NOTE: __ASSEMBLY__ macro is now deprecated in favor of __ASSEMBLER__.
All common C compilers predefine a macro called __ASSEMBLER__ when
preprocessing a .S file. There is no reason for TF-A to define it's own
__ASSEMBLY__ macro for this purpose instead. To unify code with the
export headers (which use __ASSEMBLER__ to avoid one extra dependency),
let's deprecate __ASSEMBLY__ and switch the code base over to the
predefined standard.
Change-Id: Id7d0ec8cf330195da80499c68562b65cb5ab7417
Signed-off-by: Julius Werner <jwerner@chromium.org>
Commit 09d40e0e0828 ("Sanitise includes across codebase") modified the
include paths of the TSP includes but it didn't remove the include path
from the makefile or did the same for TLK. This patch does the remaining
work.
Change-Id: Iecee2e88fabcd06989d35568c3a4c1f4e7d93572
Corrects typos in core code, documentation files, drivers, Arm
platforms and services.
None of the corrections affect code; changes are limited to comments
and other documentation.
Change-Id: I5c1027b06ef149864f315ccc0ea473e2a16bfd1d
Signed-off-by: Paul Beesley <paul.beesley@arm.com>
All identifiers, regardless of use, that start with two underscores are
reserved. This means they can't be used in header guards.
The style that this project is now to use the full name of the file in
capital letters followed by 'H'. For example, for a file called
"uart_example.h", the header guard is UART_EXAMPLE_H.
The exceptions are files that are imported from other projects:
- CryptoCell driver
- dt-bindings folders
- zlib headers
Change-Id: I50561bf6c88b491ec440d0c8385c74650f3c106e
Ensure the flow through switch statements is clear
Change-Id: Icd1cdd42afdc78895a9be6c46b414b0a155cfa63
Ensure case clauses:
* Terminate with an unconditional break, return or goto statement.
* Use conditional break, return or goto statements as long as the end
of the case clause is unreachable; such case clauses must terminate
with assert(0) /* Unreachable */ or an unconditional __dead2 function
call
* Only fallthough when doing otherwise would result in less
readable/maintainable code; such case clauses must terminate with a
/* Fallthrough */ comment to make it clear this is the case and
indicate that a fallthrough is intended.
This reduces the chance of bugs appearing due to unintended flow through a
switch statement
Change-Id: I70fc2d1f4fd679042397dec12fd1982976646168
Signed-off-by: Daniel Boulby <daniel.boulby@arm.com>
RFC4122 defines that fields are stored in network order (big endian),
but TF-A stores them in machine order (little endian by default in TF-A).
We cannot change the future UUIDs that are already generated, but we can store
all the bytes using arrays and modify fiptool to generate the UUIDs with
the correct byte order.
Change-Id: I97be2d3168d91f4dee7ccfafc533ea55ff33e46f
Signed-off-by: Roberto Vargas <roberto.vargas@arm.com>
Use a _ prefix for macro arguments to prevent that argument from
hiding variables of the same name in the outer scope
Rule 5.3: An identifier declared in an inner scope shall not
hide an identifier declared in an outer scope
Fixed For:
make PLAT=fvp SPD=tspd
Change-Id: I2d711b9584c4cb9ba3814ecd2ca65a42b7e24179
Commit 4c0d03907652 ("Rework type usage in Trusted Firmware") changed
the type usage in struct declarations, but did not touch the definition
side. Fix the type mismatch.
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
These are used locally in a file.
Rule 8.4: A compatible declaration shall be visible when
an object or function with external linkage is defined
Fixed for:
make DEBUG=1 PLAT=fvp SPD=tspd all
Change-Id: I0a16cf68fef29cf00ec0a52e47786f61d02ca4ae
Rule 8.3: All declarations of an object or function shall
use the same names and type qualifiers
Fixed for:
Change-Id: I4e31c93d502d433806dfc521479d5d428468b37c
Ensure (where possible) that switch statements in services comply with
MISRA rules 16.1 - 16.7.
