path: root/drivers/st/reset/stm32mp1_reset.c
2020-06-01drivers: stm32_reset adapt interface to timeout argumentEtienne Carriere
Changes stm32mp1 reset driver to API to add a timeout argument to stm32mp_reset_assert() and stm32mp_reset_deassert() and a return value. With a supplied timeout, the functions wait the target reset state is reached before returning. With a timeout of zero, the functions simply load target reset state in SoC interface and return without waiting. Helper functions stm32mp_reset_set() and stm32mp_reset_release() use a zero timeout and return without a return code. This change updates few stm32 drivers and plat/stm32mp1 blé_plat_setup.c accordingly without any functional change. functional change. Change-Id: Ia1a73a15125d3055fd8739c125b70bcb9562c27f Signed-off-by: Etienne Carriere <etienne.carriere@st.com>
2019-02-14stm32mp1: add timeout detection in reset driverYann Gautier
This change makes the platform to panic in case of peripheral reset resource malfunction. Change-Id: I17eb9cb045b78a4e5142a8c33b744e84992d732a Signed-off-by: Yann Gautier <yann.gautier@st.com> Signed-off-by: Etienne Carriere <etienne.carriere@st.com> Signed-off-by: Nicolas LE BAYON <nicolas.le.bayon@st.com>
2019-02-14stm32mp1: use functions to retrieve some peripheral addressesYann Gautier
PWR, RCC, DDRPHYC & DDRCTRL addresses can be retrieved from device tree. Platform asserts the value read from the DT are the SoC addresses. Change-Id: I43f0890b51918a30c87ac067d3780ab27a0f59de Signed-off-by: Yann Gautier <yann.gautier@st.com> Signed-off-by: Etienne Carriere <etienne.carriere@st.com> Signed-off-by: Nicolas LE BAYON <nicolas.le.bayon@st.com>
2019-02-14stm32mp1: remove some dependencies on clocks and reset in driversYann Gautier
Include all RCC, clocks and reset headers from stm32mp1_def.h which if exported to the firmware through platform_def.h. The same dependency removal is done in common code as well. Some useless includes are also removed in stm32_sdmmc2 driver. Change-Id: I731ea5775c3fdb7f7b0c388b93923ed5e84b8d3f Signed-off-by: Yann Gautier <yann.gautier@st.com>
2019-02-14stm32mp1: make functions and macros more commonYann Gautier
Mainly remove suffix 1 from prefix stm32mp1 in several macros and functions that can be used in drivers shared by different platforms. Change-Id: I2295c44f5b1edac7e80a93c0e8dfd671b36e88e7 Signed-off-by: Yann Gautier <yann.gautier@st.com> Signed-off-by: Etienne Carriere <etienne.carriere@st.com>
2019-01-04Sanitise includes across codebaseAntonio Nino Diaz
Enforce full include path for includes. Deprecate old paths. The following folders inside include/lib have been left unchanged: - include/lib/cpus/${ARCH} - include/lib/el3_runtime/${ARCH} The reason for this change is that having a global namespace for includes isn't a good idea. It defeats one of the advantages of having folders and it introduces problems that are sometimes subtle (because you may not know the header you are actually including if there are two of them). For example, this patch had to be created because two headers were called the same way: e0ea0928d5b7 ("Fix gpio includes of mt8173 platform to avoid collision."). More recently, this patch has had similar problems: 46f9b2c3a282 ("drivers: add tzc380 support"). This problem was introduced in commit 4ecca33988b9 ("Move include and source files to logical locations"). At that time, there weren't too many headers so it wasn't a real issue. However, time has shown that this creates problems. Platforms that want to preserve the way they include headers may add the removed paths to PLAT_INCLUDES, but this is discouraged. Change-Id: I39dc53ed98f9e297a5966e723d1936d6ccf2fc8f Signed-off-by: Antonio Nino Diaz <antonio.ninodiaz@arm.com>
2018-07-24stm32mp1: Add clock and reset supportYann Gautier
The clock driver is under dual license, BSD and GPLv2. The clock driver uses device tree, so a minimal support for this is added. The required files for driver and DTS files are in include/dt-bindings/. Signed-off-by: Yann Gautier <yann.gautier@st.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Nicolas Le Bayon <nicolas.le.bayon@st.com> Signed-off-by: Lionel Debieve <lionel.debieve@st.com>
