All identifiers, regardless of use, that start with two underscores are
reserved. This means they can't be used in header guards.
The style that this project is now to use the full name of the file in
capital letters followed by 'H'. For example, for a file called
"uart_example.h", the header guard is UART_EXAMPLE_H.
The exceptions are files that are imported from other projects:
- CryptoCell driver
- dt-bindings folders
- zlib headers
Change-Id: I50561bf6c88b491ec440d0c8385c74650f3c106e
STM32MP1 is a microprocessor designed by STMicroelectronics,
based on a dual Arm Cortex-A7.
It is an Armv7-A platform, using dedicated code from TF-A.
STM32MP1 uses BL2 compiled with BL2_AT_EL3.
Signed-off-by: Yann Gautier <yann.gautier@st.com>
Signed-off-by: Mathieu Belou <mathieu.belou@st.com>
Signed-off-by: Etienne Carriere <etienne.carriere@st.com>
Signed-off-by: Lionel Debieve <lionel.debieve@st.com>
Signed-off-by: Nicolas Le Bayon <nicolas.le.bayon@st.com>
Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
Signed-off-by: Pascal Paillet <p.paillet@st.com>