Change-Id: I47bf6ed4a026201e6fe125ce51842482e99e8bb0
Signed-off-by: Jonathan Wright <jonathan.wright@arm.com>
An earlier patch extended ehf_allow_ns_preemption() API to also register
an error code to offer to Non-secure when a Yielding SMC is preempted by
SDEI interrupt. In TSPD's case, register the error code TSP_PREEMPTED.
Change-Id: I31992b6651f80694e83bc5092b044ef7a3eda690
Signed-off-by: Jeenu Viswambharan <jeenu.viswambharan@arm.com>
At present, the build option TSP_NS_INTR_ASYNC_PREEMPT controls how
Non-secure interrupt affects TSPs execution. When TSP is executing:
1. When TSP_NS_INTR_ASYNC_PREEMPT=0, Non-secure interrupts are received
at the TSP's exception vector, and TSP voluntarily preempts itself.
2. When TSP_NS_INTR_ASYNC_PREEMPT=1, Non-secure interrupts causes a
trap to EL3, which preempts TSP execution.
When EL3 exception handling is in place (i.e.,
EL3_EXCEPTION_HANDLING=1), FIQs are always trapped to EL3. On a system
with GICv3, pending NS interrupts while TSP is executing will be
signalled as FIQ (which traps to EL3). This situation necessitates the
same treatment applied to case (2) above.
Therefore, when EL3 exception handling is in place, additionally
require that TSP_NS_INTR_ASYNC_PREEMPT is set to one 1.
Strictly speaking, this is not required on a system with GICv2, but the
same model is uniformly followed regardless, for simplicity.
Relevant documentation updated.
Change-Id: I928a8ed081fb0ac96e8b1dfe9375c98384da1ccd
When EL3 exception handling is in effect (i.e.,
EL3_EXCEPTION_HANDLING=1), Non-secure interrupts can't preempt Secure
execution. However, for yielding SMCs, preemption by Non-secure
interupts is intended.
This patch therefore adds a call to ehf_allow_ns_preemption() before
dispatching a Yielding SMC to TSP.
Change-Id: Ia3a1ae252f3adc0f14e6d7e0502f251bdb349bdf
A line in the upstream SPDs is only compiled in in `DEBUG` builds. This
line is used to help with assertions and so assertion failures can
happen in release builds with assertions enabled. Use
`ENABLE_ASSERTIONS` instead of `DEBUG`.
This bug was introduced in commit aa61368eb5, which introduced the build
option `ENABLE_ASSERTIONS`.
Change-Id: I7977df9c89c68677b00099b2a1926fa3cb0937c6
This fix modifies the order of system includes to meet the ARM TF coding
standard. There are some exceptions in order to retain header groupings,
minimise changes to imported headers, and where there are headers within
the #if and #ifndef statements.
Change-Id: I65085a142ba6a83792b26efb47df1329153f1624
Signed-off-by: Isla Mitchell <isla.mitchell@arm.com>
Use SPDX license identifiers
Update terminology: standard SMC to yielding SMC
Since Issue B (November 2016) of the SMC Calling Convention document
standard SMC calls are renamed to yielding SMC calls to help avoid
confusion with the standard service SMC range, which remains unchanged.
http://infocenter.arm.com/help/topic/com.arm.doc.den0028b/ARM_DEN0028B_SMC_Calling_Convention.pdf
This patch adds a new define for yielding SMC call type and deprecates
the current standard SMC call type. The tsp is migrated to use this new
terminology and, additionally, the documentation and code comments are
updated to use this new terminology.
Change-Id: I0d7cc0224667ee6c050af976745f18c55906a793
Signed-off-by: David Cunado <david.cunado@arm.com>
SMC_RET0 should only be used when the SMC code works as a function that
returns void. If the code of the SMC uses SMC_RET1 to return a value to
signify success and doesn't return anything in case of an error (or the
other way around) SMC_RET1 should always be used to return clearly
identifiable values.
This patch fixes two cases in which the code used SMC_RET0 instead of
SMC_RET1.
It also introduces the define SMC_OK to use when an SMC must return a
value to tell that it succeeded, the same way as SMC_UNK is used in case
of failure.
