Remove old implementation for Layerscape ls1043a platform, and
will added it back with unified software architecture of all
Layerscape platforms.
Signed-off-by: Jiafei Pan <Jiafei.Pan@nxp.com>
Change-Id: If038c19ab04d70050ec8e6ab2097b1c4f8324e87
This patch introduce TF-A support for NXP's ls1043a platform.
more details information of ls1043a chip and ls1043ardb board
can be found at docs/plat/ls1043a.rst.
Boot sequence on ls1043a is: bootrom loads bl1 firstly, then bl1
loads bl2, bl2 will load bl31, bl32 and bl33, bl31 will boot
bl32(tee os) and bl33(u-boot or uefi), bl33 boot Linux kernel.
Now TF-A on ls1043ardb platform has the following features in this patch:
* Support boot from Nor flash.
* TF-A can boot bl33 which runs in el2 of non-secure world.
* TF-A boot OPTee OS.
* Support PSCI
Signed-off-by: Chenyin.Ha <Chenyin.Ha@nxp.com>
Signed-off-by: Chenhui Zhao <chenhui.zhao@nxp.com>
Signed-off-by: jiaheng.fan <jiaheng.fan@nxp.com>
Signed-off-by: Wen He <wen.he_1@nxp.com>
