Related for older ArmClang versions (pre-UBL) which were removed and no
longer supported.
Signed-off-by: Paul Sokolovsky <paul.sokolovsky@linaro.org>
Change-Id: I300282231ffa521e6674675eaf35aefb6e1da071
We switched to 6.18 for the last release, then to 6.21 after it.
Change-Id: I893be445beca389d632efb5620e712f910b6e873
It was found that 6.21 may trigger warning-as-error which really looks like
false positive (more info: https://linaro.atlassian.net/browse/TFC-540). That
warning doesn't happend with 6.18, so now going to try intermediate versions.
Change-Id: Ie37fc95620fff51a49ee2ca5cd46d6696d264721
Primary motivation at this time is to test is there's an improvement
re: discovered issues with ArmClang 6.18 UBL (produces binaries which
fail LAVA tests).
Change-Id: I52fe9d03b18b45d63ed09ebc66bf3431e38ccd62
Required to support UBL licensing. Related to
https://linaro.atlassian.net/browse/TFC-198
Change-Id: I77638fe2bcda1867636bab18d3ab3b82b23ad57f
Signed-off-by: Xinyu Zhang <xinyu.zhang@arm.com>
Change-Id: Ief770230c0f759236005053f6ff1fd480a4b5a03
The latest Jenkins releases support only Java 11 (on the server side, and
thus on the build agent side, as the versions should match).
Change-Id: I29fb695171e96dff5dc61d94bdebc0588a2bf577
Arm Clang toolchains are no longer accessible via straight HTTP requests.
Instead, they are mirrored to an S3 bucket, files from which are made
available to build.sh, which in turn makes them available to Dockerfile.
This is similar to changes previously made to TF-A images.
Change-Id: Iebf0b1089d1963bac8aa8b49621540741762183f
Change-Id: I24ee08da5c42caf903ceae0ffa2cb6f9fb777fda
Change-Id: If3bd9dbfbb1d9baef9f984022494a4e5c92cd5b4
Ninja based build can improve TF-M build job performance.
Change-Id: Iaabdc549968484dc4d98008899a1a435929a71cf
TF-M Open CI needs to support multi versions of compilers.
Download all compilers to COMPILER_DIR, and set specific paths
for different compiler versions. So that the compiler versions
can be selected in every single build-config job.
Currently following compilers are installed for TF-M Open CI:
- GCC v7.3.1
- GCC v10.3
- ARMClang v6.13
Change-Id: I31cc55181704319d5194c336c5bd6f14fccd921e
Rebuild with latest software to get ca-certificates upto
date
Change-Id: Ie99f097076970136fa2163efdc5a7f8779f547c1
The cysecuretools is the tool to sign the binaries for Cypress PSoC6 [1]
psutil will be installed as a dependency package by pip3, so remove
python3-psutil from the PKG_DEPS
Some python3 packages version are adjusted, due to the requirement of
cysecurtools
[1] https://tf-m-user-guide.trustedfirmware.org/platform/ext/target/cypress/psoc64/cypress_psoc64_spec.html#prerequisites
Signed-off-by: Arthur She <arthur.she@linaro.org>
Change-Id: Ib95d1be727be66efb3934bfdccd4ad64ec6b4d06
On the speculation that the random license issues are due to
jenkins server overloading from license requests, try using
another server for flexnet.
Change-Id: I2105da9a9bedaad02b32260f0b12d8ce228fb6e8
librsvg2-bin package is needed for sphinxcontrib-svg2pdfconverter.
Signed-off-by: Summer Qin <summer.qin@arm.com>
Change-Id: Idfe17936eb23a6d3ca58944c58e9a714a4938dd7
The URL of script 'get-pip.py' has changed.[1]
[1] https://ci.trustedfirmware.org/job/ci-dockerfiles-sanity-check/label=build-amd64/lastBuild/console
Change-Id: I9a958719895243e9845308dbc57777790b8f6cb3
fixes the following error:
File "/tmp/get-pip.py", line 199, in main
bootstrap(tmpdir=tmpdir)
File "/tmp/get-pip.py", line 82, in bootstrap
from pip._internal.cli.main import main as pip_entry_point
File "/tmp/tmpcP1hEo/pip.zip/pip/_internal/cli/main.py", line 60
sys.stderr.write(f"ERROR: {exc}")
SyntaxError: invalid syntax
Signed-off-by: Fathi Boudra <fathi.boudra@linaro.org>
Change-Id: I4895c8db072a8878325b022d8f9cb5e4d50d00ee
Fix https://projects.linaro.org/browse/LSS-2002
Files are truncated when writing on the filesystem using unicode strings.
Change-Id: Id16c742f77a6b41c2ba4f3fb56f8c816fff72b43
cppcheck test requires to build mbedcrypto, which fails with a cmake
fatal error: fatal: unable to auto-detect email address
Set a git default config to avoid this error.
Change-Id: Ice1337777ea294e0b93c573137fa9780c544a864
We're using docker with sshd. ENV aren't preserved.
In addition, it keeps the environment variables settings in a single
place, within the docker image itself.
Change-Id: I06005c608c2e6c6a22c0ed1acf4b84addcee22fc
ARMLMD_LICENSE_FILE is used by Arm Clang. It looks like a duplicate of the
existing LICENSE_VARIABLE but the latter is used to substitute a string in
the FVP jinija2 template used for LAVA.