Change-Id: Ie4278b51559e4262aced13bbde4e844023270582
ABORT SMC used to return to the previously executing world, which
happened to be S-EL1 as it calls a TSP handler using synchronous entry
into the TSP.
Now properly save and restore the non-secure context (including system
registers) and return to non-secure world as it should.
fixes ARM-Software/tf-issues#453
Change-Id: Ie40c79ca2636ab8b6b2ab3106e8f49e0f9117f5f
Signed-off-by: Douglas Raillard <douglas.raillard@arm.com>
Replace all use of memset by zeromem when zeroing moderately-sized
structure by applying the following transformation:
memset(x, 0, sizeof(x)) => zeromem(x, sizeof(x))
As the Trusted Firmware is compiled with -ffreestanding, it forbids the
compiler from using __builtin_memset and forces it to generate calls to
the slow memset implementation. Zeromem is a near drop in replacement
for this use case, with a more efficient implementation on both AArch32
and AArch64.
Change-Id: Ia7f3a90e888b96d056881be09f0b4d65b41aa79e
Standard SMC requests that are handled in the secure-world by the Secure
Payload can be preempted by interrupts that must be handled in the
normal world. When the TSP is preempted the secure context is stored and
control is passed to the normal world to handle the non-secure
interrupt. Once completed the preempted secure context is restored. When
restoring the preempted context, the dispatcher assumes that the TSP
preempted context is still stored as the SECURE context by the context
management library.
However, PSCI power management operations causes synchronous entry into
TSP. This overwrites the preempted SECURE context in the context
management library. When restoring back the SECURE context, the Secure
Payload crashes because this context is not the preempted context
anymore.
This patch avoids corruption of the preempted SECURE context by aborting
any preempted SMC during PSCI power management calls. The
abort_std_smc_entry hook of the TSP is called when aborting the SMC
request.
It also exposes this feature as a FAST SMC callable from normal world to
abort preempted SMC with FID TSP_FID_ABORT.
Change-Id: I7a70347e9293f47d87b5de20484b4ffefb56b770
Change-Id: I6f49bd779f2a4d577c6443dd160290656cdbc59b
Earlier the TSP only ever expected to be preempted during Standard SMC
processing. If a S-EL1 interrupt triggered while in the normal world, it
will routed to S-EL1 `synchronously` for handling. The `synchronous` S-EL1
interrupt handler `tsp_sel1_intr_entry` used to panic if this S-EL1 interrupt
was preempted by another higher priority pending interrupt which should be
handled in EL3 e.g. Group0 interrupt in GICv3.
With this patch, the `tsp_sel1_intr_entry` now expects `TSP_PREEMPTED` as the
return code from the `tsp_common_int_handler` in addition to 0 (interrupt
successfully handled) and in both cases it issues an SMC with id
`TSP_HANDLED_S_EL1_INTR`. The TSPD switches the context and returns back
to normal world. In case a higher priority EL3 interrupt was pending, the
execution will be routed to EL3 where interrupt will be handled. On return
back to normal world, the pending S-EL1 interrupt which was preempted will
get routed to S-EL1 to be handled `synchronously` via `tsp_sel1_intr_entry`.
Change-Id: I2087c7fedb37746fbd9200cdda9b6dba93e16201
On a GICv2 system, interrupts that should be handled in the secure world are
typically signalled as FIQs. On a GICv3 system, these interrupts are signalled
as IRQs instead. The mechanism for handling both types of interrupts is the same
in both cases. This patch enables the TSP to run on a GICv3 system by:
1. adding support for handling IRQs in the exception handling code.
2. removing use of "fiq" in the names of data structures, macros and functions.
The build option TSPD_ROUTE_IRQ_TO_EL3 is deprecated and is replaced with a
new build flag TSP_NS_INTR_ASYNC_PREEMPT. For compatibility reasons, if the
former build flag is defined, it will be used to define the value for the
new build flag. The documentation is also updated accordingly.
