
prevent compilers generating unaligned accesses and enable
architectural features respectively.
Enable the SCTLR.A and SCTLR.SA alignment checks in all images.
TF test has several cases of code which enable the alignment checks.
Change-Id: I9a0413786caf94d0abf376aa1b4fb54fc7f2f355
Signed-off-by: Joel Hutton <Joel.Hutton@Arm.com>
Added includes and sources of libc to the makefiles.
Change-Id: I8e84db9634e0df7d51caa5c5858311672dd3a8d1
Enforce full include path for includes.
of them with the same name).
Change-Id: I45e912b16c9fff81f50840dad7e7f90ed6637b2a
'fid' (short for 'function ID') makes for a more explicit name.
Change-Id: I41d90c39979162142b0377a68f4be90dc31de253
Signed-off-by: Sandrine Bailleux <sandrine.bailleux@arm.com>
NS_BL1U and NS_BL2U images have their own exception vectors code
provided by lib/${ARCH}/exception_stubs.S.
Change-Id: I5d2d760d9faf3d7bb4ba0bdefc5f20c193b1569d
BL1 SMC function IDs are not platform-specific so move them to a new
generic header file, called bl1.h.
Change-Id: I621483f7737f8101e9f370343e1a45a731c31c3b
At the moment, alignment fault checking is always enabled in TF-A
Tests (by setting the HSCTLR/SCTLR.A bit). Thus, for every instruction
that loads or stores one or more registers, the hardware checks that
the address being accessed is properly aligned to the size of the data
element(s) being accessed. If this check fails it causes an alignment
fault, which is taken as a data abort exception.
However, the compiler is currently unaware that it must not emit load
and store instructions resulting in unaligned accesses because we do
not compile the source code with -mstrict-align (AArch64) /
-mno-unaligned-access (AArch32). Because of this, we might get some
unexpected alignment faults.
We could request the compiler to align all data accesses but whether
this gives us any performance benefit is dependent on the
microarchitecture. Thus, it is simpler to just disable hardware
alignment checking and let the compiler make the call.
Change-Id: I6ef4afb09e0f87c8462a968da1ca2192ee075b40
In practice, all the functions in this file are platform-specific. It is
better to force all platforms to implement than having some sort of weak
function placeholder.
Porting guide updated.
Change-Id: I5beeeb10bec6fe5178b24503d6da8ca66074a8c6
This is the first public version of the tests for the Trusted
Firmware-A project. Please see the documentation provided in the
source tree for more details.
Change-Id: I6f3452046a1351ac94a71b3525c30a4ca8db7867
Co-authored-by: amobal01 <amol.balasokamble@arm.com>
Co-authored-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
Co-authored-by: Asha R <asha.r@arm.com>
Co-authored-by: Chandni Cherukuri <chandni.cherukuri@arm.com>
Co-authored-by: David Cunado <david.cunado@arm.com>
Co-authored-by: Dimitris Papastamos <dimitris.papastamos@arm.com>
Co-authored-by: Douglas Raillard <douglas.raillard@arm.com>
Co-authored-by: dp-arm <dimitris.papastamos@arm.com>
Co-authored-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
Co-authored-by: Jonathan Wright <jonathan.wright@arm.com>
Co-authored-by: Kévin Petit <kevin.petit@arm.com>
Co-authored-by: Roberto Vargas <roberto.vargas@arm.com>
Co-authored-by: Sathees Balya <sathees.balya@arm.com>
Co-authored-by: Shawon Roy <Shawon.Roy@arm.com>
Co-authored-by: Soby Mathew <soby.mathew@arm.com>
Co-authored-by: Thomas Abraham <thomas.abraham@arm.com>
Co-authored-by: Vikram Kanigiri <vikram.kanigiri@arm.com>
Co-authored-by: Yatharth Kochar <yatharth.kochar@arm.com>
