Main Fixes:
Use int32_t replace int [Rule 4.6]
Added explicit casts (e.g. 0U) to integers in order for them to be
compatible with whatever operation they're used in [Rule 10.1]
Force operands of an operator to the same type category [Rule 10.4]
Fixed if statement conditional to be essentially boolean [Rule 14.4]
Voided non c-library functions whose return types are not used
[Rule 17.7]
Change-Id: I98caa330c371757eb2dfb9438448cb99115ed907
Signed-off-by: Anthony Zhou <anzhou@nvidia.com>
All identifiers, regardless of use, that start with two underscores are
reserved. This means they can't be used in header guards.
The style that this project is now to use the full name of the file in
capital letters followed by 'H'. For example, for a file called
"uart_example.h", the header guard is UART_EXAMPLE_H.
The exceptions are files that are imported from other projects:
- CryptoCell driver
- dt-bindings folders
- zlib headers
Change-Id: I50561bf6c88b491ec440d0c8385c74650f3c106e
Since Issue B (November 2016) of the SMC Calling Convention document
standard SMC calls are renamed to yielding SMC calls to help avoid
confusion with the standard service SMC range, which remains unchanged.
http://infocenter.arm.com/help/topic/com.arm.doc.den0028b/ARM_DEN0028B_SMC_Calling_Convention.pd
A previous patch introduced a new define for yielding SMC call type.
This patch updates the secure payload dispatchers (except the TSPD) to
use this new define and also migrates the code to use the new
terminology.
Change-Id: I3d2437c04e3b21fdbd32019f55c066c87679a5bf
Signed-off-by: David Cunado <david.cunado@arm.com>
If Trusty is not running on the device, then Verified Boot is
not supported and the NS layer will fail gracefully later during
boot. This patch just returns success for the case when Trusty is
not running on the device and the bootloader issues SET_ROT_PARAMS
call during boot, so that we can at least boot non-Android images.
Change-Id: I40fc249983df80fb8cc5be5e4ce94c99d5b5f17d
Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
With GCC 6.2 compiler, more C undefined behaviour is being flagged as
warnings, which result in build errors in ARM TF build.
The specific issue that this patch resolves is the use of (1 << 31),
which is predominantly used in case statements, where 1 is represented
as a signed int. When shifted to msb the behaviour is undefined.
The resolution is to specify 1 as an unsigned int using a convenience
macro ULL(). A duplicate macro MAKE_ULL() is replaced.
Fixes ARM-software/tf-issues#438
Change-Id: I08e3053bbcf4c022ee2be33a75bd0056da4073e1
This patch adds the secure payload dispatcher for interacting
with Google's Trusty TEE. Documentation for Trusty can be found
at https://source.android.com/security/trusty
Original authors:
* Arve Hjønnevåg <arve@android.com>
* Michael Ryleev <gmar@google.com>