Change-Id: I1807d371f41c3656322dd259340a57649833065e
The TSP is expected to pass control back to EL3 if it gets preempted due to
an interrupt while handling a Standard SMC in the following scenarios:
1. An FIQ preempts Standard SMC execution and that FIQ is not a TSP Secure
timer interrupt or is preempted by a higher priority interrupt by the time
the TSP acknowledges it. In this case, the TSP issues an SMC with the ID
as `TSP_EL3_FIQ`. Currently this case is never expected to happen as only
the TSP Secure Timer is expected to generate FIQ.
2. An IRQ preempts Standard SMC execution and in this case the TSP issues
an SMC with the ID as `TSP_PREEMPTED`.
In both the cases, the TSPD hands control back to the normal world and returns
returns an error code to the normal world to indicate that the standard SMC it
had issued has been preempted but not completed.
This patch unifies the handling of these two cases in the TSPD and ensures that
the TSP only uses TSP_PREEMPTED instead of separate SMC IDs. Also instead of 2
separate error codes, SMC_PREEMPTED and TSP_EL3_FIQ, only SMC_PREEMPTED is
returned as error code back to the normal world.
Background information: On a GICv3 system, when the secure world has affinity
routing enabled, in 2. an FIQ will preempt TSP execution instead of an IRQ. The
FIQ could be a result of a Group 0 or a Group 1 NS interrupt. In both case, the
TSPD passes control back to the normal world upon receipt of the TSP_PREEMPTED
SMC. A Group 0 interrupt will immediately preempt execution to EL3 where it
will be handled. This allows for unified interrupt handling in TSP for both
GICv3 and GICv2 systems.
Change-Id: I9895344db74b188021e3f6a694701ad272fb40d4
The IMF_READ_INTERRUPT_ID build option enables a feature where the interrupt
ID of the highest priority pending interrupt is passed as a parameter to the
interrupt handler registered for that type of interrupt. This additional read
of highest pending interrupt id from GIC is problematic as it is possible that
the original interrupt may get deasserted and another interrupt of different
type maybe become the highest pending interrupt. Hence it is safer to prevent
such behaviour by removing the IMF_READ_INTERRUPT_ID build option.
The `id` parameter of the interrupt handler `interrupt_type_handler_t` is
now made a reserved parameter with this patch. It will always contain
INTR_ID_UNAVAILABLE.
Fixes ARM-software/tf-issues#307
Change-Id: I2173aae1dd37edad7ba6bdfb1a99868635fa34de
In certain Trusted OS implementations it is a requirement to pass them the
highest power level which will enter a power down state during a PSCI
CPU_SUSPEND or SYSTEM_SUSPEND API invocation. This patch passes this power level
to the SPD in the "max_off_pwrlvl" parameter of the svc_suspend() hook.
Currently, the highest power level which was requested to be placed in a low
power state (retention or power down) is passed to the SPD svc_suspend_finish()
hook. This hook is called after emerging from the low power state. It is more
useful to pass the highest power level which was powered down instead. This
patch does this by changing the semantics of the parameter passed to an SPD's
svc_suspend_finish() hook. The name of the parameter has been changed from
"suspend_level" to "max_off_pwrlvl" as well. Same changes have been made to the
parameter passed to the tsp_cpu_resume_main() function.
NOTE: THIS PATCH CHANGES THE SEMANTICS OF THE EXISTING "svc_suspend_finish()"
API BETWEEN THE PSCI AND SPD/SP IMPLEMENTATIONS. THE LATTER MIGHT NEED
UPDATES TO ENSURE CORRECT BEHAVIOUR.
Change-Id: If3a9d39b13119bbb6281f508a91f78a2f46a8b90
The new PSCI frameworks mandates that the platform APIs and the various
frameworks in Trusted Firmware migrate away from MPIDR based core
identification to one based on core index. Deprecated versions of the old
APIs are still present to provide compatibility but their implementations
are not optimal. This patch migrates the various SPDs exisiting within
Trusted Firmware tree and TSP to the new APIs.