Change-Id: I85bcc0afc4afca4e0ff64e64535ef00650aa051d
They can be overriden (per instance) in:
-> Jenkins configure system
-> global properties
-> environment variables
Change-Id: I4d76103ec2bdbcf895d0b48ae95dbdb8d56452fb
revert https://review.trustedfirmware.org/c/ci/dockerfiles/+/6672
It was working as expected, as long as we keep "set -e" in the RUN
command.
Split toolchains and binaries install into a shell script. it's easier to
read and maintain a shell script than bundle it into a Dockerfile.
Change-Id: Ib0d0dfd26c7ef3602547113a5172c1021c9e3ac2
As we don't use ECS anymore, remove jenkins remoting support deprecated in
favor of sshd approach.
Change-Id: Ifc6dc9449be3290a766c3773b20fcd571408b4f4
remove binaries pulled from
https://releases.linaro.org/members/arm/platforms as TF-M CI isn't using
them.
Change-Id: I5d70de79974e6d85c38df75b6e5986f778ab9969
There is no need to use jenkins slaves because now the communication
is with through ssh daemon (sshd)
Signed-off-by: Leonardo Sandoval <leonardo.sandoval@linaro.org>
Change-Id: If77cbb629748660104e5675311d8bc40c57492c5
Otherwise, image build phases yield images even though there may be
erros in the build process.
For example, the following image is built however there is a command
that fails (false command)
echo -e 'FROM ubuntu:bionic\nRUN false; true' | docker build -
Sending build context to Docker daemon 2.048kB
Step 1/2 : FROM ubuntu:bionic
---> 56def654ec22
Step 2/2 : RUN false; true
---> Running in 85759437ee6b
Removing intermediate container 85759437ee6b
---> 44ee5447fd5d
Successfully built 44ee5447fd5d
versus this image that fails (correctly) due to errors
echo -e 'FROM ubuntu:bionic\nRUN false && true' | docker build -
---> 56def654ec22
Step 2/2 : RUN false && true
---> Running in f4b9ac94bf12
The command '/bin/sh -c false && true' returned a non-zero code: 1
Change-Id: Iea48194869c884fc6d3d6c64a1fd6ea7be41ec84
This reverts commit ade88fcb5f50b8d47d930cb6b7d8aa0d7f6a81c8.
Reason for revert: we can't embed the token here
Change-Id: I56db900a411a813680dd016e09ad399c81829e97
Coverity is a static code analysis tool that is used in both TF core
projects.
Change-Id: I0a9f50d4badfce7270731ab432c3e9087b6a6492
Currently, the builders.sh [1] script fetches Linaro's platform files
everytime a job runs but this can be avoided if the latter are already
present on the image.
[1] https://git.trustedfirmware.org/ci/tf-a-job-configs.git/tree/tf-a-builder/builders.sh
Change-Id: I8736a73231111ae3304965268723b431013ab69d
The clang-tools contains 'scan-build' binary, used for static analysis
checks at TF-A project [1].
[1] https://git.trustedfirmware.org/ci/tf-a-ci-scripts.git/tree/script/scan_build_wrapper.sh
Change-Id: I909b264f880821f61a1e49bafb11737f77c863f5
The libxml package is required to build TF-A tests as indicated in
[1] otherwise build failures are encountered when building tftf
related test configs.
[1] https://trustedfirmware-a-tests.readthedocs.io/en/latest/getting_started/requirements.html#build-host
Change-Id: I0c22a219f27a5164037764604cbf23d7790c1e88
With these new toolchains, besides the already installed GNU-GCC
arm-none-eabi- (7.3.1), TF projects (A and M) can compile with GNU
and Arm toolchains for both architectures, arm and aarch64.
Change-Id: Ied143296faa4ab2228c7e2415272ef564561d2ad
lcov
ctags
Change-Id: Ie6d47a9a4d43281c387165fe1034d03bc2e35082
Signed-off-by: Karl Zhang <karl.zhang@arm.com>
The new build system for TF-M going to merge, it requires Cmake later
than 3.15.0.
Change-Id: I56efdb309cdfa4bac2d337047fd3f0b2cbfb439f
Add bison and flex packages for building TF-Fuzz tool in
bionic-amd64-tf-m-build.
Change-Id: I4c9adebb1cc8e41b7e0da557e89580f038daf06a
Signed-off-by: Mate Toth-Pal <mate.toth-pal@arm.com>
setup-ssh is required for YADP, also the jar file has never been
readable by the buildslave user. Lets fix this.
Signed-off-by: Benjamin Copeland <ben.copeland@linaro.org>
Change-Id: I2076bb62eefc9c0a09612a0d3e62bfdbc9ef8c37
These changes are needed for the temp solution to move away from ECS
Change-Id: I4fd3a08b3f3c842e443a86da202176d5922f132d
TF-M currently failing on fatal error: bits/libc-header-start.h: No such
file or directory this should fix that.
Change-Id: Ia396b88761a1e1f3fa7c6656482ec52e1769b9a5
Change-Id: I8b8d64cd6779b4bb71469fa20a78d990a30e2925
"CMake 3.10 or higher is required. You are running version 3.7.2", with
a list of 3.10 -> 3.14 supported. Lets move to 3.14 as its the current
TF-M support make version.
Change-Id: Ia4cf658d74611e1f2924748be5039b26e6c61924
Change-Id: Ia399392297bf67a135c865cc72dfe36408ef092e
Based of the xenial image this builds a Bionic image for the TF-M
project.
Change-Id: Ie620de26f0c27098aee2f5ebb0b74867669c8aa4
