All identifiers, regardless of use, that start with two underscores are
reserved. This means they can't be used in header guards.
The style that this project is now to use the full name of the file in
capital letters followed by 'H'. For example, for a file called
"uart_example.h", the header guard is UART_EXAMPLE_H.
The exceptions are files that are imported from other projects:
- CryptoCell driver
- dt-bindings folders
- zlib headers
Change-Id: I50561bf6c88b491ec440d0c8385c74650f3c106e
The watchdog block on the IMX is mercifully simple. This patch maps the
various registers and bits associated with the block.
We are mostly only really interested in the power-down-enable (PDE) bits in
the block for the purposes of ATF.
The i.MX7 Solo Applications Processor Reference Manual details the PDE bit
as follows:
"Power Down Enable bit. Reset value of this bit is 1, which means the power
down counter inside the WDOG is enabled after reset. The software must
write 0 to this bit to disable the counter within 16 seconds of reset
de-assertion. Once disabled this counter cannot be enabled again. See
Power-down counter event for operation of this counter."
This patch does that zero write in-lieu of later phases in the boot
no-longer have the necessary permissions to rewrite the PDE bit directly.
Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