Change-Id: Ifc37e7071c5769b5ded21d0b6a071c8c4cab7836
In order for the symbol table in the ELF file to contain the size of
functions written in assembly, it is necessary to report it to the
assembler using the .size directive.
To fulfil the above requirements, this patch introduces an 'endfunc'
macro which contains the .endfunc and .size directives. It also adds
a .func directive to the 'func' assembler macro.
The .func/.endfunc have been used so the assembler can fail if
endfunc is omitted.
Fixes ARM-Software/tf-issues#295
Change-Id: If8cb331b03d7f38fe7e3694d4de26f1075b278fc
Signed-off-by: Kévin Petit <kevin.petit@arm.com>
This patch provides an option to specify a interrupt routing model
where non-secure interrupts (IRQs) are routed to EL3 instead of S-EL1.
When such an interrupt occurs, the TSPD arranges a return to
the normal world after saving any necessary context. The interrupt
routing model to route IRQs to EL3 is enabled only during STD SMC
processing. Thus the pre-emption of S-EL1 is disabled during Fast SMC
and Secure Interrupt processing.
A new build option TSPD_ROUTE_NS_INT_EL3 is introduced to change
the non secure interrupt target execution level to EL3.
Fixes ARM-software/tf-issues#225
Change-Id: Ia1e779fbbb6d627091e665c73fa6315637cfdd32
This patch adds support to save the "power state" parameter before the
affinity level specific handlers are called in a CPU_SUSPEND call.
This avoids the need to pass the power_state as a parameter to the
handlers and Secure Payload Dispatcher (SPD) suspend spd_pm_ops.
The power_state arguments in the spd_pm_ops operations are now reserved
and must not be used. The SPD can query the relevant power_state fields
by using the psci_get_suspend_afflvl() & psci_get_suspend_stateid() APIs.
NOTE: THIS PATCH WILL BREAK THE SPD_PM_OPS INTERFACE. HENCE THE SECURE
PAYLOAD DISPATCHERS WILL NEED TO BE REWORKED TO USE THE NEW INTERFACE.
Change-Id: I1293d7dc8cf29cfa6a086a009eee41bcbf2f238e
This patch adds support for SYSTEM_OFF and SYSTEM_RESET PSCI
operations. A platform should export handlers to complete the
requested operation. The FVP port exports fvp_system_off() and
fvp_system_reset() as an example.
If the SPD provides a power management hook for system off and
system reset, then the SPD is notified about the corresponding
operation so it can do some bookkeeping. The TSPD exports
tspd_system_off() and tspd_system_reset() for that purpose.
Versatile Express shutdown and reset methods have been removed
from the FDT as new PSCI sys_poweroff and sys_reset services
have been added. For those kernels that do not support yet these
PSCI services (i.e. GICv3 kernel), the original dtsi files have
been renamed to *-no_psci.dtsi.
Fixes ARM-software/tf-issues#218
Change-Id: Ic8a3bf801db979099ab7029162af041c4e8330c8
* Move TSP platform porting functions to new file:
include/bl32/tsp/platform_tsp.h.
* Create new TSP_IRQ_SEC_PHY_TIMER definition for use by the generic
TSP interrupt handling code, instead of depending on the FVP
specific definition IRQ_SEC_PHY_TIMER.
* Rename TSP platform porting functions from bl32_* to tsp_*, and
definitions from BL32_* to TSP_*.
* Update generic TSP code to use new platform porting function names
and definitions.
* Update FVP port accordingly and move all TSP source files to:
plat/fvp/tsp/.
* Update porting guide with above changes.
Note: THIS CHANGE REQUIRES ALL PLATFORM PORTS OF THE TSP TO
BE UPDATED
Fixes ARM-software/tf-issues#167
Change-Id: Ic0ff8caf72aebb378d378193d2f017599fc6b78f
This patch adds support for BL3-2 initialization by asynchronous
method where BL3-1 transfers control to BL3-2 using world switch.
After BL3-2 initialization, it transfers control to BL3-3 via SPD
service handler. The SPD service handler initializes the CPU context
to BL3-3 entrypoint depending on the return function indentifier from
TSP initialization.
Fixes ARM-software/TF-issues#184
Change-Id: I7b135c2ceeb356d3bb5b6a287932e96ac67c7a34
There is no mechanism which allows the TSPD to specify what SPSR to
use when entering BL3-2 instead of BL3-3. This patch divides the
responsibility between tspd_setup() and tspd_init() for initializing
the TSPD and TSP to support the alternate BL3-2 initialization flow
where BL3-1 handsover control to BL3-2 instead of BL3-3.
SPSR generated by TSPD for TSP is preserved due the new division of
labour which fixes #174.
This patch also moves the cpu_context initialization code from
tspd_setup() to tspd_init() immediately before entering the TSP.
Instead tspd_setup() updates the BL3-2 entrypoint info structure
with the state required for initializing the TSP later.
Fixes ARM-software/TF-issues#174
Change-Id: Ida0a8a48d466c71d5b07b8c7f2af169b73f96940
Assert a valid security state using the macro sec_state_is_valid().
Replace assert() with panic() in those cases that might arise
because of runtime errors and not programming errors.
Replace panic() with assert() in those cases that might arise
because of programming errors.
Fixes ARM-software/tf-issues#96
Change-Id: I51e9ef0439fd5ff5e0edfef49050b69804bf14d5
Consolidate all BL3-1 CPU context initialization for cold boot, PSCI
and SPDs into two functions:
* The first uses entry_point_info to initialize the relevant
cpu_context for first entry into a lower exception level on a CPU
* The second populates the EL1 and EL2 system registers as needed
from the cpu_context to ensure correct entry into the lower EL
This patch alters the way that BL3-1 determines which exception level
is used when first entering EL1 or EL2 during cold boot - this is now
fully determined by the SPSR value in the entry_point_info for BL3-3,
as set up by the platform code in BL2 (or otherwise provided to BL3-1).
In the situation that EL1 (or svc mode) is selected for a processor
that supports EL2, the context management code will now configure all
essential EL2 register state to ensure correct execution of EL1. This
allows the platform code to run non-secure EL1 payloads directly
without requiring a small EL2 stub or OS loader.
Change-Id: If9fbb2417e82d2226e47568203d5a369f39d3b0f
All callers of cm_get_context() pass the calling CPU MPIDR to the
function. Providing a specialised version for the current
CPU results in a reduction in code size and better readability.
The current function has been renamed to cm_get_context_by_mpidr()
and the existing name is now used for the current-CPU version.
The same treatment has been done to cm_set_context(), although
only both forms are used at present in the PSCI and TSPD code.
Change-Id: I91cb0c2f7bfcb950a045dbd9ff7595751c0c0ffb
This patch fixes the compilation issue for trusted firmware when the
IMF_READ_INTERRUPT_ID is enabled.
Change-Id: I94ab613b9bc96a7c1935796c674dc42246aaafee
into for-v0.4
Rename the ic_* platform porting functions to plat_ic_* to be
consistent with the other functions in platform.h. Also rename
bl31_get_next_image_info() to bl31_plat_get_next_image_ep_info()
and remove the duplicate declaration in bl31.h.
Change-Id: I4851842069d3cff14c0a468daacc0a891a7ede84
This patch fixes a missed return and code alignment issues
in TSP_FID_RESUME handling.
Change-Id: Icf8aeb76dfd6898745653ce039e3bac45e0a9b3a
Previously, platform.h contained many declarations and definitions
used for different purposes. This file has been split so that:
* Platform definitions used by common code that must be defined
by the platform are now in platform_def.h. The exact include
path is exported through $PLAT_INCLUDES in the platform makefile.
* Platform definitions specific to the FVP platform are now in
/plat/fvp/fvp_def.h.
* Platform API declarations specific to the FVP platform are now
in /plat/fvp/fvp_private.h.
* The remaining platform API declarations that must be ported by
each platform are still in platform.h but this file has been
moved to /include/plat/common since this can be shared by all
platforms.
Change-Id: Ieb3bb22fbab3ee8027413c6b39a783534aee474a
